$1 MCU review — looking for AVR part suggestions
180 posts / 0 new
Pages
Paulvdh wrote:
Some time ago I dipped a part of my littlest pinky toe in the ARM world. (STM32F103C8T6)
It's a 32 bit processor but the I/O structure (timers, etc) is apparently mostly 16 bit.
That's one of my pet peeves with some ARMs. I cannot see the sense in a 32b MCU, with 16b Timers ?
Some 8b MCUs even allow Timer cascade to 32b, such is the demand for the better dynamic range/precision.
NXP 'gets this' & have (IIRC) 32b timers and 32b prescalers, and Nuvoton are close, with 24b timers.
Paulvdh wrote:
Ah, so that is the "steering" part.
Triggers a memory about a story floating on (or sunk deep into) the 'net.
It was about a uC occasionallly losing bits in it's I/O configuration registers. The whole uC (or FPGA?) kept running happily, just some outputs stopped outputting the right signals untill the uC got a hardware reset. Then it worked all perfectly for a while, so no hardware pins blown, but the problem kept recurring.
The likely culprit was probably marginal decoupling / emc design, whatever but investigating and PCB revisions take time.
So as a (temporary) solution they put the whole I/O configuration in flash and used a periodic interrupt to rewrite it to the I/O ports.
That's more common than you realize, and is somewhat standard ESD hardening. Always a good idea to 'refresh the config', where practical.
Worse was the part where we found Reset was more of a 'Reset Request', and it could disable under ESD stress tests - outcome was a Power Removal watchdog design, that I'm surprised is not seen much.
Total votes: 2
In case anyone was wondering if I ever got around to finishing this write-up, the answer is "Yes! Finally!"
Check out The Amazing $1 Microcontroller on my blog.
It took several months of on- and off-again work, but I got through all 21 parts I selected.
I'd like to thank everyone on this thread for their help --- I got steered in the right direction toward the new tinyAVR 1-Series (which pulled in some impressive performance), and I also got some suggestions for other parts that ended up getting included, too.
If there are things you think need to be mentioned that I'm forgetting, please drop a line on this thread (or, shamelessly plugging my blog, as a comment on this post smiley)
Thanks again for the wonderful discussions!
Wow ... and that's from only a skim.
Plan is to put a comment onto that web page "soon"
Thanks for the follow-up.
Jay, a stunning roundup of the chips and the oft ignored tools. This must have taken you some time. I'm glad you investigated some of the more obscure parts that, whilst I'd heard of, have never really appeared on my radar.
A couple of comments - the PIC16 series aren't RISC - they are accumulator based, not single cycle and not load/store. Microchip grabbed the moniker and repurposed it for their own ends.
One thing I found missing was the voltage range of the various devices - the M051 and XMC1100 for example are 5 volt parts which for ARM ('arm') based parts sorta sets them apart.
As for using Arduino shields, I have used the prototype ones ( the ones with lots of holes) to build up some test hardware for the XMC1100 and STM32 parts. I've even used used one with a small solderless breadboard on top for some quick prototyping.
Great work.
Thanks for the comment --- RISC is a loaded term (as you can imagine), so I've added additional clarity to explain that while it is RISC in the sense that each instruction is precisely one word long and executes in a single cycle (unlike CISC parts like the 8051), it is *also* an accumulator-based architecture, which is quite different than most RISC parts. I hope you think this change makes the information more useful.
Just thought I'd let you know: Your navigation pane does not behave well on smallish screens. The bottom of it is off the screen and it is not scroll'able. Only if I zoom out to about 70% can I see the whole navigation pane. At 100% the last visible entry is "Dev Tools".
Chromium Version 59.0.3071.109 , display is 1366 x 768.
Good call — I will fix this as soon as traffic calms down (I can't even get a login page).
EDIT: No quick fix, other than removing content, unfortunately. I'll look at some core CSS changes I can make long-term to shrink that down, but there's a lot of dependencies I'll have to work through. Sorry about the inconvenience!
By the way, for people who tried visiting earlier and got 503'd, I've made some changes to my network configuration, and I think the site should be back up for most users.
I'll save you the scrolling: https://jaycarlson.net/microcont...
This is a superb reviewyes. Thanks for keeping us posted.
It's amazing what you get for < $1 these days.
I will say one error in the notes is that the AVR have a flat ISR, the new tiny's (tiny1616 was the one you picked), have a two level.
Now since it a relativ new chip I'm not sure if the Compiler support it.
And then it's not clear when you run 10MHz and when 20MHz on the AVR, (And find it a bit funny that you have to trick your 5V device to run 3.3V :D )
I don'e see that you have a 3v3 volt rule.
Comments
AVR
1. "And interrupts are one of the weak points of the AVR core: there’s only one interrupt priority, ..."
   tinyAVR 1-series has two interrupt priority levels (datasheet, CPUINT)
2. like megaAVR, tinyAVR 1-series is Harvard architecture but with unified memory (datasheet, Memories, Memory Map)
3. tinyAVR 1-series UPDI is more capable than megaAVR debugWIRE
Parametric Reach
megaAVR
XMEGA AVR are a follow-on to some megaAVR.
ATmega2561   - 16MHz, 64 pins, 256KB,  8KB
ATxmega384C3 - 32MHz, 64 pins, 384KB, 32KB
ATmega1280    - 16MHz, 100 pins, 128KB, 8KB + 56KB on EBI
ATxmega128A1U - 32MHz, 100 pins, 128KB, 8KB + 16MB on EBI
Atmel Studio
"The excellent IntelliSense engine that Microsoft spent years perfecting has been replaced by some sort of Atmel-proprietary “Visual Assist” technology that ..."
1. IntelliSense and AVR is available from third party(ies)
2. Visual Assist from Whole Tomato Software
Microchip Customizations
"As these compilers [XC] are quite expensive and ..."
About 1USD/day though the dongle is 1495USD
Discussion
megaAVR
"While the megaAVR has a perplexing debugging experience that requires two completely different interfaces and protocols to work with the part, ..."
fyi, once debugWIRE is enabled then stay with it until done.
"... low-cost, open-source programmers (which don’t support the UPDI interface)."
pyupdi is Python UPDI programming via an inexpensive USB UART; debug via UPDI is currently only Atmel-ICE or Power Debugger
PIC32
"... expensive compilers ..."
Can chipKIT PIC32 GCC be invoked from MPLAB X?
Thank you!
Notes
1. IntelliSense with most AVR is available from VisualGDB
2. IntelliSense is in Visual Studio Code and AVR might be available via the Native Debug extension
3. The next release of PlatformIO may restore AVR debugging; Visual Studio(s) are some of the IDE that integrate PlatformIO
4. LLVM AVR may be a current or future alternate to AVR GCC
5. ATmega328PB is approaching 1USD each for 100 though it has a supply and demand problem that's easing 17Q4 (should be resolved 18Q1)
6. 32KB tinyAVR 1-series is likely for '18 and probably under the price limit
Ref.
VisualGDB, https://visualgdb.com/tutorials/...
Visual Studio Code, https://code.visualstudio.com/
Native Debug, https://marketplace.visualstudio...
PlatformIO, AVR, http://platformio.org/platforms/...
PlatformIO for Visual Studio Code, https://marketplace.visualstudio...
Whole Tomato Software, https://www.wholetomato.com/defa...
XC8 PRO subscription, http://www.microchip.com/Develop...
Featured MPLAB XC Compiler Licenses, http://new.microchipdirect.com/p...
LLVM, Changes to the AVR Target, http://releases.llvm.org/5.0.0/d...
Python UPDI driver for programming "new" tinyAVR devices, https://github.com/mraardvark/py...
chipKIT, http://chipkit.net/
Wow! That's a very impressive write-up.
There seems to be an inconsistency between the chart and your writing.
You wrote:
Unfortunately, the STC8 simply does not care about power consumption — so it barrels along at 1.62 mA (still not the worst part in this round-up — not by a long shot).
However, the chart shows that the STC8 consumed 5470 microamps in your test. It was the STM8 that consumed 1620 microamps (1.62 mA).
There's also a few typos, such as "sense" in the sentence "but has sense expanded" (should be "since") and "faired" (should be "fared").
Besides those, I didn't see any other issues.
 All things considered, I much prefer the AVR "one priority but lots of vectors (separate vectors for uart rx and tx, even!)" over something like the PIC "two priorities = two vectors" scheme.  Or even the 68k "7 priorities with one vector per priority."
I see that Jack Ganssle has linked to the survey in his latest newsletter...
Many readers sent this link, which explores 21 different microcontrollers, pondering the strengths and weaknesses of each. Some vendors will not be pleased...
McuOnEclipse has also linked to it.
https://mcuoneclipse.com/
Just saw an announcement, yesterday (Nov 21, 2017) for a 0.25 USD MSP430. Did not note details except  that one of the proposed uses is an RS-232 to RS-232 "bridge".
commonly known as a "piece of wire" ?
It's a chip with 0.5kB of FRAM program memory, and ... more peripherals and RAM (also 512b) than you'd expect to see on a chip with that little memory.  (Essentially, I guess you get to get to do a "little bit of stuff" with "your choice" of one or two peripherals.)  An interesting strategy?  (Also, TI seems to be following through with their "FRAM is the way" opinions.  Also interesting.)  256 instructions is ... not much.
Really?  I only one serial thing ("eUSCI")...
Electronic Design
Electronic Design
25 Functions in a 25-Cent Micro
Texas Instruments’ value-line MSP430 16-bit micro costs only 25 cents and comes with 25 preconfigured apps.
by William Wong
Nov 20, 2017
http://www.electronicdesign.com/embedded-revolution/25-functions-25-cent-micro
1. The MSP430FR2100 is the top end of the family. It adds the 8-channel, 10-bit SAR ADC with 1.5-V reference and temperature sensor.
https://www.mouser.com/Search/Refine.aspx?Keyword=MSP430FR2100
MSP430FR2100
 The new chips are the FR20xx, even smaller and cheaper than the 21xx series.  Alas, like many of the chips advertised as meeting a particular price point, the "small quantity" price isn't that great.  Lots of chips are similarly priced, including a bunch of the new AVRtinys.
Ahh.  one hardware UART, one SW uart using timer interrupts.  "half dupex."
The "25 functions" is apparently a set of build-able, app-notes with downloadable code, designed to be "easily customizable."  They have a fancy "flipbook" in annoying format (heh.  Rather like the old Microchip "tips&Tricks"?)
jaycarlson wrote:
... EFM8UB1 ...
EFM8UB3 is a new arrival at Mouser at 0.98USD each for 100.
Mouser Electronics
Silicon Labs EFM8 8-Bit MCUs
EFM8UB tab
https://www.mouser.com/new/Silicon-Laboratories/silabs-efm8-mcus/#tabs-4
Now Available: Silicon Labs EFM8UB3 Universal Bee 8-bit Microcontroller offers an innovative energy-smart USB peripheral interface, ideal for USB Type-C applications.
Jay selected an MCU in the context of education of embedded system designers.
How I Teach Embedded Systems - Jay Carlson
July 26, 2019
(mid-page)
REVISING THE LAB KITS
[next section]
I selected the PIC16F18446 + MPLAB Snap debugger.
Wow.  Paraphrasing: "Arduino makes things too easy and obscures what I'm trying to teach, but most modern chips are too complicated (especially the initialization that has to be done before you start.)"  He does an OK job justifying his choice, but it's such a "legacy" architecture...
Other MCUs often don’t have dev environments for macOS or Linux. [and the school doesn't require students to have PCs.]
That's sort-of fair.   I wonder if another year will improve AVR's standing (also supported by MPLAB-X these days.  Almost.)  And PlatformIO/VSCode is all free...
I tend to believe that a microcontroller class should introduce a second, different CPU architecture.   Because "compare and contrast" teaches you a lot.
I strongly agree, and an "opposite extreme" architecture, to the extent possible.
westfw wrote:
... but it's such a "legacy" architecture...
Some problems are I/O bound, memory bound, or power bound instead of compute bound.
Microchip's PIC team continued on to add DMA and such; Microchip's compiler team added the second stack for some PIC and bumped up (Clang and C99 in MPLAB XC8 v2 for PIC)
PIC32 in one other curricula though not an equivalent to Jay's course plans (long live MIPS, another legacy that has improved in 34 years)
westfw wrote:
...  Almost.)
IIRC, MPLAB X v5.25 is imminent though may take awhile for the ones at Microchip to verify each AVR.
PlatformIO's (primary) AVR debugger issue is pending though don't know when it'll be solved.
Microsoft Visual Studio Code has GDB and EDBG by extensions.
My experience is yes for mid-80s, no for mid-90s.
How much weight in one's rucksack?  (maybe 140 semester-hours on an undergraduate's ECE degree plan)
That's my experience in a computer architecture course though was one architecture (MIPS) for labs and such.
Arm recently re-adjusted some of their licenses (models, price, IIRC the royalty is effective on exceeding a volume limit)
Near a stew (Arm, MIPS Open, RISC-V)
PIC16F18446 - 8-bit Microcontrollers
5 tubes of PDIP, of 22 each, has a total price of 151USD from MicrochipDIRECT.
PIC18F24K42 - 8-bit Microcontrollers
7 tubes of PDIP (15 each) is 154USD.
PIC18F45K42 - 8-bit Microcontrollers (in 40 pin PDIP)
10 tubes of PDIP-40 (10 each) is 178USD.
ECE 4760 (Cornell University, Electrical and Computer Engineering)
New PIC32CX and PIC32CZ? | AVR Freaks
Packages | Atmel AVR · Platforms · PlatformIO
PIO Unified Debugger for AVR · Issue #95 · platformio/platform-atmelavr · GitHub
Debug probe support for atmel-ice / dragon and atmega328p processor · Issue #53 · platformio/platform-atmelavr · GitHub (AVaRICE)
Packages | Microchip PIC32 · Platforms · PlatformIO
https://www.avrfreaks.net/forum/avr-studio-mac-linux#comment-1848031 (Microsoft Visual Studio Code, GDB, further for EDBG)
Arm reveals new licensing strategy as RISC-V makes waves
https://www.microchipdirect.com/product/ATMEGA4809?keywords=atmega4809-PF (184USD for 10 tubes of PDIP-40 at 10 each)
edit :
Release 1.15.0 · platformio/platform-atmelavr · GitHub
New boards: ...
ATmega1284P — PlatformIO 4.0.1b3 documentation
mega1284 in PDIP-40 is popular.
Ah.  I misspoke, slightly.  In the mid-80s I would have compared "cpus."   Now, I'd compare microcontrollers more at the chip level: "we've studied the PIC16 for a while, now let's see what a PIC32 looks like.  Look at the huge address space!  Look how they've used that to allow LOTS of registers for the peripherals!  Look how everything is treated as memory."  Any 8bit CPU vs any 32bit CPU should be "interesting."  (well, perhaps not x86 or those Renesas super-Z80s.)
[only] 140 semester-hours [in a class]
I dunno.  My (late 70s) Assembly Language class was mostly IBM360, but spent a short time on the PDP11 (2 weeks of a semester-long class?  One assignment, using a simulator, looking at the results in memory).  I think it was still useful...
The UTexas Online Microcontroller class bypassed the initialization complexity (of TI Tiva ARM CM3) by using instructor-provided initialization code and "starter projects."  That worked OK, I think.  We never did learn how to set up a project from scratch.  (and they used Keil - Windows Only...)
westfw wrote:
... or those Renesas super-Z80s.)
fyi, there's a Renesas instance of IAR EWARM though it's not a match for Jay's course criteria (IAR EW is Windows only)
Am aware of Zilog (Littelfuse) for super-Z80 though am unaware of Renesas super-Z80.
westfw wrote:
 My (late 70s) Assembly Language class was mostly IBM360, ...
Likewise early 80s
westfw wrote:
... but spent a short time on the PDP11
Didn't work some on a DEC PDP-11/34 until early 80s though more so mid-80s.
Project's systems engineer said could replace the rack mount "old" PDP-11 with that new IBM PC/AT; nowadays it's Intel NUC form PC on a DIN-rail within the small cabinet that one rolls around.
westfw wrote:
The UTexas Online Microcontroller class bypassed the initialization complexity (of TI Tiva ARM CM3) ...
a guess at the URL
Embedded Systems - Shape The World (University of Texas at Austin, ECE, Jonathan W. Valvano)
IAR Embedded Workbench® for Renesas Synergy™ via The Embedded Muse 365 | This Week's Cool Product
edit :
YSTBS5D5E10 Development Kit - Renesas | Mouser
Printf-style EFM8 trace messages using a C2 debugger connection - Jay Carlson
July 16, 2017
IMPLEMENTATION
  • The debugger periodically polls the flag [number of bytes to read] until it is non-zero. When it is, it reads that number of bytes, resets flag to zero, formats the data it read as an ASCII string, and displays it.
IDA was used to decompile slab8051.dll into a C file, which made it easy to identify the parameters of each method, and how the functions interacted with the target.
CAVEATS
[20ms polling duration, can't connect to running target, interrupts briefly pause]
[source code for EFM8 and Windows]
FUTURE WORK
I haven’t investigated debuggers for other 8-bit MCUs like the PIC, AVR, or STM8, but if they have a publicly-available API that allows you to read and write to memory, I’d imagine you’d be able to do the same thing.
Memory Read | Embedded Debugger-Based Tools Protocols User's Guide (EDBG)
https://github.com/mraardvark/pyedbglib/blob/master/pyedbglib/protocols/avr8protocol.py#L259 (memory_read)
PDI/UPDI is in-parallel with the CPU arbitrated by BUS Matrix (XMEGA and subsequent AVR architectures [AVRxm, AVRxt])
The documented PDI/UPDI instructions are in the data sheet (read, write, etc)
Some PIC have a form of trace :
User Instrumented Trace - Developer Help
Pages
