Spi interupt (spie) and spdr makes me problem.
4 posts / 0 new
Hi dears.
I work with atmega16, in both side master and slave.
I want to send a numbr between 100-999 b that entered by keypad to the slave.
Numbers are 16 bit ,and spdr register is 8 bit, so i send first lsb then msb bits. This works well.
But my problem is in slave side:
I enabled interupt spie in slave side so each spdr recived from master tooke as a interupt and goes to ISR function. But becouse of my number i want to take each 16 bit or two byte as a interupt. What should i do???
Please help me. Thanks.
Aasshh
Aashkanpasha wrote:
What should i do???
volatile uint16_t SPI_received;
volatile bool  SPI_valid;
ISR(SPI_vect) {
    static bool low = false;
    if (!low) {
        SPI_received = (SPDR << 8);
        SPI_valid = false;
        low = true;
    else {
        SPI_received |= SPDR;
        SPI_valid = true;
        low = false;
This toggles between two states (low / !low). I'm assuming you send high byte then low byte each time. First time !low is true so it puts the reading into the upper 8 bits of SPI_received, marks the reading as not yet valid and then toggles to wait for the low byte. The second time "low "is true so this time it ORs the other 8 bits into the low half of SPI_Received and marks it as a valid, full 16 bit reading then toggles state again to wait for the next high byte.
(or something along these lines anyway)
Or split your value into two 7-bit values. Set the top bit high for the MSB and low for the LSB. You then have enough information to accurately reconstruct your data.
Or use the CS line to synchronise.  e.g.
CS_LO;   //active
spi(hi);
spi(lo);
CS_HI;   //release
