XMega/Mega0/Tiny0/Tiny1 avr-libc boot.h (spm wrappers) support
6 posts / 0 new
Just checking:
there's still no avr-libc support equivalent to boot.h for the xmega chips, right?
And the new "xtiny" and "mega 0" chips have similar boot/spm usage?
Is there a different set of standard wrapper functions for SPM on these chips, or is everyone rolling their own?  :-(
(I did find various freaks discussions with sample xmega bootloader code, dating back to 2009...  That's 10 years ago!)
My Xmega bootloader uses routines I lifted out of the ASF/NVM driver code. If you don't have a copy install with Studio, you can find the files on Github.
(ah.  Mega0 and XTiny at least do not use SPM for writing flash, and in fact have removed SPM from the instruction set summary.)
(They use the NVM Controller peripheral instead.)
Huh.  The flash write function for Mega0/etc is pretty neat.
I'm a bit annoyed that I don't think you can duplicate the "a program can write to anywhere in flash" of the "self-programming" older ATtiny chips.
It means that you really do need to generate different binaries for a chip if you're using a bootloader, vs direct programming (since the bootloader has to be at zero.)
This is done using -Wl,--section-start=.text=ADDRESS, where ADDRESS points to immediately after the bootloader, right?
edit: or -Wl,-Ttext=ADDRESS
Yes.  But a bootloader is supposed to be transparent (IMO) - I shouldn't have separate compile rules for "xxx board with bootloader" and "xxx board with programmer."
I suppose you move the application even if no bootloader is present - the AVR will happily execute those 0xFFFF instructions (with little effect) until it gets to the start vector at the post-bootloader address.
I guess I should have noticed that this was happening on many ARM platforms :-(
This is different than the Xmegas, BTW.  They still have the boot section at the end of flash.
