Memory corruption?
20 posts / 0 new
Hi Guys,
Wonder if someone could give me some pointers as to what's going on.
Studio 7
I have a program that runs on both an Atmega324pb and 328p
I'm having an issue where the same code behaves badly on the 328p as if I'm trampling on memory, but the 324pb is fine
stats on build
Program Memory Usage : 3664 bytes   11.2 % Full
Data Memory Usage : 535 bytes   26.1 % Full
EEPROM Memory Usage : 308 bytes   30.1 % Full
It occurs where I'm passing a 32 byte array to a function in a class (by reference) and I'm reading the contents into another array (only half of it)
The debugger shows random data being retrieved and my loop counter x is a large value even when initialised to 0.  If I remove the array from the call, it's all it should be.  In addition, some local variables seem to be missing in the Autos and Local windows.
Scratching my head here.
regards
This is one source program, but has been compiled for the appropriate target micro, correct?  Are you loading the correct hex file for the target?
Or are you saying you are loading the same program (hex file) in to both targets?  This is not likely to work!
No I'm compiling and debugging on each target with a work pc and a home PC. There is a #define in a header file which defines the target.  All of the rest of the code is fine.
regards
Are you passing this data by value, or by reference?   Show the function declaration.
hi,
here's the definition
uint8_t groupSet(int8_t group, uint8_t num_count, uint8_t data[]);
all values are scrambled but only with the 328P.  remove the last element and it's fine
regards
hypothesis : the extent of data is incorrect "somehow"
test : linter over the entire source code, the file, or the pertinent snippet
Some linters will create a caution, warning, or information statement about source code that's valid wrt a compiler.
The first two are pass by value so are copies of group and num_count, the last one is a pointer so you might try defining it that way, i.e.  uint8_t* data and see if that helps.
not sure why it works with one and not the other.
Can you create and post a small complete program that demos the problem, then a freak can compile and help you debug it.
Thanks for that. I'll give it a try.  Working up a demo may take a little time as it's a mix of C and C++.  I guess it could also be the optimisation level that's messing up the debugger.  I haven't tried to see if that data is copied outside of the debug window.  It wouldn't be the first time I've seen it happen
regards
Always use -Og for debug!
I tried using that debug  level and now it's silly values.
This line:
for(int8_t x=2; x <18;x++){
Before was showing the correct values, but now in the autos it shows a value of 464 and the type is 'unsigned long@X' !
So confused.
regards
Turn on all compiler warnings and make sure to
fix all of them.
--Mike
spaces make it easier to read (and troubleshoot too)
for(int8_t x = 2; x < 18; x++){
not that, that is the problem above, just style nit picking.
Turned on warnings.  Wasn't aware that it needs to be done in two sections (C & C++) as its a mix.
No errors, just this one warning
void ATL::writeDigit(int8_t buffOffset,char data,bool DP)
    DisplayBuffer[buffOffset -1] = data;
    if(DP)
          DPBuffer[buffOffset -1] = MAX_DP;
Warning        overflow in implicit constant conversion [-Woverflow]   this line - ->   (DPBuffer[buffOffset -1] = MAX_DP;)
I'm not sure why it's complaining though
regards
The value of MAX_DP cannot fit into DPBuffer[].
Or, if MAX_DP is an expression, some part of it overflows.
Show the declaration of DPBuffer[], and the #define for MAX_DP.
1) Can you use a data memory breakpoint to check what part of the code modifies the memory? I'm not sure those devices support it though...
2) Are you using interrupts? If so have you tried turning interrupts off?
3) Did you check that all variables in your application are initialized?
4) Did you lint your code?
/Jakob Selbing
Post the complete project e.g. ZIP up your AS7.0 project and attach the zip file.
These things generally come down to exceeding array bounds e.g. by using the wrong loop counters.
It is quicker to post the buildable code. Readers' eyes might spot things that you missed.
Yes, you can post the snippets that YOU think might be the problem. Your preparation might show you the error but more likely you omit the fatal snippet.
The beauty of the internet is that you can post a project that can be built by anyone, anywhere in the world e.g. AS7.0
David..
volatile int8_t DPBuffer[32];
#define MAX_DP   0x80
regards
I know what you're saying, but the project is more than the code.  It consists of SPI, TWI and to exercise the code you need a master TWI to send commands/requests.  My original post was really to determine if anyone had come across the IDE/debugger behaving this way.
So that I can work at work and also at home, I transfer the code to myself in email. (I have GIT in place as well)
As it happens, I copied what I thought were identical files from home(code worked there) to work and the issue has gone away!  I guess it must of been something very subtle.  I'm looked at a diff, but there's nothing obvious
regards
supported for mega324, maybe not for mega328
Atmel Studio 7 - General Information on Data Breakpoint
Maximum number of data breakpoint supported: (this may vary based on specific device/family refer data sheet)
[table : CPU architecture, Maximum Data Breakpoint Supported]
MAX_DP has the value 128 which doesn't fit in an
int8_t (range is -128..127).
--Mike
