fixed point support in avr-g++ compiler
6 posts / 0 new
Hello everybody :)
I have the following Problem:
I want to compile:
#include <stdfix.h>
int main() {
    accum x;
which I can do so using avr-gcc.
In my current project however I am using the avr-g++ compiler. It seems that fixed point support is not included in the c++ compiler?
I get:
avr-g++ -g -Os -DF_CPU=16000000 -mmcu=atmega328p -c main.c
In file included from /usr/local/lib/gcc/avr/6.5.0/include/stdfix.h:36:0,
                 from main.c:1:
main.c: In function 'int main()':
main.c:5:5: error: '_Accum' was not declared in this scope
     accum x;
I tried this with the avr-gcc versions 9.1 and 6.5. I compiled these myself with the --enable-fixed-point option during the configuration (../configure --target=avr --enable-languages=c,c++ --enable-fixed-point --disable-nls --disable-libssp --with-dwarf2).
Did any of you experience the same issue?
Kind regards
Christian
It is only available in C, not in C++.
...I see.
I guess one needs quite a lot of experience to port this to the c++ compiler?
Why not write the fixed stuff in C and the rest in C++ then? You just need extern "C" to access the C functions from C++
Yes I already thought about this as an option. Porting it to the C++ compiler would only make it a bit more conveniant and avoid casts between the modules. But for now I decided to use „extern“ C functions. Thank you all for your replies.
Possibly in C++23.
Composition of Arithmetic Types
via
2019-07 Cologne ISO C++ Committee Trip Report — 🚀 The C++20 Eagle has Landed 🚀 (C++20 Committee Draft shipped; Contracts Moved From C++20 to a Study Group; `std::format` in C++20; C++20 Synchronization Library) : cpp
Library Evolution Working Group Incubator (LEWGI) Progress
GitHub - johnmcfarlane/cnl: A Compositional Numeric Library for C++
via
The Embedded Muse 361 - Tools and Tips
Readers contributed ideas about fixed-point math last issue, and John Lagerquist had some thoughts:
