Need help with 8-bit timer
30 posts / 0 new
#define F_CPU 16000000UL
void intzar (void)
	unsigned char i = 0;
	for (i = 0; i < 100; i++)		//Makes the delay of 1.6384 sec
	TCCR0A = 0xC2;		//CTC mode is used.
	OCR0A = 0xFF;		//8 bit timer
	TCCR0B = 0b00000101;	//prescaler of 1024
	while ((TIFR0 & 0b00000010) == 0b00000010)
		TCCR0B = 0x00;
		TIFR0 = 0x03;
	DDRB = 0b10000000;
	while (1)
		PORTB = 0b10000000;
		intzar();
		PORTB = 0b00000000;
		intzar();
Hi guys,
I have written a code to blink an led using an 8 bit timer to produce a delay of 1.6384 sec. As I upload the code to ATmega2560 chip, the led fails to blink. Your guidance would be of great help.
Here is the code. The platform I am using is AtmelStudio7.
Forget the timer based delay for the time being. If you simply use _delay_ms() delays what happens?
(IOW is the LED all wired up OK?)
I'll add that using binary constants like 0b1000000 is a real invitation to typos (like the one I just made).
Use (1 << 7), or
#define LED_BIT 7
(1 << LED_BIT)
A simple delay is working fine.
But the code works fine when _delay_ms function is used.
Zarrar wrote:
TCCR0B = 0x00;
this code stops the timer, and the for loop can not repeat 100 times secessfully
Obviously I need to stop the timer as the flag goes high so that the timer gets ready for the next round.
		TCCR0B = 0x00;
		TIFR0 = 0x03;
Describe what you think this code section does.
That's almost never how you should use timers (because it introduces timing jitter), but that's not your problem here.
Dear I have added comments to the code.
However, in while loop I am monitoring the output compare match flag. As the flag goes high, the timer stops and and the output compare match flag is reset.
Suggest the right way.
Not sure its the "right" way but try this:
void intzar (void)
	while ((TIFR0 & 0b00000010) == 0b00000010);
	TCCR0B = 0x00;
	TIFR0 = 0x03;
You are making the wrong test here.  You are testing for a compare match (OCF0A = 1), and since OCF0A will not be set immediately, your test will fail and your while() loop will exit immediately.
And write 0b00000010 as (1 << OCF0A) so your meaning is clear.
A relatively new problem now.
This piece of code makes the led glow continuously.
	DDRB = 0b10000000;
	while (1)
		PORTB = 0b00000000;
		intzar();
		//PORTB = 0b10000000;
		//intzar();
While this shuts the led down:
	DDRB = 0b10000000;
	while (1)
		PORTB = 0b00000000;
		//intzar();
		//intzar();
Can it be explained...?
I also tried the test for timer overflow flag (TOV0 = 1). But it did not solve the problem either.
If you haven't fixed your while() problem, there's a good chance that your LED is turning on and off many hundreds or thousands of times per second, far too fast for you to discern.
Have fixed the while problem..but the problem persists.
Thanks dear.
One thing I would like to mention that I am using ATmega2560 on Arduino mega board.
Have done certain changes to program the ATmega2560, on Arduino mega board, through Atmelstudio7.
Isn't that causing the issue I am having?
Any time you change the code ("fixed a problem") you need to post your entire new code.
//#include <util/delay.h>
void intzar (void)
	unsigned char i ;
	TCCR0A = 0xC0;		//NORMAL mode is used.
	while ((TIFR0 & (1<<TOV0)) == 0b00000001)
		TCCR0B = 0x00;
		TIFR0 = 0x01;
	DDRB = 0b10000000;
	while (1)
		PORTB = 0b00000000;
		intzar();
		PORTB = 0b10000000;
		intzar();
Did you recognize in comment#14 that the calling of intzar(); makes the LED glow continuously...?
I could not understand that.
Please try this.
void intzar (void)
    TIFR0 = 0b00000001;     // clear OVF flag
    TCNT0 = 0;              //clear counter
    TCCR0A = 0x00;          //NORMAL mode is used.
        while (!(TIFR0 & 0b00000001));  // wait OVF
    TCCR0B = 0; // stop TC0
    DDRB = 0b10000000;
    while (1)
        PORTB = 0b10000000;
        intzar();
        PORTB = 0b00000000;
        intzar();
Just to say that it is confusing beyond belief when you write code laid out like this:
		TCCR0B = 0x00;
		TIFR0 = 0x01;
While it is functionality equivalent:
	while ((TIFR0 & (1<<TOV0)) == 0b00000001);
        TCCR0B = 0x00;
	TIFR0 = 0x01;
is far clearer about how these things are related (ie they are not). The curious indentation and "stray semicolon" in the first initially imply something entirely different.
PS:
is the reason you probably want to start reading about "CTC mode" ;-)
(unless you really want a 1.6834 second delay??)
Thanks a million dear Kabasan.. :)
The code is working fine..
OP, this is what I was trying to get you to understand,  The correct waiting test is to wait while the flag (overflow or compare) is ZERO, and drop through when it goes to ONE.  Thus it uses the '!' operator in the test.  Your code was waiting while the flag was ONE, and dropped through when it was ZERO, which meant your code never waited because the flag was always ZERO to start with.
clawson wrote:
PS:
I'd suggest to OP that he now figure out how to get 1 ms timer ticks (hint, prescaler of 64, compare value of 250-1).  Then modify intzar to take a delay parameter in milliseconds ( void intzar(uint16_t delay_ms) )
Thanks dear kk6gm, your explanation cleared the my realization of the syntax. :)
Thank you all for the help.. :)
Zarrar wrote:
while (some_flag == 1)
kk6gm, I couldn't understand that when I am masking the TIFR0 register (with 0b00000001) and waiting for that timer overflow flag to be ONE; how the test is going wrong..?
Here is the sequence you were using:
some_flag = 0;    // flag starts out NOT set
while (flag == 1)  // since flag is ZERO, this while() immediately drops through
// we get here immediately, which is wrong!
Here is the sequence you want:
some_flag = 0;
while (some_flag == 0)  // now it waits for some_flag to get set to ONE
---OR---
while (!some_flag)   // note use of '!' operator
// we only get here when some_flag changes from ZERO to ONE
Now for some other ways to make your code cleaner:
while (!(TIFR0 & (1<<TOV0)))
First note the use of the bit identifier TOV0 rather than a magic number like 0b00000001.  Other compilers might supply a bit mask so you might write !(TIFR0 & TOV0_MASK)
Second, note that there is no reason to explicitly compare a single bit to zero or non-zero using ==.  The expression !(TIFR0 & (1<<TOV0)) already returns a value of zero or non-zero, which can be tested directly, without using ==
