ATMega 16u2 UNOJoy, no joy
20 posts / 0 new
My foray into more complicated AVR usage (after a lot of Arduino fiddling) I have built a PCB that is based somewhat on the UNO3.  As I plan on using HID, I have the USB being handled by the 16u2.  That section of schema is 'pretty similar' to the UNO R3:
16u2 schema snapshot
The layout has slightly longer traces from the USB plug to the chip, but not by much.
The issue I am having is that the device is never recognized by the PC, when the UNO was with the same firmware.  I know the firmware is running, and I know where it is stalling.  If I debug the UNOJoy project, it seems the SET_CONFIGURATION request is not forthcoming....   Standard UNOJoy USB interrupt handler:
// USB Endpoint Interrupt - endpoint 0 is handled here.  The
// other endpoints are manipulated by the user-callable
// functions, and the start-of-frame interrupt.
ISR(USB_COM_vect)
	uint8_t intbits;
	const uint8_t *list;
	const uint8_t *cfg;
	uint8_t i, n, len, en;
	uint8_t bmRequestType;
	uint8_t bRequest;
	uint16_t wValue;
	uint16_t wIndex;
	uint16_t wLength;
	uint16_t desc_val;
	const uint8_t *desc_addr;
	uint8_t	desc_length;
	uint8_t rep_id;
	uint8_t rep_type;
	UENUM = 0;
	intbits = UEINTX;
	if (intbits & (1<<RXSTPI)) {
		bmRequestType = UEDATX;
		bRequest = UEDATX;
		wValue = UEDATX;
		wValue |= (UEDATX << 8);
		wIndex = UEDATX;
		wIndex |= (UEDATX << 8);
		wLength = UEDATX;
		wLength |= (UEDATX << 8);
		UEINTX = ~((1<<RXSTPI) | (1<<RXOUTI) | (1<<TXINI));
		if (bRequest == GET_DESCRIPTOR) {
			list = (const uint8_t *)descriptor_list;
			for (i=0; ; i++) {
				if (i >= NUM_DESC_LIST) {
					UECONX = (1<<STALLRQ)|(1<<EPEN);  //stall
					return;
				desc_val = pgm_read_word(list);
				if (desc_val != wValue) {
					list += sizeof(struct descriptor_list_struct);
					continue;
				list += 2;
				if (desc_val != wIndex) {
					list += sizeof(struct descriptor_list_struct)-2;
					continue;
				list += 2;
				desc_addr = (const uint8_t *)pgm_read_word(list);
				list += 2;
				desc_length = pgm_read_byte(list);
				break;
			len = (wLength < 256) ? wLength : 255;
			if (len > desc_length) len = desc_length;
			do {
				// wait for host ready for IN packet
				do {
					i = UEINTX;
				} while (!(i & ((1<<TXINI)|(1<<RXOUTI))));
				if (i & (1<<RXOUTI)) return;	// abort
				// send IN packet
				n = len < ENDPOINT0_SIZE ? len : ENDPOINT0_SIZE;
				for (i = n; i; i--) {
					UEDATX = pgm_read_byte(desc_addr++);
				len -= n;
				usb_send_in();
			} while (len || n == ENDPOINT0_SIZE);
			return;
		if (bRequest == SET_ADDRESS) {
			usb_send_in();
			usb_wait_in_ready();
			UDADDR = wValue | (1<<ADDEN);
			return;
		if (bRequest == SET_CONFIGURATION && bmRequestType == 0) {
			usb_configuration = wValue;
			usb_send_in();
			cfg = endpoint_config_table;
			for (i=1; i<5; i++) {
				UENUM = i;
				en = pgm_read_byte(cfg++);
				UECONX = en;
				if (en) {
					UECFG0X = pgm_read_byte(cfg++);
					UECFG1X = pgm_read_byte(cfg++);
			UERST = 0x1E;
			UERST = 0;
			return;
		if (bRequest == GET_CONFIGURATION && bmRequestType == 0x80) {
			UEDATX = usb_configuration;
			usb_send_in();
			return;
		if (bRequest == GET_STATUS) {
			i = 0;
			#ifdef SUPPORT_ENDPOINT_HALT
			if (bmRequestType == 0x82) {
				UENUM = wIndex;
				if (UECONX & (1<<STALLRQ)) i = 1;
				UENUM = 0;
			#endif
			UEDATX = i;
			UEDATX = 0;
			usb_send_in();
			return;
		if ((bRequest == CLEAR_FEATURE || bRequest == SET_FEATURE)
		  && bmRequestType == 0x02 && wValue == 0) {
			i = wIndex & 0x7F;
			if (i >= 1 && i <= MAX_ENDPOINT) {
				usb_send_in();
				UENUM = i;
				if (bRequest == SET_FEATURE) {
				} else {
					UECONX = (1<<STALLRQC)|(1<<RSTDT)|(1<<EPEN);
					UERST = (1 << i);
					UERST = 0;
				return;
		#endif
		if (wIndex == GAMEPAD_INTERFACE) {
			if (bmRequestType == 0xA1) {
				if (bRequest == HID_GET_REPORT) {
					rep_type=(wValue>>8);
					rep_id=wValue&0xFF;
					switch(rep_type) {
					usb_send_in();
					return;
				if (bRequest == HID_GET_IDLE) {
					UEDATX = gamepad_idle_config;
					usb_send_in();
					return;
				if (bRequest == HID_GET_PROTOCOL) {
					UEDATX = gamepad_protocol;
					usb_send_in();
					return;
			if (bmRequestType == 0x21) {
				if (bRequest == HID_SET_REPORT) {
					rep_id=wValue&0xFF;
					switch(rep_type) {
						// set OUTPUT report
						case 0x02:
						// handle the SetControlValue report
						if (rep_id == UCOM_RPTID_SET_CONTROL_VALUE)
							uint8_t tmp=UEDATX;
						break;
						default: break;
					usb_wait_receive_out();
					usb_ack_out();
					usb_send_in();
					return;
				if (bRequest == HID_SET_IDLE) {
					gamepad_idle_config = (wValue >> 8);
					usb_send_in();
					return;
				if (bRequest == HID_SET_PROTOCOL) {
					gamepad_protocol = wValue;
					usb_send_in();
					return;
	UECONX = (1<<STALLRQ) | (1<<EPEN);	// stall
(I am apparently a newb that has no idea why the <code> tag has decided my code is all commented)
But I'm not sure what you're saying?  What comments?
I did use that...  I may be incorrectly assuming it would color the code in a meaningful way.
Yup!  The editor happily colours your code, but the viewer does not.  Long-standing complaint around here...
Ah, thanks.
I also forgot to mention that the fuses are identical (e-0xf4,h-0xd9,l-0xff)
What happens if you load the unmodified uno code on the chip, does it work then?
As it's a 16U2 have you considered something LUFA based for starters? As the code is guaranteed to work then any mis-behaviour is almost certainly a fault in your hardware.
Jim, if you mean dumping a working UNO's 16u2 into file and flashing my board's 16u2 with it; then 'yes, I have done that' and 'no, it doesn't work'
I am guessing there is a "everyone knows you have to ____ first, duh" that is in no document anywhere that I can find.
And fuses?
If the UNO's 16u2 was locked, then it won't work anyway.
The fuses are identical to a working UNO, as previously mentioned.  As to ' If the UNO's 16u2 was locked, then it won't work anyway. '  I am unsure what you are saying.  Can't read a locked chip?  Or what...
This.
OK, yes, I had confirmed that it isn't locked and that the file actually contains binary as expected.  Also, I have used many other firmware files for the 16u2 as provided in most UNO projects (for 'going back to an Arduino') and, of course,  ......\arduino-1.8.5\hardware\arduino\avr\firmwares\atmegaxxu2\....
I have multiple examples of my board, bread boarded UNO layouts, and minimal 16u2 layouts...  none of them will be recognized by a PC as a USB device when flashed with known-good firmware, and fuses are set to what a working UNO is set to.  There is almost certainly a missing, simple thing that I do not know.
...or some repeated error I am making in each and every iteration.
Perhaps there is data in the EEPROM that is needed as well, perhaps VID/PID or configuration data???
Jim,
That is certainly the case with my project (and I do write it).  When I read a working UNO, though, the eep appears blank.  If that is not *supposed* to be the case, it could certainly be the issue...  as I do not write the eep when testing the working UNO firmware.  Anyone know for sure?
I have checked many times now... it is not the eep.
[deleted]
This may be a stupid question but did you put the Zeners on the right way? If you put them the wrong way they'd short D+/D- to GND which would prevent USB from working.
They should be oriented with the Cathode on the D+/- side and the anode to GND
LIV2, not a stupid question as it would be an answer to the issue.   I also had not confirmed that on every board.  I have now, though, and it is not the issue.
Still stalled on this...  hiring smarter people than me to take a look.  I will post my error when it is figured out.
