AVR32UC3B and nand flash
12 posts / 0 new
Hi all,
I'm pretty new in the flash (nand flash) and I would like to know if it is possible to use a nand flash with an AVR32UCB3 CPU ?
I have no idea of what is necessery righ now. I thing we need to take a part with a nand fllash controller embedded ? or I need to put a nand flash controller between the CPU and the Flash ?
Can sombody can give me some hint on how it is possible to do it or if i'm totaly wrong with the nand flash on a UC3B parts ?
Dumarjo
You can use GPIO to bit-bang the NAND flash interface, UC3 devices has a CPU local bus with direct access to the GPIO registers.
AFAIK Atmel has a driver coming into the software framework in some time, even with software ECC.
Hans-Christian
Hi HCE,
Do you have an ETA for this ? We start 2 new design and we serious though using NAND flash with a AVR32UC3B256.
Is it possible to have an idea of what kind of device we should look at ?
Dumarjo
Samsung and Micron devices seems to be pretty strait forward to get to work, at least I have had success with both :)
Hans-Christian
is it possible to get a hand on sample code ?
do you know very aprox, a ETA that the nand flash driver will be in the FrameWork ?
regards
Dumarjo
Hi HCE,
What is the part number you use ? What is the interface you use ?
Dumarjo
I used UC3A1512 device, and the CPU local bus to drive the GPIO lines.
Hans-Christian
I talked to my FAE yesterday and he tell me that the UC3A have the Nand flash controller embedded. Is it on all UC3A device ?
And what is the part number of your Nand flash ?
Dumarjo
UC3A0 devices have EBI, so with two OR gates on the outside you can handle NAND flash attached to a chip select.
UC3A1 does not have EBI, here GPIO is your only solution.
I have also heard of a coming UC3A device, with EBI and hardware NAND flash support :)
I'm home right now, so will try to remember it tomorrow. But it was a Micron NAND flash with one CE, 2048 page size and 64k or 128k block size.
Hans-Christian
I see that atmel have release their new framework with gpio interface. I would like to know if someone have use id and which nand flash you have used.
regards
Jonathan
I've used Micron and Samsung flash devices, do not remember the part number, but they worked fine with the gpio NAND driver.
Hans-Christian
Dear Hans Christian,
I'm trying to interface a 64GB (Giga Byte) Nand IC using GPIO to AT32UC3A3128S. Since, the address space per chip select in EBI/SMC allows only interfacing upto 165 MB. So it is not possible to interface a 64/128 GB NAND Flash using this interface. Is there any way to bypass this limitation and interface Nand without any size limitation ?
So, as you said I'm planning to use GPIO to bitbang and interface a 64GB IC.(App note 32136) Can you confirm that I can choose this way to successfully interface NAND IC with any size 64/128 GB (parallel interface) ?
Thanks in advance.
