Equivalent of saft battery ls33600b
9 posts / 0 new
Is there any equivalent of saft battery ls33600b , http://www.farnell.com/datasheet...
One I found is omincel.
Any other good reputed brand for use in oil and gas industry?? Anyone has experience in that?
You need to edit your link it gives an address error, Some extra characters are added at the end. * Fixed. Ross*
what do Digi-key and Mouser come up with?
Oil and Gas industry I assume have very very stringent rules and regulations, I do not think a lot of manufacturers will be in the playing field, low volume high costs.
Something from Tadiran?
http://www.tadiranbat.com/assets... perhaps?  Same target of high-reliability, long-life, high-copacity, and you pay for every bit of it.
I have no idea whether they already have reputation in O&G.
Indeed. I see that the SAFT battery complies with ATEX standards.
found Guangzhou Markyn Battery as distributed by PowerStream (Orem, Utah US)
Single piece and bulk quantity Lithium thionyl chloride (LiSOCl2, Li/SOCl2)) Cells for sale from PowerStream
(mid-page)
ER34615H, 19Ah, 105g, 34mmD*61.5mmL, in-stock
Opened one of ls33600b pack & found this black thing on right side.
Its in series with positive wire. Anyone knows what it is?
Probably a fuse or polyswitch...why not just take off the heatshrink and see what it is?
its 3.9ohm resistor: W22
It’s probably not compliant now if you’ve interfered with the safety equipment.
