SD Card fails to initialize
7 posts / 0 new
Hello everyone,
I am doing a personal project to learn more about programming a microcontroller and designing a PCB. Although I am using an Arduino Mega I created the topic here because I am programming it as an AVR, but if that’s not correct please move it to the right section.
My tools are the Arduino Mega 2560 r3, avrdude v6.3, avr-gcc v5.4.0 and MPLAB v5.20.
My goal right now is to write to SD Card, a module that I bought from eBay,
https://tinyurl.com/y3t4caal
Firstly, I tested with the Arduino SD Card library and I could read the card and write to it without problems, so it works.
Next, I read the following websites,
http://elm-chan.org/docs/mmc/mmc_e.html
http://bikealive.nl/sd-v2-initialization.html
https://www.engineersgarage.com/embedded/avr-microcontroller-projects/sd-card-interfacing-project
to understand the protocol.
At last, I downloaded a simple example,
and started modifying it.
PROBLEM
I am not being able to initialize the sd card I can’t figure out why. The command that fails is the APP_CMD, I would expect to receive something different from 0xFF but that’s all I receive.
The code is,
#define F_CPU 16000000UL
#define GO_IDLE_STATE            0
#define SEND_OP_COND             1
#define SEND_IF_COND             8
#define SD_SEND_OP_COND          41
#define APP_CMD                  55
void sdsc_init(void) {
    int x;
    unsigned char tmp;
    char buffer[10];
    // Initialize SPI
    DDRB = 0x87; // 1000 0111
    SPCR = 0x53; // 0101 0011
    SPSR = 0x00; // 0000 0000
    _delay_ms(100);
    // Initialize SPI
    PORTB |= 0x01;            // Chip select high
    for (x = 0; x < 12; x++)  //dummies clock
        sdsc -> spi_rx();
    PORTB &=~0x01;        // Chip select low
    while (0x01 != sdsc_command(GO_IDLE_STATE, 0));
    while (0x01 != sdsc_command(SEND_IF_COND, 0x000001AA));
    while ( sdsc_command ( APP_CMD, 0 ) && sdsc_command ( SD_SEND_OP_COND, 0x40000000 ) ); //v2
    //while (sdsc_command(APP_CMD, 0) && sdsc_command(SD_SEND_OP_COND, 0x00000000));   // v1
    //while (sdsc_command(SEND_OP_COND, 0x00000000)); // mmc
    while (0x00 != sdsc_command(READ_OCR, 0));
unsigned char sdsc_command(unsigned char cmd, unsigned long arg) {
    unsigned char r1;
    sdsc -> spi_tx(cmd | 0x40);
    sdsc -> spi_tx(arg >> 24);
    sdsc -> spi_tx(arg >> 16);
    sdsc -> spi_tx(arg >> 8);
    sdsc -> spi_tx(arg);
    if (cmd == SEND_IF_COND)
        sdsc -> spi_tx(0x87);
        sdsc -> spi_tx(0x95);
    while ((r1 = sdsc -> spi_rx()) == 0xff); // wait response
    return r1;
void spi_tx(unsigned char data) {
    SPDR = data;
    while (!(SPSR & (1 << SPIF)));
unsigned char spi_rx(void) {
    SPDR = 0xff;
    return SPDR;
Unfortunately, I can’t test the SPI communication with another module to check if the functions are correctly working because I don’t have another module with SPI.
Most of the code is equal to the original, I just changed the ports and added code to work with other versions of sd card.
I added delays between the sdsc_command but nothing happened. I don't know how to solve this problem, any help is welcome.
I attach the code.
Thank you
Doing while ( sdsc_command ( APP_CMD, 0 ) && sdsc_command ( SD_SEND_OP_COND, 0x40000000 ) ); //v2 is not a good idea, because you cannot be certain which one of those two sdsc_command() will be performed first.
( the SD_SEND_OP_COND operation should preceed the APP_CMD )
I suggest you just have a search on "FatFS"  then you do not have to worry about the low level stuff.
It also is the SD/MMC interface package most of us here use and thus will be familiar with, in addition there will be a lot of threads about it here on the forum.
that should get you going in no time. It will take quit some reading at first as there are a lot of threads questions here, but then you should be good to go in no time.
His links above suggest he already did.
I would suggest it is possibly the "best" implementation of SD/MMC + FAT for embedded micros so I would also suggest using it. In the MMC support code the disk_initialize looks like:
DSTATUS mmc_disk_initialize (void)
	BYTE n, cmd, ty, ocr[4];
	power_off();						/* Turn off the socket power to reset the card */
	for (Timer1 = 10; Timer1; ) ;		/* Wait for 100ms */
	if (Stat & STA_NODISK) return Stat;	/* No card in the socket? */
	power_on();							/* Turn on the socket power */
	FCLK_SLOW();
	for (n = 10; n; n--) xchg_spi(0xFF);	/* 80 dummy clocks */
	ty = 0;
	if (send_cmd(CMD0, 0) == 1) {			/* Put the card SPI mode */
		Timer1 = 100;						/* Initialization timeout of 1000 msec */
		if (send_cmd(CMD8, 0x1AA) == 1) {	/* Is the card SDv2? */
			for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF);	/* Get trailing return value of R7 resp */
			if (ocr[2] == 0x01 && ocr[3] == 0xAA) {				/* The card can work at vdd range of 2.7-3.6V */
				while (Timer1 && send_cmd(ACMD41, 1UL << 30));	/* Wait for leaving idle state (ACMD41 with HCS bit) */
				if (Timer1 && send_cmd(CMD58, 0) == 0) {		/* Check CCS bit in the OCR */
					ty = (ocr[0] & 0x40) ? CT_SD2 | CT_BLOCK : CT_SD2;	/* Check if the card is SDv2 */
		} else {							/* SDv1 or MMCv3 */
			if (send_cmd(ACMD41, 0) <= 1) 	{
				ty = CT_SD1; cmd = ACMD41;	/* SDv1 */
			} else {
				ty = CT_MMC; cmd = CMD1;	/* MMCv3 */
			while (Timer1 && send_cmd(cmd, 0));			/* Wait for leaving idle state */
			if (!Timer1 || send_cmd(CMD16, 512) != 0)	/* Set R/W block length to 512 */
				ty = 0;
	CardType = ty;
	deselect();
	if (ty) {			/* Initialization succeded */
		Stat &= ~STA_NOINIT;		/* Clear STA_NOINIT */
		FCLK_FAST();
	} else {			/* Initialization failed */
		power_off();
	return Stat;
The && operator guarantees that the left-hand expression is evaluated first.
I stand corrected..
Sometime in the dim past I 'read' that expressions might not be evaluated in the order that one expected, and hence I've used brackets () and simple expressions everywhere.
Thank you everyone. The implementation of FatFS it's too complicated for me. I wanted simple code just to write to SD Card. I tried again to use the FatFS but it's too overwhelming. I didn't want to use code that I cannot understand in my project. And wanted to keep it simple.
Eventually I found this one,
https://exploreembedded.com/wiki...
that works perfectly fine and it's simple to read. I am already using it, I will adapt to my needs.
Unfortunately i couldn't find out the problem with the code that I posted so i cannot offer a solution.
