Quiz for fun, I/O pin and 4 levels
15 posts / 0 new
Let us assume; we like to monitor on a scope the timing of 4 stages while an MCU code is running. But one I/O pin only is free for this task.
As we know, an I/O pin (as of ATmega8) is controlled by 2 internal bits (in two I/O registers; DDRx and PORTx). An I/O pin could have, therefore, 4 different states which could be made to output four different voltages. The two obvious outputs are Vcc and 0V.
On my next post, I will present a possible solution which I applied lately.
Have fun,
Cheers,
Kerim
Well one solution, and I did not think of this but read it here somewhere, is to have a soft uart (TX only) and send serial debug info out as needed and read the result using a logic analyzer......
I'm sure there are others as well.
Keys to wealth:
Lets go Brandon!
Two external resistors, one pull-up and one pull-down.
With the pin as an output you have +Vcc and 0V. As as input you can turn on and off the internal pull-up and therefore have two intermediate levels.
With a bit of maths you could arrange the intermediate levels to be 1/3Vcc and 2/3Vcc.
Hi Jim,
The solution, you presented, is indeed good when there are too many stages to monitor, not just four.
Hint:
For 4 states, it could be solved by a simple hardware; so that the pin voltage changes as fast as setting/clearing its DDR or PORT controlling bit.
Hi Brian,
You were very fast crying
 A possible solution:
Two external resistors are added; a pull-up (R_up) and a pull-down (R_dw).
In this case, the optimum levels for monitoring are: Vcc , 2*Vcc/3 , Vcc/3 and 0
If Rp is the typical value of the internal pull-up resistor, the 4 levels of the pin output are:
DDR=1 and PORT=1 ===> Vcc
DDR=0 and PORT=1 ===> Vcc * R_dw / ( R_dw + Rp//R_up )
DDR=0 and PORT=0 ===> Vcc * R_dw / ( R_dw + R_up )
DDR=1 and PORT=0 ===> 0
By solving the two equations below:
2*Vcc/3 =  Vcc * R_dw / ( R_dw + Rp//R_up )
Vcc/3 = Vcc * R_dw / ( R_dw + R_up )
We get:
R_up = 3*Rp
R_dw = R_up / 2
On my board, the typical value of Rp is 37.5 K (of ATmega8; 80uA/3V). I added R_up (120K) and R_dw( 56K).
DDR=1 and PORT=1 ===> 5V00
DDR=0 and PORT=1 ===> 3V31
DDR=0 and PORT=0 ===> 1V59
DDR=1 and PORT=0 ===> 0V00
Edited: Thanks to Jim.
If we assume the internal pull-up is 100k then an external pull-up of 200k, and a pull-down of 100k, will give you then numbers above.
Assuming 5v rail.
There are other possibility depending on what pin you have available. One option might be to change the reload value of a timer if a timer output pin is free and it's not otherwise used internally.
[E2A]
Going back many years an ex-colleague put an R-2R-4R... resistor DAC on the address bus of his Z-80 based CP/M system and connected it to a moving coil voltmeter. The meter therefore indicated where in the address range the code was. A low voltage would indicate user code whereas a high voltage either somewhere in the BDOS or BIOS.
I am afraid that in your case (internal pull-up is 100K), the external pull-up is 300K and the pull-down is 150K.
DDR=0 and PORT=0 ===> 0
This does not look right?  both ddr/port = 0 in both cases???
edit: I think you meant:
Keys to wealth:
Lets go Brandon!
Thank you Jim.
DDR=1 and PORT=0 ===> 1V59
DDR=0 and PORT=0 ===> 0V00
This still does not look right?  One more time please.
Keys to wealth:
Lets go Brandon!
Also many years ago, I have seen a similar thing done with a scope, using upper 8 bit of address bus as one axis, and lower 8 for the other.
I can only assume it wasn't all that useful, as I've not seen it suggested since.
Originally by Jack Ganssle I bellieve
http://www.ganssle.com/tem/tem226.htm
Really? I'd have thought bit banging serial TX only was as old as the asynch serial protocol.
About where the code run , back in the old days (I think it was late 80's), one of my friends had a PC (80286 I think), that had a LED bar on the case, that showed where the code ran.
