Solved: Magnetometer QMC5883L + mega328p issue
6 posts / 0 new
I have a problem with initialization the magnetometer sensor QMC5883L on the mega328p on Arduino board. I write a code on a Arduino software and everything works properly. But now I want to change it for the code in C language for AVR. So at the beginning i want to display information from magnetometer by the USART. I based on this tutorial https://www.electronicwings.com/avr-atmega/magnetometer-hmc5883l-interfacing-with-atmega16. This tutorial is dedicated for HMC5883L magnetometer and I tried to change it to the QMC5883L based on datasheet: http://wiki.epalsite.com/images/7/72/QMC5883L-Datasheet-1.0.pdf and Arduino dedicated library. When I initialize magnetometer, the USART did not respond. Nothing happens.
Please help. Below is the code:
#define F_CPU 16000000UL
#define FOSC 16000000	// Clock Speed
#define BAUD 9600
#define MYUBRR FOSC/16/BAUD-1
#include <stdlib.h>
#include <math.h>
#include <stdio.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include "I2C_Master_H_file.h"
#include "USART_irq.h"
#define I2C_READ 1
#define I2C_WRITE 0
#define QMC5883L_ADDR	0x0D							/* Magnetometer QMC5883L Address */
static FILE mystdout = FDEV_SETUP_STREAM(USART0_Transmit_IO, NULL,_FDEV_SETUP_WRITE);
void Magneto_init()										/* Magneto initialize function */
	I2C_Start(QMC5883L_ADDR+I2C_WRITE);					/* Start and write SLA+W */
	I2C_Write(0x0B);									/* Defined Set/Reset Period as Default */
	I2C_Write(0x01);									/* Configure register  */
	I2C_Write(0x09);
	I2C_Write(0x12);									/* Configure register OSR = 512, Full Scale Range = 8G(Gauss), ODR = 200HZ, set continuous measurement mode */
 	I2C_Stop();											/* Stop I2C */
void Magneto_GetPos(int *x, int *y, int *z)
		I2C_Start_Wait(QMC5883L_ADDR+I2C_WRITE);					/* Start and wait for acknowledgment */
		I2C_Write(0x00);											/* Write X register address */
		I2C_Repeated_Start(QMC5883L_ADDR+I2C_READ);						/* Generate repeat start condition with SLA+R */
		/* Read 16 bit x,y,z value (2’s complement form) */
		*x = ((int)I2C_Read_Ack() | ((int)I2C_Read_Ack()<<8));
		*y = ((int)I2C_Read_Ack() | ((int)I2C_Read_Ack()<<8));
		*z = ((int)I2C_Read_Ack() | ((int)I2C_Read_Nack()<<8));
		I2C_Stop();
	I2C_Init();											/* Initialize I2C */
	Magneto_init();
    USART0_Init(MYUBRR);								// Calculate baud rate
	sei();				/* Enable interrupts => enable UART interrupts */
	stdout = &mystdout;
	int xAxis = 0 , yAxis = 0, zAxis = 0;
	int i = 0;
    while (1)
		Magneto_GetPos(&xAxis, &yAxis, &zAxis);
		printf("x: %d | y: %d | z: %d | t -> %d\n", xAxis, yAxis, zAxis, i);
		i++;
		_delay_ms(1000);
Arduino board uses a mega328. Are you sure yours is a mega32?
Sorry my mistake. You're right. Arduino uses mega328p
Change the title and post to avoid confusion.
Isthe uart working?
My guess is your i2c address is not correct for the library you are using. This is a common source of confusion. In some cases you must shift the device address left one bit
After your suggestion to shift device address, the uart starts working and displays constant numbers, so it helped a little bit. But it doesn't display actual measured values.
I fix it. Now works fine. UART displays actual measured values. I've just replaced lines
on these
I2C_Start(((QMC5883L_ADDR)<<1) | I2C_WRITE);
I2C_Start_Wait(((QMC5883L_ADDR)<<1) | I2C_WRITE);
I2C_Repeated_Start(((QMC5883L_ADDR)<<1) | I2C_READ);
Thank you for your help Kartman smiley.
