Atsha204a
10 posts / 0 new
Hi guys
I am using the atsha204a for first time and I want to read the data what I have written in slot 0 so this is the step which I have used
1] Config Write – writing 0x80 0x80 0x80 0xA1
2]Locking Config Zone
3]Writing your 32bytes private key in slot 0
4]Locking Data Zone
and how to unlock the locked config or data zone
Regards
Harish
Harish
Hello Friends,
I am using Atsha204 to implement secure boot.
Is their any configuration in which after locking the configzone I can unlock it back ??,because I am new to this device and I have to work with it.
Regards
Harish
Harish
Pretty sure there was a recent thread asking the same question, and the answer was no - once it's locked, it's locked.
Which makes sense for a security product!
I have one controller in its I2C ATSHA204 device is their. Now I want to use ATSHA204 as an authenticator during the bootup process so I saw Diversified Key Authentication using random number. So I will read the serial number from the device and using the Gendig I will mac value to the ATSHA204 it will give response and in the end I have to compare that response.
I am getting confused here at the end with what should I compare the response with ???
Regards
Harish
Harish
This is the step which I am following for Diversified key authentication
1) Reading serial number for the ATSHA204 device. I am getting 8 bytes serial number.
2)I am generating 32bytes random number from the function atcab_random(uint8_t*random).
3)Creating a atcab_challenge using the random number as the argument.
4)Creating gendig using atcab_gendig_host(),which takesGENDIG_ZONE_DATA ,as zone argument value,key_id is 0,and passing 8bytes serial number.
5)After this I get a 32 bytes response from ATSHA204.
6)Now by using atcab_mac(),function I am trying to compare the response.
7)I am getting mac_failed as response from ATSHA204 (4 1 0 C3).
I am going somewhere wrong can someone helpmeout.
Regards
Harish
Harish
Hello Friend's
My system is having a controller and a crypto ic Atsha204. So can I do the diversified key authentication ?
Regards
Harish
Harish
I am having the same issue of having  mac_failed. Does someone having any solution or proper steps for key authentication?
i've put together an all-in-one project.
https://github.com/PhillyNJ/SAMD21/tree/master/examples/atsha204a
The demo written for a SAMD21 xplained pro.
Here is a walk-thru of the demo
The demo will configure the device, lock it and then there are a bunch of examples. I tried to include a bunch of real time examples. Let me know what you think.
"When all else fails, read the directions"
Hi  PhillyNJ,
Thanks for the Reply.
Seems like very helpful. I will surely evaluate this.
Thanks.. :)
