Graphic LCDs
13 posts / 0 new
HELLO everyone
I wanted to know how can I display on a graphical LCD such as PCD8544(Nokia 5110) with a atmega micro controller via code visin AVR.
These displays are like from well over 10 years ago! Old skool!
have you tried Googling PCD8544 Codevision?
[edit] I did - look what I found!
http://www.hpinfotech.ro/cvavr-e...
In the future - just about anything that you want to do has probably been done before - many times. Try Google first.
Codevision comes with examples for PCD8544.   The "Simple_Demo" will build and run on a Mega.   (just edit the the Project Configure)
You can use the CodeWizard to initialise a new Project.   And the regular glcd.h library.
Ask if you need help.   Note that most graphics projects will exceed the Flash size for the Evaluation CV.
Thank you
actually you'r right I should have been searching it on the internet.
thanks for the link.
SparkFun have example code for them:
https://www.sparkfun.com/products/10168
... and even the humble Arduino can work with the Nokia 5110.
https://create.arduino.cc/projec...
Speaking of graphical LCDs, I've never used one (but done plenty of PC graphics).  What are a few modern and available displays I should look at if I wanted to get my hands dirty?
Probably just Google "Arduino graphic lcd shield" to see "current options"
EDIT: Actually, now I try that, I have a feeling "OLED" rather than "LCD" may lead to "cooler" displays!
OK, thanks.
TFT are the common ones I find cost effective as they are usually 3 inches diagonal, color, and most have a touchscreen in them.
Thanks.  In simple terms, how are they typically driven?  SPI?  Special chip?  Some form of parallel?
Depends on the Screen/shield, but SPI and parallel are the most common I find.   I2C is too slow of course.
Do yourself a favor and stop using the Nokia 5110 screen.  The contrast of the dark pixels against the background depends on how the metal cover is attached to the main PCB.  And this metal cover is simply twisted in place using cheap little metal tabs.  In other words, the Nokia 5110 is cheap but it really sucks for dependable quality.  And its resolution is only 84 x 48 pixels.   It has only three advantages:  it's really cheap; it uses very little power as long as the backlight is off; and it is found in all the university computer/electronics labs throughout the world, where professors have been assigning students to make a little "Hello, world!" demo programs on it for the past 10-15 years.
I recommend the OLED SSD1306{monochrome 128x64 at about $2-3 each} or the 128x160 ST7735 color display at about $4 each: https://www.ebay.com/itm/1-44-Co...
