Arduino Uno - interrupt on serial rx
5 posts / 0 new
Am I going bananas and/or missing something obvious? The limited amount of googling I have done leads me to believe that the only interrupts which can wake the processor from deep sleep are the D2 and D3 level change. I had rather hoped that I could get  a received serial data stream to wake the processor.
Obviously it will require some sort of reset of the serial status to do that, and a suitable serial protocol to define where the actual message is, but at the moment it looks like I need to link the serial in to D2 or D3 to get the wakeup... meh.
Will play with this on Monday.
Neil
Cross wire RXD to INTO/INT1 perhaps?
But it's a 328P don't the UART pins also do PCINT?
(not in a position to download/check d'sheet, watching British GP qualifying)
Looking at the 328P datasheet, the set of interrupts that can wake depends on the Sleep Mode.   For Idle, I would expect UART to work, otherwise you need to use INT0, INT1, or "Pin Change",  In the I/O ports section it says "SLEEP is overridden for port pins enabled as external interrupt pins.   Hope that helps.
That's about what I'd figured, thanks. I'll be poking things around today.
Neil
Sadly, still too much power taken by processor and associated hardware, including the micro-SD card. So I'm using a switchable regulator to drive the 5v line directly when required to power the board using the host's batteries.
Neil
