Looking for IoT advice.
29 posts / 0 new
Freaks,
 I'm consider a a project that will use a browser interface over WiFi. I have
no experience with WiFi and IoT devices and it would help if someone could look
at the concept and let me know if this is reasonable.
 - I have chosen Espressifs ESP8266 as the client/server.
 - The device will only be accessible via WiFi, so it will
   need to connect directly to a smart phone/tablet in
   order to enter WiFi credentials and for local control.
 - From the browser I should only need to modify uploaded
   text and download it onto the device.
  Is this something that is done on a regular basis or
am I building something that is non-standard?
  I'm using an ATmega1280 to control the project, so I
think it would be difficult to take advantage of the Arduino
stuff. Having said that, can anyone recommend resources
that might help with this project?
  Any advice appreciated.
A.
andrew99 wrote:
I'm using an ATmega1280 to control the project, so I think it would be difficult to take advantage of the Arduino stuff.
What is the attraction to the M1280 when the Ardunio Mega is cheap and available?    I do think you can find M1280 based arduino core so really not much of a barrier to using Arduino lib's.
Jim,
  Its kind of a trade off. I have about 5000 lines of code I need to port
to this new product. The current the device uses a keypad and LCD display.
 The existing code runs in about 1000 devices.
 I would need to learn the ins and outs of the Arduino, modify the
existing code and then add the web interface.
 Maybe I'm under the mistaken impression that developing the
web interface would be more straightforward?
A.
that makes perfect sense now!
I work with "front end" guys who develop the web interfaces for our products, so I'm not much help there.
It seems to be another coding specialty from embedded C/C++ coding.  i.e. do you use php, angular, node, ... others I'm sure for the web interface.
I'm not a Python or a C programmer, and I've not done much with IoT, however
SparkFun has a introduction to the ESP32 and MicroPython here.
While not exactly what you are looking for, it might be a good starting point to learn some basics, which you can then modify to meet your needs.
How complex is the current project, and how easily will you integrate WiFi access into the current project?
One might consider redoing the project using just an ESP... processor, which can easily handle the LCD, Keypad, and the IoT aspect, without the need for the second micro.
Do the 1000 devices in the wild already have the ESP... chip on the board?
If not, it sounds like this is a major rework on the project.
Jim,
  The current device is not connected to a network in any way. It
has a crude RS485 serial interface but lacks any networking
capability.
 I modified the existing controller card to to include a serial interface
connection and power for the ESP8266. ( Prototype. )
 I primarily deal with simple hardware design and programing and have
little to no knowledge of whats required here.
 A.
    So you need to run a web server somewhere in the ESP or your Mega128. Only you can decide how much of this will run on the ESP and how much will run on the MEGA. Ideally would be as much as possible on ESP and as little as possible to the existing Mega code. The downside of this could be that you feel more comfortable to code for Mega than for ESP. You may find libraries for a bare TCP/IP stack to run on ESP and you build the web pages in the MEGA.
The 'usual' solution would be to do the web stuff on the ESP as it has plenty of external flash to store your web pages. Then the interface with your other processor would be via serial. Depending on what actual data you need to transfer would determine how you packetise it via serial.
Also, note that you can do a whole lot of processing on the web browser - the javascript code is stored on the esp flash and loaded as part of the web page. So if you need to draw graphs or do curve fitting etc, do this on the browser.
At its simplest, the webserver is just a fileserver. The browser connects and expects a webpage which is just a file from the filesystem in the esp flash. It can also request more files. How do you transfer data between the webserver and the browser? AJAX is one method - effectively you request a file but in the webserver you have code that checks for specific filenames and gets the 'file' data from code that gets run. This code might send a request via serial to your other processor and when it responds, the 'file' data is returned to the browser. Similarly for writing data.
Other methods are to have special tags in your webpage code that the webserver looks for when it is serving a page when requested by the browser. When the special tag(s) is found, it is removed and the requested value is inserted. Downside is the webpage needs to be refreshed to update your data. This is the older skool method.
Then there's REST and websockets. Personally, AJAX is pretty simple.
There should be zillions of examples as this type of thing is what everyone wants to do.
I'd suggest using a ESP32 - later chip with more features.
andrew99 wrote:
It has a crude RS485 serial interface but lacks any networking capability.
A WebSocket can connect a MCU to an operator's web browser via a WebSocket server (MCU UART to/from WebSocket server to/from web browser)
Am aware of two proprietary WebSocket servers that can run on ESP8266 :
  • Minnow Server
  • Mongoose OS
There's an open source WebSocket server that runs on Linux, macOS, and Windows; might evaluate on an Intel Compute Card (12Vdc)
About HTML5 WebSocket - Powered by Kaazing
Introducing WebSockets: Bringing Sockets to the Web - HTML5 Rocks
websockets · PyPI (Python)
Embedded WebSocket Server (Minnow Server)
Mongoose OS - WebSocket client and server
https://github.com/chilipeppr/serial-port-json-server
Serial Port JSON Server is a websocket server for your serial devices. It compiles to a binary for Windows, Mac, Linux, Raspberry Pi, or BeagleBone Black that lets you communicate with your serial port from a web application. This enables web apps to be written that can communicate with your local serial device such as an Arduino, CNC controller… http://chilipeppr.com
[GPLv2]
Arduino Uno WiFi rev2 is a mega4809 with Wi-Fi by an ESP32; its mega4809 source code was recently made visible.
Microchip's alternative is mega4808 to a Cortus APS3 (32-bit) with source code in ASF.
https://www.avrfreaks.net/forum/megaavr-0-series?page=2#comment-2579861
New IoT sensor node w/ M4808 + wifi + battery
ATWINC1500 - Wireless Modules - Wireless
A MCU host driver can be found in the Advanced Software Framework (ASF).
An alternative to MicroPython is Zerynth; it has some timing and sizing advantages.
Zerynth has a low price for each instance (it's not open) with sales from distributors or direct.
Zerynth has a cloud interface and can run on ESP8266 or ESP32; Pycom WiPy (ESP32) comes in a module form and Olimex has the ESP32 WROOM module.
DocJC wrote:
One might consider redoing the project using just an ESP ...
A network stack is typically non-deterministic; that might not matter for some applications.
ESP32 has a dual-core form so one core for the network stack.
GCC toolchain with a SDK from Espressif Systems.
Zerynth Supported Devices
Zerynth Distributor | Mouser
Webshop - Pycom (OEM)
ESP32-WROOM-32 (Olimex)
Espressif Systems Distributor | Mouser
https://platformio.org/platforms/espressif32/packages
An ESP32 alternative is MIPS32 Wi-Fi modules; these run embedded Linux though consume about double the current at double the price.
Advantage is the wealth of FOSS packages.
Onion Omega2 Documentation - Connecting to Cloud Platforms
Onion
Powering the Omega with No Dock
https://docs.onion.io/omega2-docs/hardware-prep-no-dock.html
Providing Power
The Omega needs to be powered by 3.3V DC and requires 500mA to be safe.
Omega2S & Omega2S+ System-On-Modules - Onion | Mouser
https://www.olimex.com/Products/OLinuXino/RT5350F/RT5350F-OLinuXino/resources/RTF5350F-OLinuXino-UM.pdf
(page 15)
3.4 Powering the board
[5V, 0.15A typical to 0.4A peak]
via Olimex - RT5350F
Edit: last URL
andrew99 wrote:
Maybe I'm under the mistaken impression that developing the web interface would be more straightforward?
There are terminal servers that connect a MCU or MPU's serial port to the LAN (serial port to TCP port)
Lantronix has device servers that can connect one or two UARTs to TCP ports; about three times the price of an ESP32 WROOM though no need to develop software for the module.
A Lantronix device server appears to have a MCU and an RTOS (ThreadX) which likely has the network stack.
Lantronix Global Device Manager is software for provisioning and operating a fleet of their device servers through Lantronix gateways; couldn't locate what operating system it runs on.
Wi-Fi Archives | Lantronix
Lantronix
xPico Wi-Fi – User Guide
(page 57)
9: Tunnel Settings
Serial tunneling allows serial devices to communicate over a network, without "being aware" of the devices which establish the network connection between them. Tunneling parameters are configured using the Tunnel menu and submenus in Web Manager as described in this chapter.
via https://www.lantronix.com/products/xpico-wi-fi/#docs-downloads
via https://www.lantronix.com/products/xpico-wi-fi/#tab-docs-downloads
Real-Time Operating System Royalty Free THREADX® RTOS
due to https://www.lantronix.com/wp-content/uploads/pdf/Embedded-Module-Matrix.pdf
edits: strikethrus, ThreadX
ATWINC1500 isn't a fit for this case as its interface is SPI.
Microchip's Roving Networks (RN) has Wi-Fi modules by UART but these are NRND.
Wi-Fi Network Controller | Microchip Technology
Another way to work a fleet of UARTs is by a value-added part of PlatformIO ... PIO RemoteTM
PlatformIO has ESP8266 so can create software to serve up a UART.
PIO Remote — PlatformIO 3.6.2a2 documentation - Use Cases
Remote Serial Monitor:
Plans and Features · PlatformIO
Espressif 8266 · Platforms · PlatformIO
Another open source (LGPLv2.1) WebSocket server and client that runs on ESP32 down to mega328 and mega2560; includes ESP8266 :
GitHub - Links2004/arduinoWebSockets: arduinoWebSockets
https://github.com/Links2004/arduinoWebSockets#websocket-server-and-client-for-arduino-
a WebSocket Server and Client for Arduino based on RFC6455.
https://github.com/Links2004/arduinoWebSockets#supported-hardware
via Arduino WebSocket Server Using an ESP32 – Shawn Hymel
via Arduino WebSocket Server Using an ESP32 @HUZZAH32 Feather Board @arduino @shawnhymel « Adafruit Industries – Makers, hackers, artists, designers and engineers!
due to https://plus.google.com/u/0/+adafruit/posts/JNoUXgoUy2b
Do you need to do it with a browser and webpage?
If all you want is remotely writing to the serial interface you already have, a simple telnet server on the ESP8266 could be enough.
On the PC, you can then log in with any telnet capable client. There are also telnet clients for smartphones, if necessary.
"Some people die at 25 and aren't buried until 75." -Benjamin Franklin
What is life's greatest illusion?"  "Innocence, my brother." -Skyrim
Lantronix XPico Wi-Fi doesn't have TLS.
XPico 240 has TLS plus a Lantronix gateway function, SDK, and e-mail.
A Wi-Fi module with limited TLS (TCP client only) and a UART interface is WIZnet WizFi310; in bulk, it's approximately 20% less expensive than a XPico Wi-Fi.
WizFi310 is on the WIZnet Arduino MEGA 2560.
xPico 200 Series | Lantronix
Home - xPico 200 Series SDK
products:wizfi310:wizfi310pg:start [Document Wiki]
Network Commands
AT+SCON
Opens a socket and if it is a TCP Client, establishes TCP connection with remote peer device.
* 'Secured' means TCP connection through SSL Encryption. It can be used in only TCP Client mode.
WizFi310 | WIZnet Co., Ltd.
https://www.mouser.com/ProductDetail/WIZnet/WizFi310-PA?qs=sGAEpiMZZMsRr7brxAGoXSSUPDSAjAiVjW%252bis%2fvexGy1HfZWRNCwKw%3d%3d
osh:wizarduino_mega_wifi:start [Document Wiki]
Another apparently open source WebSocket server is
GitHub - ejeklint/ArduinoWebsocketServer
This library implements a Websocket server running on an Arduino.
The implementation in this library has restrictions as the Arduino platform resources are very limited:
[text only, no fragmentation, no keep-alive]
Requirements:
https://github.com/ejeklint/ArduinoWebsocketServer#requirements
[Arduino IDE, Arduino Ethernet or shield, WebSocket client (a recent web browser)]
via https://github.com/u0078867/Arduino-Websocket-Fast
via https://github.com/Wiznet/WizFi310_arduino_library/blob/master/examples/WebSocketEcho/WebSocketEcho.ino
Arduino Ethernet Rev3 without PoE
Arduino Ethernet Library 2.0.0
Minnow Server was dual-licensed (GPLv2, commercial) on 7-Dec'18.
wrt Microchip, the possible Minnow Server ports :
  • PIC32, MPLAB Harmony
  • SAMA5, Blackberry QNX or Microchip (Atmel) Software Package
  • other SAM, multiple RTOS or event frameworks
  • AVR and PIC, bare with lwIP
  • PIC24 and dsPIC (?)
PIC are 128KB max; so, 256KB for megaAVR and up to 384KB for XMEGA AVR are the better fit (128KB would be tight for app, SPA, Minnow Server, TCP/IP, TLS, Ethernet, scheduler, bootloader, FOTAU within app before boot)
Arduino's Ethernet library is for WIZnet Ethernet MAC (IIRC, max of 4 simultaneous sockets); Minnow Server reference is 1 socket max though is configurable.
Microchip's Ethernet library is for Microchip Ethernet MAC.
Dean's LUFA has RNDIS so IP over USB in-lieu of Ethernet.
PIC24, dsPIC :
Enough flash and RAM with some having for EBI PMP (100s KB of SRAM) and EPMP (MB of SRAM)
Probably lwIP for these though there are other IP stacks (Micrium TCP/IP, etc) (Microchip?)
PIC32MZ and SAMA5 have a MMU (GPLv2 Minnow Server can be separated from the application); otherwise, GPLv2 will be an issue that can be resolved by either purchasing a Minnow Server license or the application is FOSS compatible with GPLv2.
GitHub - RealTimeLogic/MinnowServer: A super small and fast embedded HTTP(S) WebSocket server
Efficient web server technology for resource-constrained microcontrollers | Embedded
by  (Founder & CTO of Real Time Logic)
JANUARY 17, 2019
(in second paragraph)
In fact, we believe WebSockets is the only viable option if you ever plan on TLS enabling the embedded web server.
Modern Web Application Reference Design for Microcontrollers
We recently committed our Embedded HTTP and WebSocket Server to GitHub. [MinnowServer on GitHub]
The HTTP protocol is used only for loading the SPA [Single Page Application]. In other words, HTTP is initially used by the browser when loading the application on demand from the device.
[signals, analog data, firmware over-the-air update (FOTAU)]
The complete SPA requires only 41 Kbytes of flash memory storage space.
The following screenshot shows the SPA firmware upload page.
All messages sent via the WebSocket connection are sent as JSON text messages except for the upload, which is sent as binary data. Modern JavaScript can easily manage binary data and the WebSocket protocol supports both binary and text frames.
[image of SPA's FOTAU]
Get Started with the Minnow Server
Note:
[immediately : Windows or Linux, quickly : ESP8266/FreeRTOS/lwIP]
The best way to think about how to create an SPA is to compare the development process to creating a desktop application or a phone application that is designed to communicate with a device using TCP.
[create an interface control document (information flows on WebSockets) to aid the firmware developer and the web developer]
MPLAB Harmony | Integrated Embedded Software Development Framework | Microchip Technology
QNX Operating Systems
GitHub - atmelcorp/atmel-software-package: Atmel Software Package
Four Walled Cubicle - LUFA (Formerly MyUSB)
lwIP: Overview
TCP/IP Networking | Micrium
https://www.micrium.com/downloadcenter/download-results/?searchterm=pa-microchip-pic243033&supported=true
yaSSL download | SourceForge.net
GitHub - ARMmbed/mbedtls: An open source, portable, easy to use, readable and flexible SSL library
edit: yaSSL, arm Mbed TLS
I do not like the ESP8266 much, mainly because there is no decent datasheet available, but just some 30 page overview.
"arduino" works on ESP8266 though, and the "Wemos D1 Mini" are nice small & cheap boards to work with.
I do not see much advantage in "Zerynth".  As most of the ESP8266 boards have multiple MB of memory the smaller footsize of Zerynth also seems mostly irrelevant.
I would also rather donate to Open Source projects I like than pay in advance for stuf I'm not even sure of whether it does what I want. It is the way my brain is wired.
If you like support from the manufacturer, then Zerynth may have the advantage for you.
Micro Python does indeed seem to be a nice option to write software for the ESP8266:
http://docs.micropython.org/en/latest/esp8266/quickref.html#dht-driver
Developing web related stuff is probably best done on a PC. Whether wired or WiFi, most of it is simply TCP/IP and having a keyboard and monitor on your target is a big convenience while developing software.
There are also multiple libraries available for web server like behaviour in Python. (but also in other languages).
With flask, for example this is the code for a working web server:
from flask import Flask
app = Flask(__name__)
@app.route("/")
def hello():
return "Hello World!"
if __name__ == "__main__":
app.run()
Source:
https://pythonspot.com/flask-hello-world/
I have not checked if Flask or any of the other web libraries have been ported to ESP8266.
Another technology that could be very relevant to your situation is MQTT.
MQTT is a standarized and lightweight protocol for machine to machine communication to exchange sensor data and more.
I never used it myself, but this should get you going:
https://duckduckgo.com/html?q=esp8266+mqtt
https://en.wikipedia.org/wiki/MQTT
Microchip IOT DESIGN WEEK
MARCH 9-13, 2020
Virtual
Expert Q&A Every Morning
Learn and ask questions during the livestream every morning at 9am PST. Livestreams give you the opportunity to interact with Microchip engineers remotely.
Your Couch is Calling
The event is completely digital, so feel free to join us from your couch!
Agenda
Contact
A Raspberry Pi can also be used as a console server. I use the R-Pi Zero W (10$) for this. I install the picocom package, and then I can SSH to the little host machine remotely and run picocom to talk with the serial inclined animals. But that is not all; it can also clone a git repository and build and upload right from the gum stick. And yep, there is still more; it has SPI and I2C (* Zero has a clock stretching issue), and it is running mainline Linux from Raspian (Debian is upstream), so real updates.
https://www.adafruit.com/product...
my projects: https://github.com/epccs
Debugging is harder than programming - don’t write code you can’t debug! https://www.avrfreaks.net/forum/help-it-doesnt-work
Similar with a WebSocket server than that encapsulates MCU UART or USB CDC ACM streams (ie a terminal server)
ron_sutherland wrote:
...  the gum stick.
Gumstix, Inc.
https://github.com/chilipeppr/serial-port-json-server/releases/tag/v1.96
Installing on Raspberry Pi:
A server for the Internet of Things. Lets you serve up serial ports to websockets so you can write front-end apps for your IoT devices in the browser.
That is cool :-), but keep in mind that an SSH connection helps keep the network footprint as near to nil as possible. The badness of IoT is the network footprint, and it has to bootload through potential adversaries.
The badness of IoT is the network footprint, ...
and the memory footprint.
Been stated that megabytes of object code for enabling network security; that's evident in edge computing.
Linux kernel is approximately a megabyte of object code.
Some RTOS have verified network interfaces and stacks (so, well less than one megabyte)
lwIP is one IP stack that's a part of the Core Infrastructure Initiative.
https://scan.coverity.com/projects?utf8=%E2%9C%93&search=lwip
due to Tooling - Core Infrastructure Initiative
