Trouble translating Assembler directives (Atmel -> GNU)
5 posts / 0 new
Hi all,
Noob here, learning Assembly.
I'm trying to use code ROM data storage on an ATmega328p (Arduino) but I can't get it to work.
This is what I have so far:
#define __SFR_OFFSET    0
.equ    RAM_BUF,    0x0140              ; The SRAM location the string needs to be moved to.
; Initialisation
        ldi     ZH,     hi8(STRING)
        ldi     ZL,     lo8(STRING)
        ldi     XH,     hi8(RAM_BUF)
        ldi     XL,     lo8(RAM_BUF)
; Main program
LOOP:   lpm     r20,    Z+
        cpi     r20,    0
        breq    STOP
        st      X+,     r20
        rjmp    LOOP
STOP:   rjmp    STOP
; Fixed data storage
.data
STRING: .asciz  "Hello, World!\n"
The code compiles without error, but the string never gets loaded. Instead R20 gets the value 0xFF every time and thus the LOOP never ends as well.
I am following the Mazidi book "AVR in assembly and C" so only have Atmel assembly code as examples.
The GNU-AS manual is very terse about directives and my Google Fu is failing me.
For what its worth, I tried setting the Z register with
        ldi     ZH,     hi8(STRING << 1)
But that produces Error: invalid operands (.data and *ABS* sections) for `<<'
Can anyone point me in the direction of resources for translating Atmel directives to GNU?
Thanks!
I'm trying to use code ROM data storage on an ATmega328p ...
.data
".data" is explicitly a RAM section.  if you want the string to be in flash, leave that line out (or explicitly use a flash section like ".section .progmem")
You need to mult all the LPM addresses by 2, such as
hi8(STRING*2)
  ldi     ZL,     lo8(STRING*2)
That explains it!
One thing you can do (easliy) in avr-as that is not so simple in Atmel Asm is simply make use of C's _do_copy_data() so if you have the RAM for it you can just have the data copied out to RAM anyway. In fact it's easiest just to add a .c file to the project:
char text[] = "Hello world";
and the default action of this is that the data "Hello world" is copied out to a RAM location labelled "text:" anyway. Then you just LD from that.
But a bit like PROGMEM/_flash in C, if the strings are "const" it may be better to keep them in flash alone. Of course you can use C for that too:
const __flash char text[] = "Hello world";
then "text:" (*2) could be loaded into Z and LPM'd
Thanks for your answers!
Just leaving the ".data" line out fixed it (at least for simple examples like this).
Must have overlooked the RAM bit in the docs I read.
@avrcandles: the first half of the book is Assembly only and the second half compares Assembly with C. They are not combined in this book smiley
@clawson: I think I will stick to learning the basics for now, already challenging enough lol
