AVR Timer operation mode and timebase correlation
2 posts / 0 new
Dear all,
As we all know there are only 4 x Timers on ATmega 1284p MCU. Currently in my setup,  two of those 4 Timers are used for control of the 2 engines.
These engine control timers are running Phase Correct PWM, in 8bit mode.
The yellow highlighted mode is used for Engines.
Is there any chance to make a timebase from this already running timers, and not setup yet another Timer for a timebase.
Can I use the TCNT1 register to create a timebase which can then be used for time.
Thanks in advance
work in progress...
Sure, just enable the timer overflow interrupt and place your timing code there.
You should have a diagram like this in your DS:
This one is from the M328 DS, yours should be similar.
