FreeRtos for the ATXMEGA128A1
56 posts / 0 new
Pages
I am already referring to both of these, as I am using the IAR compiler and latest version of FreeRTOS. As said in  "yuriykulikov/FreeRTOS-on-XMEGA · GitHub", I only have to change the portable folder file.
After doing that, I am able to successfully compile the code. But while debugging(running), it crashes( i.e. restart again to main) from the vPortStart(just after portRESTORE_CONTEXT).
Can you help me out?I dont know the root cause why it is happening.(tell me if anythings i you required)
Thanks.
Shiv Pratap Singh
Likely no as I have zero experience with FreeRTOS.
Me neither.
Thanks for support.
I think I have found the reason(still in progress), it was because of the assembler file(which is required in IAR compiler not in other compilers) for FreeRTOS.
As it is working fine for the Atmel Studio ( i.e. same portable file).But let me check.
Shiv Pratap Singh
Pages
