attiny1616 UART PROGRAM NOT WORKING IN ATMEL STUDIO 7
12 posts / 0 new
Hai,
       i am trying to interface BM70 BLUETOOTH module with attiny1616. i have used the sample UART program to send a script to BM7O MODULE. But in my code there are some mistakes. i couldnt understand that. Please find the solution for it.
1. i have used alternate UART PIN POSITION.
My code as follows:
#define F_CPU 20000000
#define USART0_BAUD_RATE(BAUD_RATE) (float)(20000000 * 64 /16 *(float)BAUD_RATE) + 0.5)
#include<util/delay.h>
#include<string.h>
#include<stdint.h>
void USART0_init(void);
void USART0_sendchar(char C);
void USART0_sendString(char *str);
    USART0_CTRLC = USART_CMODE_ASYNCHRONOUS_gc ;
    PORTMUX.CTRLB |= PORTMUX_USART0_ALTERNATE_gc;
    PORTA_DIR &= ~PIN1_bm;
    PORTA_DIR |= PIN2_bm;
    USART0_BAUD = (uint16_t) USART0_BAUD_RATE(115200);
    USART0_CTRLB |= USART_TXEN_bm;
    while (!(USART0.STATUS & USART_DREIF_bm))
    USART0.TXDATAL=C ;
    for (size_t i=0; i<strlen(str); i++)
        USART0_sendString(str[i]) ;
    USART0_init();
        USART0_sendString("hello world!/r/n") ;
        _delay_ms(500);
First, eliminate the build error.
The mistake is on the second and 35th lines.
Yes there is some error.i am having doubt with how to set the baud rate also..i want to baud rate of 115200 and i am using internal clock of 20MHz. is it corect way to represent baud rate in my program?
How do you know it's 20MHz?
Have you ever heard about the clock divisor? You should open the datasheet and learn about it.
Modify lines 1 and 2 like this:
#define F_CPU 20000000UL
#define USART0_BAUD_RATE(BAUD_RATE) (float)(F_CPU * 64 / (16f * (float)BAUD_RATE) + 0.5)
Modify line 35 like this:
        USART0_sendchar(str[i]) ;
And the clock must be changed to 20MHz by your program. At startup, the 1/6 prescaler is enabled.
Thank you so much for your input. i am a beginner in embedded C
HI,
    i have made the above corrections. I have checked the clkout by using a DSO.It is getting 3.33Mhz. I tried to read the Tx output using a Oscilloscope. Nothing displayed in it. What to do?
Code is written as below.
I selected the 20Mhz internal oscillator. Prescaler value is 6 by default. I haven't selected the frame rate as it is using the default 8bit data and one stop bit.
Anything more i have to do to work this code?
#define F_CPU 3333333
#define USART0_BAUD_RATE(BAUD_RATE) ((float)(F_CPU * 64 / (16 * (float)BAUD_RATE)) + 0.5)
#include <util/delay.h>
#include <string.h>
void USART0_sendChar(char c);
    PORTB_DIR &= ~PIN3_bm;  //Rx Pin
    PORTB_DIR |= PIN1_bm;    //Tx Pin
    USART0_BAUD = (uint16_t)USART0_BAUD_RATE(9600);
    while (!(USART0_STATUS & USART_DREIF_bm))
    USART0_TXDATAL = c;
    for(size_t i = 0; i < strlen(str); i++)
        USART0_sendChar(str[i]);
    USART0_init();
    while (1)
        USART0_sendString("Hello World!\r\n");
        _delay_ms(500);
Tx is PB2, not PB1.
TX pin is PB2(PIN2_bm).
Isn't it a shame that Xmega/Xtiny are not like tiny/mega which automatically set pin direction at RXEN/TXEN? I'm sure there must be some hugely technical reason why leaving the direction setting to be done separately is a "better idea" but, off-hand I can't quite think what. (I suppose it opens the possibility of HI-Zing usually driven outputs if something else might be coming onto the bus or something??). It might have been better if the UART registers had a special "relinquish control bit" to be used as an exception in the 0.0001% of cases when just setting IN/OUT is not required.
Thank you all. its qorked
