TWI Slave problems
6 posts / 0 new
Hi Guys
I've been making steady process on my AVR slave implementation but I'm having a few issues while testing
Setup
Atmega328p as slave writing to a display via SPI
Arduino Uno as master using wire library
Cable length 4"
Pull up resistors (4.7k) installed on both lines
Issue
The master is sending an 8 byte sequence 4 times repeatedly to the slave.
If I put in a delay(1) after each 'end transmission', it works fine.  If I don't, some sequences appear to the 'lost'
The slave is interrupt driven, a section of the ISR is as below
ISR(TWI_vect)
	switch(TW_STATUS)
		case TW_START:
			break;
		case TW_SR_STOP:
			if(TW_BuffPtr != -1) //there's data in the buffer
				TW_RxProcBuffer(); // Process recieved data
			TWCR = (1<<TWIE) | (1<<TWINT) | (1<<TWEA) | (1<<TWEN);
			break;
		case TW_SR_DATA_ACK:
		        // received data from master, call the receive callback
		        TW_recv(TWDR); // Process byte and put it in receive buffer
		    break;
My understanding that until the following is set, communication is paused while I process the data following a stop condition
Am I missing something?
regards
All that I can find in the datasheet is that the clock line is held low (pausing the TWI master)
after the slave recognizes its address when the uC is in sleep mode.
Thank you,
I wonder if this is not an TWI issue at all. (I'll fire up a logic analyser to confirm).  It may be the displays.  The slave is talking to 4 MAX7219 chips and I wonder if I'm refreshing too fast for the data to propagate.  The specs shows the MAX has a ~2ms data to display time.  Some of the Arduino examples suggest a 100ms delay before refresh.  This might explain what I thought was a buffer over Write condition.  Perhaps a 10ms delay after a display refresh might do the trick.
regards
Have you looked at Atmel app note AVR311?
Good find!
On page 5
As long as the TWINT Flag is set, the SCL line is held low. This allows the application software to
complete its tasks before allowing the TWI transmission to continue.
I have indeed, but it didn't help me though.  Firing up the protocol analyser showed that the slave was sending a NACK at times when being addressed with a write operation.
I'm processing the write registers with SPI writes to a number of MAX7219's which can take some time.  When I received a STOP from the master I was processing the buffer and then sending the following
Sending the above before processing cleared up the issue. (still testing)
I also found that the case of a BUS_ERRROR  the following from the app note didn't seem to clear it.
TWCR =   (1<<TWSTO)|(1<<TWINT); //Recover from TWI_BUS_ERROR, this will release the SDA and SCL pins thus enabling other devices to use the bus
but this did, though I have no Idea why
TWCR = 0;
Anyway, thanks for all the help Guys, much appreciated.
regards
Tiny video of an UNO talking TWI to a 328P as fast as it can to a 32 digit display
