ATtiny1614 Fuse settings + Avrdude
22 posts / 0 new
Hi!
I'm using a ATtiny1614 and trying to setup the fuses.
For while i'm programming the .hex file with avrdude and an Arduino (ElTangas UPDI Programmer) but I don't know how can I setup the fuses since I'm generating the hex file from AS7 and programming externally with avrdude.
Can someone help me?
In which case you may want to read this page in the manual:
https://www.nongnu.org/avr-libc/user-manual/group__avr__fuse.html
However to use this requires that you are using "ELF programming" not "HEX programming" (as it relies on a .fuse section that is embedded in the ELF).
Personally I'd tend to treat (during development) fuses as a "fire once and forget". You only need to work out once what you need, have one programming session during which you program the fuses then never go near them again.
Tell us what you want to do, or post the fuse settings you think you want to set and someone here will guide you to the correct fuse settings.
FF = PI > S.E.T
So first I have to flash a .elf with this code?
FUSES = {
    .WDTCFG     = WDT_WINDOW_OFF_gc | WDT_WINDOW_8KCLK_gc,  // WDT = OFF
    .BODCFG     = LVL_BODLEVEL7_gc | SAMPFREQ_1KHZ_gc | ACTIVE_ENABLED_gc | SLEEP_SAMPLED_gc,  // BOD level = 4.3V
    .OSCCFG     = FREQSEL_20MHZ_gc,
    //  .TCD0CFG    =
    //  .SYSCFG0    =
    //  .SYSCFG1    =
    //  .APPEND     =
    //  .BOOTEND    =
And after that I can flash my program .hex normally?
This is my fuse settings.
FUSES = {
    //  .TCD0CFG    =
    //  .SYSCFG0    =
    //  .SYSCFG1    =
    //  .APPEND     =
    //  .BOOTEND    =
You seem confused. Try following Jim's advice in #3
I want to activate the BOD and WDT.
But I don't know how to send it to the ATtiny
As a general rule, programming is either a single step process using the .elf file, or a two step process using the .hex file and following that with setting the fuses.
Which method you use will depend on the tools you use.
I'm not an avrdude expert so others will need to jump in, but this method uses the two step method, although it can be all on one command line, using the .hex file and fuse settings.
The other way is to use atprogram and one of several Atmel programmers with the .elf file method.
Hope that helps.
FF = PI > S.E.T
Well you should be able to do it with some -U's on the avrdude command line. It accepts things like "-U hfuse:w:0xNN:m" however the "tricky bit" for these new AVRs will be knowing what replaces "lfuse","hfuse","efuse" as presumably they aren't called that any more.
EDIT: Oh I see from:
https://github.com/facchinm/avrdude/blob/master/avrdude.conf.in#L15248
that apparently these "8x" parts now just call the fuse bytes "fuse0", "fuse1", "fuse2" and so on.
You are going to need a fairly recent avrdude (or more specifically avrdude.conf) so it "knows" about these new chips.
Ok
I can use the .elf file on avrdude. I just don't know how can I set the fuses in code, because the device I'm using (Attiny1614) doesn't accept this format (lfuse, hfuse, efuse -  https://www.nongnu.org/avr-libc/user-manual/group__avr__fuse.html)
So I tried this way:
FUSES = {
    //  .TCD0CFG    =
    //  .SYSCFG0    =
    //  .SYSCFG1    =
    //  .APPEND     =
    //  .BOOTEND    =
instead of this
FUSES =
.low = LFUSE_DEFAULT,
.high = (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_EESAVE & FUSE_SPIEN & FUSE_JTAGEN),
.extended = EFUSE_DEFAULT,
But it seems not work.
You have to set _all_ the fuses or you will brick the chip.
You are lucky you weren't able to program the fuses yet. Set the unused fuses to default values.
These are the default values, so change what you need to change and write the others to default values, especially SYSCFG0.
FUSES = {
	.WDTCFG = 0x00,			/* Watchdog Configuration */
	.BODCFG = 0x00,			/* BOD Configuration */
	.OSCCFG = 0x02,			/* Oscillator Configuration */
	.reserved_0x03 = 0xFF,
	.TCD0CFG = 0x00,
	.SYSCFG0 = 0xF6,		/* System Configuration 0 */
	.SYSCFG1 = 0x07,		/* System Configuration 1 */
	.APPEND = 0x00,			/* Application Code Section End */
	.BOOTEND = 0x00			/* Boot Section End */
If you don't to this, all "commented out" fuses will be set to zero with very bad results. They will not be preserved.
Well, ok, those that default to zero may be commented out.
Look at the device header...
/* ========== Fuses ========== */
#define FUSE_MEMORY_SIZE 9
/* Fuse Byte 0 (WDTCFG) */
#define FUSE_PERIOD0  (unsigned char)~_BV(0)  /* Watchdog Timeout Period Bit 0 */
#define FUSE_PERIOD1  (unsigned char)~_BV(1)  /* Watchdog Timeout Period Bit 1 */
#define FUSE_PERIOD2  (unsigned char)~_BV(2)  /* Watchdog Timeout Period Bit 2 */
#define FUSE_PERIOD3  (unsigned char)~_BV(3)  /* Watchdog Timeout Period Bit 3 */
#define FUSE_WINDOW0  (unsigned char)~_BV(4)  /* Watchdog Window Timeout Period Bit 0 */
#define FUSE_WINDOW1  (unsigned char)~_BV(5)  /* Watchdog Window Timeout Period Bit 1 */
#define FUSE_WINDOW2  (unsigned char)~_BV(6)  /* Watchdog Window Timeout Period Bit 2 */
#define FUSE_WINDOW3  (unsigned char)~_BV(7)  /* Watchdog Window Timeout Period Bit 3 */
#define FUSE0_DEFAULT  (0x0)
#define FUSE_WDTCFG_DEFAULT  (0x0)
/* Fuse Byte 1 (BODCFG) */
#define FUSE_SLEEP0  (unsigned char)~_BV(0)  /* BOD Operation in Sleep Mode Bit 0 */
#define FUSE_SLEEP1  (unsigned char)~_BV(1)  /* BOD Operation in Sleep Mode Bit 1 */
#define FUSE_ACTIVE0  (unsigned char)~_BV(2)  /* BOD Operation in Active Mode Bit 0 */
#define FUSE_ACTIVE1  (unsigned char)~_BV(3)  /* BOD Operation in Active Mode Bit 1 */
#define FUSE_SAMPFREQ  (unsigned char)~_BV(4)  /* BOD Sample Frequency */
#define FUSE_LVL0  (unsigned char)~_BV(5)  /* BOD Level Bit 0 */
#define FUSE_LVL1  (unsigned char)~_BV(6)  /* BOD Level Bit 1 */
#define FUSE_LVL2  (unsigned char)~_BV(7)  /* BOD Level Bit 2 */
#define FUSE1_DEFAULT  (0x0)
#define FUSE_BODCFG_DEFAULT  (0x0)
/* Fuse Byte 2 (OSCCFG) */
#define FUSE_FREQSEL0  (unsigned char)~_BV(0)  /* Frequency Select Bit 0 */
#define FUSE_FREQSEL1  (unsigned char)~_BV(1)  /* Frequency Select Bit 1 */
#define FUSE_OSCLOCK  (unsigned char)~_BV(7)  /* Oscillator Lock */
#define FUSE2_DEFAULT  (0x2)
#define FUSE_OSCCFG_DEFAULT  (0x2)
/* Fuse Byte 3 Reserved */
/* Fuse Byte 4 (TCD0CFG) */
#define FUSE_CMPA  (unsigned char)~_BV(0)  /* Compare A Default Output Value */
#define FUSE_CMPB  (unsigned char)~_BV(1)  /* Compare B Default Output Value */
#define FUSE_CMPC  (unsigned char)~_BV(2)  /* Compare C Default Output Value */
#define FUSE_CMPD  (unsigned char)~_BV(3)  /* Compare D Default Output Value */
#define FUSE_CMPAEN  (unsigned char)~_BV(4)  /* Compare A Output Enable */
#define FUSE_CMPBEN  (unsigned char)~_BV(5)  /* Compare B Output Enable */
#define FUSE_CMPCEN  (unsigned char)~_BV(6)  /* Compare C Output Enable */
#define FUSE_CMPDEN  (unsigned char)~_BV(7)  /* Compare D Output Enable */
#define FUSE4_DEFAULT  (0x0)
#define FUSE_TCD0CFG_DEFAULT  (0x0)
/* Fuse Byte 5 (SYSCFG0) */
#define FUSE_EESAVE  (unsigned char)~_BV(0)  /* EEPROM Save */
#define FUSE_RSTPINCFG0  (unsigned char)~_BV(2)  /* Reset Pin Configuration Bit 0 */
#define FUSE_RSTPINCFG1  (unsigned char)~_BV(3)  /* Reset Pin Configuration Bit 1 */
#define FUSE_CRCSRC0  (unsigned char)~_BV(6)  /* CRC Source Bit 0 */
#define FUSE_CRCSRC1  (unsigned char)~_BV(7)  /* CRC Source Bit 1 */
#define FUSE5_DEFAULT  (0xc4)
#define FUSE_SYSCFG0_DEFAULT  (0xc4)
/* Fuse Byte 6 (SYSCFG1) */
#define FUSE_SUT0  (unsigned char)~_BV(0)  /* Startup Time Bit 0 */
#define FUSE_SUT1  (unsigned char)~_BV(1)  /* Startup Time Bit 1 */
#define FUSE_SUT2  (unsigned char)~_BV(2)  /* Startup Time Bit 2 */
#define FUSE6_DEFAULT  (0x7)
#define FUSE_SYSCFG1_DEFAULT  (0x7)
/* Fuse Byte 7 (APPEND) */
#define FUSE7_DEFAULT  (0x0)
#define FUSE_APPEND_DEFAULT  (0x0)
/* Fuse Byte 8 (BOOTEND) */
#define FUSE8_DEFAULT  (0x0)
#define FUSE_BOOTEND_DEFAULT  (0x0)
So like avrdude it seems the fuses no longer have "names" but are just fuse0, fuse1 and so on. In fact you can see that in fuse.h:
#if FUSE_MEMORY_SIZE > 3
typedef struct
    unsigned char byte[FUSE_MEMORY_SIZE];
} __fuse_t;
So the FUSES= section is going to be something like:
FUSES = {
    .byte[0] = FUSE_WDTCFG_DEFAULT,
    .byte[1] = FUSE_LVL2 | FUSE_LVL1 | FUSE_LVL0 | FUSE_ACTIVE0 | FUSE_SLEEP1
    etc.
El Tangas wrote:
FUSES = {
	.TCD0CFG = 0x00,
Where are you getting those field names? I don't see them in the device header? As far as I can see the fields (when >3 fuses) are just .byte[0]=, .byte[1]= and so on ??
They are somewhere else in the header:
FUSE - Fuses
/* Fuses */
typedef struct FUSE_struct
    register8_t WDTCFG;  /* Watchdog Configuration */
    register8_t BODCFG;  /* BOD Configuration */
    register8_t OSCCFG;  /* Oscillator Configuration */
    register8_t reserved_0x03;
    register8_t TCD0CFG;  /* TCD0 Configuration */
    register8_t SYSCFG0;  /* System Configuration 0 */
    register8_t SYSCFG1;  /* System Configuration 1 */
    register8_t APPEND;  /* Application Code Section End */
    register8_t BOOTEND;  /* Boot Section End */
} FUSE_t;
Ah I see. I was misreading:
#if !defined(FUSES)
  #if defined(__AVR_XMEGA__)
    #define FUSES NVM_FUSES_t __fuse FUSEMEM
  #else
    #define FUSES __fuse_t __fuse FUSEMEM
  #endif
#endif
For tiny1614 "__AVR_XMEGA__" is in fact true. Therefore the fuses are defined in terms of NVM_FUSES_t and not just __fuse_t as I thought. __fuse_t is the thing that does:
typedef struct
} __fuse_t;
But, as you say, it actually uses:
/* Fuses */
} FUSE_t;
/* avr-libc typedef for avr/fuse.h */
typedef FUSE_t NVM_FUSES_t;
to define NVM_FUSES_t because it's really an Xmega.
clawson wrote:
(...) because it's really an Xmega.
Yes, exactly, one must keep that in mind when navigating the headers.
I've set up according you wrote:
FUSES = {
    .BODCFG = 0xE5,            /* BOD Configuration */
    .TCD0CFG = 0x00,
     return 0;
Generated the .elf file and using avrdude flashed the ATtiny1614
Are these the correct procedures?
Yes, but you should use the macros instead of hardcoded hex values. Then you need to extract the fuses from the elf file.
I add this to the "post-build events" on AS7:
"$(ToolchainDir)"\avr-objcopy.exe -O ihex -R .text -R .eeprom -R .lock -R .signature -R .user_signatures --change-section-lma .fuse=0 "$(OutputFileName).elf" "$(OutputFileName)_fuses.hex"
This will create a filename_fuses.hex file in the AS7 output directory, containing the fuses.
Then write the fuses with avrdude, using the -U fuses:w:filename_fuses.hex:i command.
I have been using the attiny1614 with fuse settings inside the code, using Atmel Studio to generate the .elf file which i then use  the Atmel Studio command prompt to program the boards at work through a batch file. I test quick code changes through AS7 programing though.
I thought AVRdude has not been updated with the Attiny1614, but i have not checked in awhile. Atmel studio command prompt works great, but (probably do to user error) i can only get the batch/.cmd files to work if they are directly located  on C: drive main in Windows 7-10. If i try to dive through folders for the batch file it is as if AS command prompt acts like Windows regular command prompt and i cannot program my target device.
#include <avr/interrupt.h>
#include <avr/sleep.h>
// Set fuses:
FUSES =
    .BODCFG    = ACTIVE_ENABLED_gc | LVL_BODLEVEL2_gc,// 2.6v BOD, VLM at 3.3 for battery monitor and chip shut down
    //.BODCFG    = ACTIVE_ENABLED_gc | LVL_BODLEVEL3_gc,//2.95v BOD, vlm@ +5% = 3.0975V
    .OSCCFG    = FREQSEL_16MHZ_gc,
    .SYSCFG0	= RSTPINCFG_UPDI_gc | CRCSRC_NOCRC_gc,
    .SYSCFG1	= SUT_64MS_gc,
    //.TCD0CFG	= 0x00,
    //.WDTCFG     = 0x00,
    //.APPEND     = 0x00,
    //.BOOTEND	= 0x00,
~William
If you browse the iotn1614.h file it will give you 5800 lines of of defines/commands you will use for 'C' code programming.
This header(along with many others) should be installed along with AS7 and are in folders located somewhere in your install folder, also available online.
This in an invaluable tool to help along with the data sheet.
~William
Well, the secret avrdude build used by the Arduino IDE has been updated (windows build with extra stuff, all that matters is avrdude.exe and avrdude.conf): http://downloads.arduino.cc/tool...
Added in '18 though the UPDI effort began in '17.
http://svn.savannah.gnu.org/viewvc/avrdude/trunk/avrdude/ChangeLog-2018?revision=1427&view=markup
2018-01-10 Joerg Wunsch <j.gnu@uriah.heep.sax.de>
Submitted by Jan Egil Ruud <janegil.ruud@microchip.com>
(ATtiny1614,...
