Going Retro
13 posts / 0 new
It's been a while since I've been confronted with something like this...
..a fun little kit...
...first spotted here...
https://hackaday.io/project/1599...
...and bought from here...
https://shop.mcjohn.it/en/diy-ki...
Just need an 8" floppy interface & drive & I can use some of my files again....
Or maybe they were modern 5 1/4 types
Remember, use a hole punch to punch a write notch in the other side and you can use both sides of the floppy!
Do they come with OS images, or did you have to scrounge that up separately?
No, the kit came with a uSD card with loads of stuff on it. There's also a PC utility which can transfer stuff onto the 16 virtual floppies on the uSD, each of which holds 8Mbytes.
It's a cool design.  I designed the PCB for v1 of the project (https://hackaday.io/project/19000-a-4-4ics-z80-homemade-computer-on-breadboard), and did the Forth Port ("Just Because")  They won some prize money and went on to make the improved v2, so now I'm stuck with orphans - But I'm not quite motivated to build more.
I think the basic operation is very clever - doing an IO access (or some memory accesses?) trips a wait-state-inducing flipflop, and then the AVR32 goes and manipulates to bus "at its leisure."  I've been thinking that you could do the same thing with other old-school architectures (6502, 6809, ...)
The likes of a Cortex M3/4 with enough ram does a good emulation in only 1 chip! For the sdcard interface, i used fatfs and mapped the cp/m disks as files. Do a fseek to goto the relative sector then read/write 128 bytes. No clunk of the head load solenoid though.
Emulating the CPU isn't "retro" enough, but emulating the IO is OK.
It’s a fine line! Using modern memory devices is ‘ok’ as long as it is DIP package!
Cool find!
I met with this guy recently:
https://thehighnibble.com/imsai8080/#overview
I liked the web emulation of the Cromemco Dazzler board.
Kartman wrote:
I met with this guy recently: https://thehighnibble.com/imsai8... I liked the web emulation of the Cromemco Dazzler board.
I always wanted to get a few "Microangelo" boards for my S100 computer.
Well, I'm building the retro processor and simulating the memory... just call me awkward :)
Neil
