Using EEMEM in a class
8 posts / 0 new
Studio 7
In the class include file I have the following declaration
uint8_t EEMEM NonVolatileString[16][18];
This fails to make with the following errors
expected ';' at end of member declaration
 'NonVolatileString' does not name a type
 'Section atribute not allowed for 'NonVolatileString'
I'm not knowledgeable enough to figure out what's wrong or if I simply can't do this so any help would be appcreciated
Regards
Nik Middleton
Maybe not your problem, but you don't say which AVR. Many have EEMEM sizes that are 256 bytes or less. Your declaration uses 288.
You might check about how much space your device actually has.
Sorry my bad, target is a 328P so 1024 available
regards
Nik Middleton
Apply the attribute at the point of instantiation not declaration.
Like this, as an example:
#include <avr/eeprom.h>
class EEPROM {
	private:
		static char strings[][18];
EEMEM char EEPROM::strings[][18] = {
	"Test"
int main(void) {
    while (1) {
I assume you want them static so that you can initialize the strings statically... If not, then you need read/write functions from the avr/eeprom.h file...
:: Morten
It compiles but I don't seem to be able to set any values.  It seems to be an offset, but I'm not sure.  When I try the following within the class
//instantiate a copy of myclass
myclass  test;
myclass.h
private:
    static uint8_t NonVolatileString2[5];
in main.cpp
EEMEM uint8_t test::NonVolatileString2[] ;
in class
eeprom_write_byte(&NonVolatileString2,0x21);
Error  cannot convert 'uint8_t (*)[5] {aka unsigned char (*)[5]}' to 'uint8_t* {aka unsigned char*}' for argument '1' to 'void eeprom_write_byte(uint8_t*, uint8_t)'
Am I simply just missing something?  I basically want to read/write to the eeprom from within a class, populating data to be wrtten from within the class
regards
Nik Middleton
Now you're just mixing types...
uint8_t NonVolatileString2[5] is a pointer to the first element of a array of 5 uint8_t things.
Writing the first byte will then be  eeprom_write_byte(&NonVolatileString2[0],0x21), writing the second byte is eeprom_write_byte(&NonVolatileString2[1],0x21) etc...
Or, if you want to write blocks, use eeprom_write_block.
PS; use the _update_ functions instead of read/write. The _update_ functions will check if the value actually has to be written, possibly saving a write cycle of the eeprom.
:: Morten
Perfect!  Thanks for the pointers (no pun intended smiley )
regards
Nik Middleton
