date coding executables
4 posts / 0 new
Hi
when I run make (external makefile) in avr studio i want the target to have the date in the filename, so i get something like targetname04072007.hex
I know there is a windows environment variable called %date%, but how to incorporate it into gnu makefile?
Does anyone know if this can be done?
thanks in advance for any help
rob carter
I just have something like this in the .c source:
const uint8_t help[] PROGMEM = {
"Program version "__DATE__" "__TIME__"\r\n\n\
1 - toggle LED1\r\n\
2 - toggle LED2\r\n\
3 - toggle LED3\r\n\
Then when I display this help menu it has the date/time embedded and in the hex/binary I also have it embedded:
:1000F0006865723E200050726F6772616D20766590
:100100007273696F6E204D61722020322032303060
:10011000372031353A31373A35340D0A0A31202D3E
etc...
(one thing I did do in the makefile was have it always 'touch' the .c file that this __DATE__ and __TIME__ is included in to ensure that file was always recompiled and a new date/time version embedded)
In *nix systems, environment variables can be directly referenced in makefiles, so you can easily construct a name if you have an environment variable that already has a correctly formatted piece of the name that you want. I presume that it is the same for gnu make in Windows, but I only boot Windows once every 6 weeks or so, and never to development there any more, so I'll have to point you at the make documentation.
If make regards date as an environment variable,
you can use targetname$(date).hex as your file name.
If not, do something like this first:
date=$(shell date_emitter)
BTW when I want the link time in the executable,
my link sequence recompiles a file named linktime.c
before invoking avr-gcc to link.
That way, I get a fresh copy of linktime.o
without making linktime.c artificially newer.
