Keypad and lcd interface for numbers 0-999 ,help me
6 posts / 0 new
i try to write a code to input numbers by connecting a keypad and a lcd to atmega32 ic.i do it in atmel studio by c language. i initlize lcd and keypad.but i want limit operator only to enter numbers between 0-999. and i want if key# pressed one unit add to entered number and if * presses minus one unit entered number.my problem is i cant store entered numbers in a variable in my code. my code and my 3 question is marked below in code (01code???02code??03code??) please help me it is critical for my boss and my job:
How can i add my c code here??
To see my code and find a way to my problem what should i do?
Aasshh
Add C code by clicking the "<>" button. That opens a code window. Copy your code, then paste into that code window, and click OK button at the bottom of that window.
#include "main.h"
Thats all it takes.
It sounds like a concept you are missing is the conversion of (string) characters into numeric values. One way to do this is to use the  atoi() [string to integer] function from avr-libc. To access that, all you have to do is
#include <stdlib.h>
You can read about the function in the avr-libc documentation or in one of the many AS7 help files.
Hi dear
I use this site by my iphone and so there isnt any button like that you say.
No i know that you say. I can use itoa and libraries. My problem is anywhere else. In making a array by entered key. If i can send yoy my code i explain there.
Aasshh
how many keys does your keypad have? 10, 12, or 16?
Can you read the  keypad?  Can you display  numbers on the LCD?
Aashkanpasha wrote:
Hi dear I use this site by my iphone and so there isnt any button like that you say. No i know that you say. I can use itoa and libraries. My problem is anywhere else. In making a array by entered key. If i can send yoy my code i explain there.
surely you don't write the C code on an iPhone? Try accessing this site in a browser on the same PC where you write the code.
hi dear.thanks alot for your attention.
i have a project to interface a keypad and lcd by atmega32.
from morning untill now my all problems solved.
all the codes and all things are correect now  but only one problem.
i enter the number by keypad and lcd shows them, but after 2556 it show 1 again untill 512 then back to 1 again.
i get intiger numbers and  store in a variable named number and convert it to string by itoa function or sprintf  function (both have same result). why it is so???
please help me.thanks
void int2char(y){
	char str[5];
	sprintf(str,"%d",y);
	//itoa(y,str,10);
	alcd_puts(str);
number=t;
alcd_gotoxy(0,0);
alcd_puts(" Number:");
int2char(number);
state++;
break;
Aasshh
