AVR32UC3A Flash Writing Support
3 posts / 0 new
Hello all,
I need some help in writing and reading content to internal flash of AVR32UC3A3128S. Had seen official example (for EVK1104 and changed the device to UC3A3128S ) for flash writing using flashc driver, but unable to figure out how we can program a particular flash address/page.
In Flashc_example.c,  there is a structure nvram_data_t, used flashc_memset & flashc_memcpy functions to set (clear) and copy values respectively. (But I couldn't understand..  to what address (nvram_data_t) is mapped and writing operation is happening to)
Neverthless, I dumped the program and saw the memory window, after breaking the debugging. But couldn't see any written data to memory (Except for the magic number at start 0x80000000 & at user flash page)
I read similar posts in forum, but couldn't get what I'm searching for. Please help me in this regard.
Tilak.
I think the asf example puts the struct into the last page of flash in the .lds file - have a look there?
I the end its the usual: a page erase, write to the temp buffer, page commit.
If you have a simple use-case the datasheet might be a better place to look than asf...
@mraardvark,
Thanks a lot for your reply. I checked it... it does put content at the end of the flash. And I followed this App note.. through which I was able to place content at any flash address.
