Dual MCU - Programming Atmel ICE
5 posts / 0 new
I'm designing a new PCB that features an ATmega328p and ATtiny80. Both MCUs are SMT and populated by a turnkey manufacturer.
They communicate over I2C with the 328p being the master.
The tiny runs a stepper motor at whatever speed the 328p tells it to.
I am planning to program these using the Atmel ICE and Atmel Studio.
I've never used Atmel ICE, ATtiny, or Multiple MCUs in a single board before so I've very new to these areas.
What would the best way to program these be?
Would I just be able to wire both MCUs to the 6 pin programming port and the software is able to detect which MCU to upload to?
Each MCU needs it's own programming connector, ISP for 328, could not find a tiny80? post a link to the DS please.
BTW: I forgot to say: Welcome to AVRFreaks!
By chance is it a Tiny88 or Tiny85? Both of these also use ISP for programming, so you would need two 6 pin ISP connectors (or at least the holes for same) on the PCB.
Sorry, I meant tiny85.
http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-2586-AVR-8-bit-Microcontroller-ATtiny25-ATtiny45-ATtiny85_Datasheet.pdf
Section 20.5
What if they both use ISP? Could I specify one ISP 6 pin port in my design and wire it to both MCUs?
Can Atmel Studio detect each MCU using its device ID?
One ISP per mpu
