Split from: I/O problem with code
12 posts / 0 new
 Hi,how are you I have problem at90s2313 in simulation work and on circuit board not work how I can set this to work out.
 please guide me to set it. I use crystall and button to reset also nothing happend thanks
void main() {
ddrd=0x00;
    portd=0x0e;
    Portb=0;
    ddrb=0xff;
    while (1)
        if (pind.b0==1 && pind.b1==1&& pind.b2==0&&pind.b3==0&& pind.B4==0)
            Portb=0b00001011;
        Portb=0;
        if(pind.b0==1  && pind.b1==0&& pind.b2==0&&pind.b3==0&&pind.b4==0)
            portb=0b00000011;
            portb=0;
             if(pind.b0==1&&pind.b1==0 && pind.b2==1&&pind.b3==0&&pind.b4==0)
            portb=0b00000010;
            portb=0;
            if (pind.b0==1 && pind.b1==1&&pind.b2==1&&pind.b3==0&&pind.b4==0)
            portb=0b00000100;
            portb=0;
            if(pind.b3==1&&pind.b1==1&&pind.b2==0&&pind.b0==0&&pind.b4==0)
            portb=0b00011001;
            portb=0;
            if(pind.b3==1&&pind.b1==0&&pind.b2==0&&pind.b0==0&&pind.b4==0&&pind.B5==0)
            portb=0b00010001;
            portb=0;
            if(pind.b3==1&&pind.b2==0&&pind.b1==1&&pind.b0==0&&pind.b4==0&&pind.B5==0)
            portb=0b00010000;
            portb=0;
            if (pind.b3==1&&pind.b2==1&&pind.b1==1&&pind.b0==0&&pind.b4==0&&pind.B5==0)
            portb=0b00010000;
            portb=0;
ihope you find me bascom error221
Not much of a problem description, work/not work???
Tell what you expected the code to do, then what it is doing, and how you tested to come to your conclusion.
You also state it works (what ever that means) in simulation, but not on real hardware, so tell us about your real hardware, show a picture or a schematic.
Things we often see, are not all power pins are connected, no bypass caps (100nf) on all power/gnd pin pairs, etc, pictures and/or schematic will help with that.
stack gold/silver https://www.onegold.com/join/713...
Using all of those port compares is somewhat ridiculous and dangerous.  What if the port changes during the compares? That is probably not what you want.
Get the port first, then compare to that.
myport=portd;   //used for compares
// GCC supports 0b binary prefix
if ((myport & 0b00001111 )== 0b00001010)
    blah blah
if ((myport & 0b00001111) == 0b00000111)
or using hex:
if ((myport & 0x0F) == 0x0A)
    blah blah
if ((myport & 0x0F) == 0x07)
edit: corrected binary notation & parenthesis
avrcandies wrote:
if (myport & 0x00001111 == 0x00001010)
    blah blah
if (myport & 0x00001111 == 0x00000111)
I was going to suggest the OP learn to use hex and avoid the use of binary constants, it's just so easy to miscount the ones & zeros,
but then you used that incorrectly as well, or perhaps you have been working with a lot of 64 bit systems lately!  smiley
That's funny...took a few secs to see what was wrong, I was too busy poking through his code...will update
avrcandies wrote:
if (myport & 0x0F == 0x0A)
    blah blah
I've been doing C for some decades, and the precedence table isn't ingrained in my synapses.  So I find it easier to just use a set of parentheses and avoid the strain.
Hmmm-- do you see which operators are in levels 8 and 9?  Do you really want to present your code fragments as being "better"?
Had to check that myself (I doubt anyone memorizes the precedence table!):
int main()
    printf("%X\n", 0x0A & 0x0F == 0x0A);
    printf("%X\n", (0x0A & 0x0F) == 0x0A);
That's a very easily encountered "gotcha" I guess!
I momentarily thought about checking it, then thought nah...haste makes waste when you are trying to be quick.   I wonder how many variations of operator precedence there are amongst all the "common" languages.  There's sure to be a comparison chart somewhere.  I get students who go parenthesis crazy to the point where statements become unreadable.
Nothing crazy about using a NECESSARY pair, is there?  As I implied, if you were unsure why didn't you put them in, if nothing else to make the snippet clearer?
So, is everyone commenting on OP's coding style, or is there some causation that has been found?  For example, I found a causation in the "better" presented code fragment.
Not sure why portb=0 is scattered all over the place to make thing  harder to read....if it is none of the choices, then set portb=0.  Or it might be allowable to set it at the beginning, regardless & possibly be overriden by one of the choices.
As mentioned, you should read the ports once & make decisions off that reading, otherwise can get logically impossible results, if the port changes midstream.  Occasionally you may want it the other way, but it should be intentional.
wonderful description!
Personally I'd vote for:
void main() {
    uint8_t pins;
    ddrd=0x00;
    portd=0x0e;
    Portb=0;
    ddrb=0xff;
    while (1)
        pins = PIND & 0x3F;
        swithc(pins) {
            case 0b00011:
                PORTB = 0b00001011;
                break;
            case 0b00001:
                PORTB = 0b00000011;
                break;
            case 0b00101:
                PORTB = 0b00000010;
                break;
            case 0b00111:
                PORTB = 0b00000100;
                break;
            case 0b00011:
                PORTB = 0b00011001;
                break;
            case 0b000001:
                PORTB = 0b00010001;
                break;
            case 0b001110:
                PORTB = 0b00010000;
                break;
            case 0b001110:
                PORTB = 0b00010000;
                break;
            default:
                PORTB = 0;
which could well be wrong because the existing code is all over the place and very confused.
For example how can you have some states that consider pind.5 and some don't ??
I guess we need to create that Karnaugh map...
