Arduino fails to upload after installation of the latest version
7 posts / 0 new
After installing a new version, Arduino cannot upload with my avrispmk2 programmer
When I click the upload button it shows that it executes this line:
/usr/share/arduino/hardware/tools/avr/bin/avrdude -C/usr/share/arduino/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_952916/bmp280.ino.hex:i
It works fine when I change the avrdude parameters and run it in a terminal:
/usr/share/arduino/hardware/tools/avr/bin/avrdude -C/usr/share/arduino/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cavrisp2 -Pusb -D -Uflash:w:/tmp/arduino_build_952916/bmp280.ino.hex:i
Where can I change the command line in Arduino?
The first command talks to Duemilanove bootloader.
The second command talks to your AVRISP-2
The first command would work FOREVER if you have a Duemilanove (or other 57600 baud bootloader)
The second command will work ONCE.    The -D switch prevents the AVR erasure (I think).
If you omit -D it will erase the bootloader.
Life is a mystery.    God invented the Arduino.   The Bootloader works perfectly.   The IDE works well.
Why do punters want to destroy it?
Incidentally,   you can always "mqke everything better":
1. Connect AVRISP-2 to 3x2 header.
2. Select AVRISP-2 as Programmer
3. Select the correct Arduino Board
4. Select Burn Bootloader
5. Dig deep hole.
6. Bury AVRISP-2
The situation is this:
I'm trying to upload to a "Arduino Pro mini" and I could not find my FTDI programmer, probably lost it. So I ordered a new one on eBay. Now I have to wait a couple of weeks for it to arrive from China. To have something to do in the meantime, I opened up the deep hole again, wiped the dirt from the avrispmk2. I selected the Pro Mini and avrispmk2 in the tools menu.
I have absolutely no idea why it is trying to address a Duemilanove.
I don't want to program the bleeping thing from the command line every time.
Arduino - Programmer (Upload using Programmer)
A Pro Mini has no Serial.  It does not even have a power supply.
If you want a Bootloader you need to buy a Serial dongle and power supply and permanently connect them.
So actually an USBASP or your AVRISP-2 is probably the most convenient way to program it.   (or even an ArduinoISP)
A Pro Mini might be ok for a final product.   But it is painful to use for development.   You either need external Serial or external programmer.
A 5V Nano is the same size but fully functional as an Arduino i.e. USB cable is all you need.
Whether you use Bootloader or Programmer it is a single keystroke ctl-U or ctl-Shift-U from the Arduino IDE.
I don't agree. A Pro Mini in combination with serial programmer with an FTDI chip gives you the same functionality as a complete Arduino with USB port. Why would you want a programmer on every board. It's a waste of money and pcb space.
In my case, yes it is painful, because I have to wait for the programmer to arrive.
The pins of this programmer fit directly in the holes of the pro mini, see the pictures on this site: https://www.ebay.co.uk/itm/11160...
Using the AVRISP-MK2 is more challenging. The serial port is missing so there is no debugging information when I use it for the pro mini because I cannot use the serial monitor.
Everyone to their own opinion.
A Nano is cheap from Ebay
It is breadboard friendly and is small enough to fit in a final product.
I was just pointing out that you need "extra electronics" before you can program a Pro Mini (even with bootloader).
You don't need them in the final project.
Personally,   I don't like Nanos and I don't like breadboards.   I prefer Uno format Protoshields.   (because I can use with NXP, STM32, ...)
