Need help with pointers & memory address
7 posts / 0 new
Hi guys,
What data type is used to hold the memory address?
I want to store the memory address held in the pointer variable
How big is your memory?
Choose a type that can hold the maximum value
your question is vague!    memory address held in the pointer variable
WHAT pointer   ...WHAT VARIABLE?
Be more descriptive in your next post.
Concept of STACK Memory-CUSTOM*
#include <iostream>
using namespace std;
int main ()
    long int ad[5] ;   //Array to hold address.
    long int x[5] = {0};     //Array of 5 int variables. Consider it a STACK.
    long int *p;             //Declaration of pointer to an int value.
    p = x;              //Initialized the pointer to the first element of
                        //array or STACK.
    ad[0] = p;         //Initialized the first element to the first address
                        //of x array i.e. x[0].
    int val = 0;
/*-----------------Loop to fill the STACK----------------*/
    for (int i = 0; i < 5; i++){
    cout << "Enter Value: ";
    cin >> *p;          //Overwrite the contents of the address pointed by 'p'.
    cout << i <<". You Entered: " << *p <<"  " << p << "\n";    //With the input value also display the
        //the memory address of it.
    ad[i] = p;         //Address will be stored in add array.
    p++;                //Post increment the memory address.
/*-------------Loop for Resetting the pointer to first array or STACK element-----------*/
       p--;             //Decrement to the previous address.
/*----------------------Data Fetch---------------------*/
    cout << "Enter Ser. No. to Fetch: ";
    cin >> val;
    p = ad[val];
    cout << *p;
    return 0;
I have posted the program.
Secondly, the memory address of the variable, containing the entered value, consist of 6 hex digits, i.e. 24 bits.
What toolchain?  What hardware?
On AVR sizeof(ptr) is 2 so you don't need "long int" if you want to store them. It only needs to be uint16_t but why would you store them in an array of "Int" anyway? Why not an array of pointers and the compiler would pick the appropriate storage size anyway.
You generally want to just use pointers as clawson pointed out. If for some reason you do need to convert a pointer to an integer type you should use uintptr_t/intptr_t. The only use case I've come across for doing this is storing additional data in the unused bits of a pointer.
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
