ATMEGA2560 i2c issues
3 posts / 0 new
I am using using Peter Fluery's i2c library for my ATMEGA2560. I am trying to do simple scan of the bus. I only have 1 device on the bus at address 0xC8, however the library says there is another device at 0xC9.  When I connect an analyzer up I see it reads the the following write command as a read.
Here is my code:
#include <asf.h>
#include "uart_config.h"
#include <util/delay.h>
#include <avr/power.h>
#include "i2cmaster.h"
int main (void)
	unsigned char ret;
	uint8_t ack = 0;
	board_init();
	usart_init();
	printf("ATMEGA2560 i2c Scanner Rev 2\n\r");
	i2c_init(); // initialize I2C library
	uint8_t address = 0;
	for( address = 0; address < 255;address++){
		ret = i2c_start(address+I2C_WRITE);       // set device address and write mode
		if ( ret ) {
			i2c_stop();
		} else {
			printf("Found Device on 0x%02X\n\r", address);
			i2c_stop();
	while(true){
I would expect the i2c_stop() to release the bus and start all over. Any help is appreciated.
"When all else fails, read the directions"
You are using a 7-bit address = 0x64
Which is 0xC8 (Write) or 0xC9 (Read).
Fleury uses 8-bit addresses e.g.  0xC8/0xC9 pair.
Other libraries e.g. Wire.h use 7-bit address like 0x64.
If you are scanning for devices,  you just need to check the Write address e.g. 0xC8
or  (0x64 << 1) | I2C_WRITE if you follow the 7-bit convention.
Note that a polled approach is equally happy with separate 8-bit (W) and (R)
But an interrupt approach tends to use 7-bit because the ISR() will need to use both read and write sequences.
Incidentally,  what hardware device are you using which has 0x64 address ?
Hi David - The ATSHA204a sets the default i2c address to 0xC8 (2.1.2 Configuration Zone).  Shifting the bits over fixed the issue. Thanks for help.
