Basic info for the Atmega8515 AVR
12 posts / 0 new
Dear all
I am trying to read an AVR atmega8515 chip from one application and i have the following problem :
When i give the order to READ the chip the software send me back ERROR messages << Power ON - FAIL >> and << Cannot communicate with the target chip >> (check the attached picture - original Atmega)
I use the same programmer with one other same chip and the results was normal . (check the attached picture - empty Atmega)
My question is the following :
i take that error messages from the original chip because it is Locked .... or the Chip is damaged and i should replaced it .
Thank you
in advance .
regards
sv1plh
Are both chips being plugged into the exact same socket to give the results you posted?
Power ON - FAIL
Is the chip powered??
The IC that you can't read is still most likely in good condition, however (it is likely) that the chip had its SPIEN fuse deactivated when it was previously written.
Try buying or building an AVR programmer that has the high-voltage serial programming feature included.  High voltage means +12V applied to the reset pin.  I believe that there are several examples listed in the Projects section of this website.
Chips also need a clock source.  The ISP bit rate needs to be appropriate for that clock speed.
Yes it is exactly the same !!!
Yes it is !
I dont use clock input ......
I will try with a crystal
Thank you
First i will try with a crystal (same like the one in the application) and if i receive the same abnormal messages ,  i will check your proposal .
Thank you !!!
Uh, highly unlikely:
Thank you
Finally even the crystal don't make any difference , the chip can not powered ON from the programmer .
I will check the solution with the higher source (12V) programmer and i revert .
Thanks again for your time and the attached table 83
regards
SV1PLH
???  Does your ISP programmer provide power to the target chip?  Many (most?) have a Vcc connection, but that is to SENSE the Vcc level, not provide supplyV to the target chip.
What voltage do you measure at the Vcc pin(s)?
??? again.   Do you really have the facilities for a HV parallel programming setup?
