Sample rate and number of ADC channels
12 posts / 0 new
Hi everyone.
I am new to AVR and also to this interesting website/forums. I have a question regarding ADC. It is related to sampling rate and number of adc channels. Let's say the external crystal is 16MHz, and the prescaler is 128. then the frequency of ADC is 125 KHz, considering that a conversion rake about 13 adc clock, then we can sample approximately 9600 sample per second. my question is: If more than one channel is used, then this sampling rate will split between them? For example if two channels are used, then each channel can sample 4800 per second?
I appreciate if you can help me with this.
Yes, you need to select the mux, then take your reading.  If you only have one ADC peripheral, then it must be shared & the throughput is reduced.
You can only read one ADC channel at a time..   Yes.   You can get a fresh 10-bit sample on a single channel every 13 ADC "clocks".
If you are changing the ADC channel you must allow for the SAH capacitor to charge to the new signal voltage.
In practice you would not expect to read several channels at full speed.
You can get 8-bit samples faster than 10-bit samples i.e. less ADC "clocks"
 Then you mean then sampling frequency will be shared between different channels?
thank you for your help
Thanks David. Can you give me a hint on how to let SAH capacitor to charge? should I use delay?
Life is easier if you just say what you want to do.   e.g. sample two audio signals,   sample five temperature sensors, ...
Note that some sensors really do not need to be sampled at a high rate e.g. temperature
But an audio signal probably does.
You can have several different signals. One on each ADC channel pin.
You can sample at different rates and the punter does not notice.    e.g. skip an audio sample to read a battery voltage.   (let the software guess the missing sample)
Just to point out that if you are still in the design phase and the core of your design is ADC use you may be using the wrong AVR if you have picked one with the 200kHx/13 clock limit. The Xmega have a much more advanced ADC capable of converting much faster. I haven't checked but I suspect the very recent Xtiny chips have probably inherited that same ADC.
Actually, I have a current sensor and a microphone. The microphone is able to record up to 22khz signals. so I need to read two channels, while for microphone i need at least 22k sample per seconds
You need to pay attention to what is going on, since a 22KHz  freq would require at least 44KHz sampling (which won't happen with the classic AVR).
If you can get up to 15K samples/sec, then your allowable freq might be able to go as high as 7.5KHz.
What exactly are you trying to do?  It's doubtful you need to do anything at that 22 KHz freq, unless audiophile (which the AVR isn't)
Ok, this sounds like an interesting application, can you expand on it?
You can run the ADC faster with lower resolution, say 250k at 8 bit and get close to 22KHz sample rate, but that means a max frequency input of around 11kHz.....
Did you mention which AVR?
Let's assume the ubiquitous ATmega328P
The m328p can hit a 1 MHz clock for 8 good bits.  That gives 1000000/13 = 76.923 kHz.  If you're sampling 2 channels, that gives a channel rate of 38.462 kHz.
Not necessarily.  If the impedance of the signal sources is low enough, the 1.5 ADC clock period during the sample period is sufficient to do that.  One must do the analysis, however.
As per the datasheet, the internal resistance of the ADC path is between 1K and 100K.  The S/H cap is 14 pF.  You want the cap to charge to within 0.5 LSB.  This has been addressed in whole or in part in a number of previous threads:
https://www.avrfreaks.net/forum/avr-adc-analog-bandwith?page=all
https://www.avrfreaks.net/forum/adc-series-resistance?page=all
https://www.avrfreaks.net/forum/atmega8-adc-two-inputs?page=all
(In particular: https://www.avrfreaks.net/comment/1722371#comment-1722371 and https://www.avrfreaks.net/comment/1722446#comment-1722446)
There are others I haven't dug up.
The simplest first thing to do is to set the ADC channel to the next channel number immediately after reading the current ADC value, rather than setting the ADC channel just before starting the conversion.  This give you some "free" SAH settling time, which may or may not be enough depending on what is driving the ADC channels.
So do this:
Start conversion
Read ADC value
Set MUX to next channel
...Do other stuff...
Rather than this:
Start conversion
Read ADC value
