status input pin shift in to a byte
7 posts / 0 new
hallo,
i think it is not a big problem, but i just don't see how to fix it.
i have 2 pins: 1 input and 1 output:
pinc3 = input serieel data comes in (90000 bits)
pinc4 = output clock pulse to synchronize
the speed is very slow something like 375 bytes/sec.
when 8 bits are in (a byte) i write it away in a externe RAM.
i like to do this with the shift instructions, so on the moment the clock = 1, i ask the status of pc3 (serieel in) and the result
i wanna gonna shit in to a byte.
but can i directly shift the status of a input pin in a byte, ore do i need a conversion ?
thanks in advance.
C or assembler?
byte<<=1;
If (pin)
byte|=1;
Do you want most significant bit first or leadt significant bit first?
The alternative being:
byte>>=1;
If (pin)
byte|=0x80;
its in C
if i'am correct:
byte<<=1  is the same as  byte=byte<<1
and
byte|=1  is the same as  byte=byte|1
so:
byte=byte<<1     // here the byte is shift 1 pos. to the left
if(pin)                 // here i gonna ask if the serieel pin = "1"
byte=byte|1       // if serieel pin = "1"  the "1" is gonna place at the LSB
but wat i have to do when the serieel input pin = "0" ?
trixo wrote:
its in C
if i'am correct:
and
so:
the first shift above (byte = byte<<1;) shifts in a zero so nothing else needs to happen, but...
if the pin ==1, then the (byte = byte|1;) changes the zero to a one!
stack gold/silver https://www.onegold.com/join/713...
ok, now i see it,....thanks for the answer.
