atsha204a newbie struggle
3 posts / 0 new
I am completely new to the atsha204. I am having difficulty understanding several things.
At first I am using a ATmega328PB to interface the two wire I2C bus. At first I want to use the atsha204 only to get random numbers and store values in EEPROM. So I do the wakup sequence (200µS SDA low and then wait 7ms, times are longer just to make sure). Then I scan the bus on all 128 addresses. But I do not get any ACK on any address. What am I missing?
Is there a library specific for the AVR in C thats easy to use? I find it hard to understand how this device is interfaced.
Glad for any help
Thnks
Kind regards
Microchip has a very good library called CryptoAuthLib (requires login). Packed full of examples. The library supports a HAL interface for connecting with i2c or SWI with any device that support those protocols. There are a few examples on how to implement your own and an Application Note here. I am currently working on added a SWI interface for the ATMEGA328.
"When all else fails, read the directions"
Thanks for the links! Exactly what I was looking for.
Also, I saw one of my pullups on the I2C was not soldered correctly and thus the reason the bus did not work angry Always a bummer looking for a hardware fault in the code.
