CodeVisionAVR Fuses programming and structures
10 posts / 0 new
Hello everybody!
I want to know how to read fuse bits in codevisionAVR (need to know, what config is using). Read some topics, but all of this is uncompatible to CV.
And another question is what is the structure like "PORTD.0"? And where can I get file with definition of this structure?
Thank you for answers.
It's not a "structure" - it's a compiler extension.
The closest you can get in "normal" C using bitfields in structures is something like PORTD.b0 but CV simplifies this syntax using an internal type.
knyazoleg wrote:
I want to know how to read fuse bits in codevisionAVR...
Tools > Chip Programmer > Read > Fuses
It is kind of a chicken-and-the-egg question, and more information is needed for a full answer.  So tell AVR model and CV version if you want to get pedantic.  In particular, how did you get to this point?  You'd think you would know the fuse settings on your own app.
-- If the chip is locked, you may not be able to get a good read of the fuses without a chip-erase.  (that part is hazy in memory)
-- If you are accessing through Serial Program Downloading, then you will not be successful if SPIEN is in the wrong state.
-- There can be other causes for not being able to do a successful Serial Program Downloading session, and all would apply here.  SPI devices attached that interfere.  No clock source.  Too fast.
To use CV's built-in chip programming subsystem, then Brain [edit] Brian outlined the menu operations:
But you can use any AVR-capable tool that you deemed not applicable.
Thank you very much! Understood and remembered this point
ATmega8, CV 3.12
https://www.avrfreaks.net/forum/reading-fuse-bits-application-flash
Your answer is best for me, but it doesn't work in this CV (and I wanna know why).
I need it, because I have task: set delay (by timer) depending on system clock and multipliers. I could know system clock reading fuse bits (especially LOW ones)
knyazoleg wrote:
ATmega8, CV 3.12
WTF??
Did you try:
EDIT:
CodeVision Version 3.10:
What make/model programmer are you using?
IF this is a BRAND NEW program>>written by you<<, AND the AVR is brand new out of the tube, then the datasheet will tell you the fuse settings.  The clock for a Mega8 out of the tube is Internal RC, 1MHz, Brown out detect @2.7v, start up 6CK cycles.
IT's in the datasheet:
https://ww1.microchip.com/downlo...
Page 51.
Good luck.
JIm
I know about that bits. I know about algorithm too. But I need read these bits during execution.
So I need algorithm. And I've read datasheet for Atmega, found it. But I cant realize it in CodeAVR. Only errors or wrong addresses to Z-pointer
Some later AVR can read fuse bits from code, some are even able to set lock bits but if you mean you want to change a running AVRs fuses it can't be done. They are "fuses", you 'blow' them when you program the AVR.
Ah, I see. So have you tried the code in post #3 of the topic you linked to? What happens?
