Version string?
10 posts / 0 new
I'm working on an project, in one of the source code headers the sw version number is defined in two places, once as a set of defines and in another as a const char string.
I not sure how to have the compiler build the string at compile time so I only have to maintain the version in one place.
Currently I have this in the header:
    #define SW_VERSION_MAJOR        1
    #define SW_VERSION_MINOR        1
    #define SW_VERSION_MAINTENANCE  2
    const char var_firmware_rev[] = "1.1.1";
As you can see the two don't match, is there a way to build the var_firmware_rev[] string from the defined values above?
I'm not looking for a run time solution such as sprinf() as ram is tight on this system, prefer it to be built at compile time and saved in flash(const).
TIA
The word is "stringify" ;-)
Something like this should do it
#define STRINGIFY(x) STRINGIFY_(x)
#define STRINGIFY_(x) #x
const char var_firmware_rev[] = STRINGIFY(SW_VERSION_MAJOR) "."
                                STRINGIFY(SW_VERSION_MINOR) "."
                                STRINGIFY(SW_VERSION_MAINTENANCE);
You need the 2 stage STRINGIFY and STRINGIFY_  (or whatever you want to call them) function like macros.
This also uses string concatenation ie. "1"  "."  "1" is concatenated by compiler to "1.1"
Indeed. SO has this:
https://stackoverflow.com/questions/5459868/concatenate-int-to-string-using-c-preprocessor
That's pretty much identical to MrKendo's suggestion. The key thing in all that is the "#x" which is the preprocessor's "stringify" operation.
Thanks guys!  Much appreciated smiley
PS a completely different approach for "version" is simply to build a string using the preprocessor __DATE__ and __TIME__ so it gets a version based on when you built it.
(I prefer this - it's too easy to forget to update major/minor/rev while the DATE and TIME auto update)
Going back to the version string, slightly different if you prefer (but exactly the same principle)
#define VERSION_STRING(major, minor, maintenance) VERSION_STRING_(major, minor, maintenance)
#define VERSION_STRING_(major, minor, maintenance) #major "." #minor "." #maintenance
const char rev[] = VERSION_STRING(SW_VERSION_MAJOR, SW_VERSION_MINOR, SW_VERSION_MAINTENANCE);
I'll argue for that in future projects, thanks for another great suggestion!
following, as this is something I also run in every now and then.
Just to update the thread, I used the following code:
#define STR_HELPER(x) #x
#define STR(x) STR_HELPER(x)
const char var_firmware_rev[] = STR(SW_VERSION_MAJOR) "."
                                STR(SW_VERSION_MINOR) "."
                                STR(SW_VERSION_MAINTENANCE);
