AVR Studio 4.19 TIMSK Error
15 posts / 0 new
Why would this set bit 5?
    TCCR1B = (1<<WGM12) + (1<<CS10);
    OCR1A  = nnnn;
    TIMSK  = (1<<OCIE1A);
    Or just:
    (1<<6) really does (1<<5), as well as (1<<5) really does (1<<6)
    or
    0x20 really does 0x40, as well as 0x40 really does 0x20
    LUNACY!
In the TIMSK, i.e. setting bit 5 (OCIE1B) sets bit 6 (OCIE1A) and vice versa, with an ATtiny2313!
The photo is of setting OCIE1A
iotn2313.h states:
#define OCIE1A  6
#define OCIE1B  5
Please someone try this and let me know if I am doing something wrong.
What happens in AS7 for the same?
(AS7 being the 10 years younger and actively maintained development of AS4 in the year 2019)
Is this happening on real h/w or in the simulator on AS4?
Thanks for replying Cliff, but no. AS7 will not run or load on my WIN 7 SP2 with 8 Gb of memory & 3.4GHz quad core.
There is no selection for Tiny devices in AS6 or I would confirm.
Confirmed on AS6 that it steps correctly. I am still re-learning AS6 "It offends our sensibilities and we are not amused"
I know it is old but I don't need a bloated .net app for what I am doing as you have heard from me before. So I won't re-hash it here.
So if anyone can confirm the operation in AS4 I would appreciate it. Yes AS4 as one steps through, F11 it does it backwards.
  H/W or Sim?  What are we talking about here?
As I have stated, Simulator in debug mode.
Odd, it runs great on mine.  What was/is the problem?
No argument from me on the bloatware.  But hey, if it works properly, and big hard drives are cheap as they are, I bite the bloat-bullet and move on.  I do admit I miss 4.19 at times though.
Not directly, but yeah, I figured you were.
Might I suggest you try MPLAB now that it supports AVR's?  It's a somewhat lighter install......
as far as your original question, last time I ran the 4.19 simulator it did not have the issue you are writing about.
It looks like you are adding the two bits together.  Try this:
 TCCR1B = (1<<WGM12) | (1<<CS10);
instead
Yes I know not to use "+". It is as the code as was written, and trying to run as presented by the author. I would prefer to use | or |= for the bits mentioned. But that is not the focus of this discussion at this time.
AS7 is as I have stated, A: Bloatware, 2: crashes upon running; C:\ took many re-installs to actually finish its install, 0x0D: offensive in its over complication and "views" to use.
But I enjoy your interaction(s).
It looks like TIFR is backwards to the ISR vector name as well...... All in Sim v2, tiny 2313 or 2313A
Looky Looky, version 1 or the original version of the simulator is loading properly. More BUGS on a rushed - abandoned AS4.19.
OCIE1A = OCIE1A  when stepping, TIFR Flags work correctly.
Mega48 works properly in v2 sim BTW.
Just debug in disassemble mode, than you can see what the code do.
Then WTF IS the discussion at this time?  I went through some of your past posts/threads, and all you seem to want to do is bitch about how poor Atmel products are.  If they suck so bad then WHY the hell use them?  Go with ANYONE else's parts if the tools are so bad.  OR, purchase an IAR license where for the price you can expect the world if you want.....and they should deliver.
It could quite possibly be that the author made a mistake on the code?  Would not be the first time we have found that.
I was talking about AS4 not my coding ability.
Your avatar fits your disposition. Please control yourself and stop your personal attacks. People change, try it sometime.
I have read many posts here where many derail the topic and engage in useless in-fighting and diatribe unrelated to the original post. This helps nobody.
If you assume I like other products more than Atmel then YOU ARE WRONG.
If you cannot observe the view of someones observances, concerns and notations of errors, I suggest you refrain from frivolous haranguing of said individuals.
Where?
I'm out, don't need the abuse!
Hope you get your project working.
Sparky85 wrote:
If you cannot observe the view someones observances, concerns and notations of errors, I suggest you refrain from frivolous haranguing of said individuals.
No problem, May someday you accept that nothing is perfect and that your arrogance in pointing said imperfections shows how narrow minded you are as well.
I wish you and your self riotousness to a long and happy existence.
I will bother, and frivolous haranguing you no more.
All the best
JIm
Why are you fiddling with the simulator in the first place? ...just put your code in a chip & have at it.   Doubt I've used the simulator more than once or twice in the last decade.  However, that's partly because the exterior signals (sensors, etc) keep doing their thing, so stepping along through code rarely provided any sensible or useful results.
The simulator is also very little help if you rely on a 32768Hz crystal for interrupt ticks. I use the simulator, when I can but, in late stage development, it is much less helpful.
