Controlling relays using ESP32
5 posts / 0 new
I am working on a predictive vibration alert monitoring system, for this, I am using a vibration sensor, Ubidots, Esp32, and relay. I am able to create an alert by controlling the relays and sending an email alert. Also able to control 4 channel relay using Esp32 but can you suggest me how to control 50  relays using esp32, by a basic example.
Who makes that chip? Not many here would know much about it.
One way of controlling that many relays would be 8 bit port latches (8 bit data port) with another 8 bit to control which chip get addressed.
Another way may be to use serial latches.
Use. A 100 pin XMEGA and relay drivers. Connect the USART of XMEGA to esp32. Or two mega2560s. Connect the Megan's together via usart1, then connect one of them to esp32 via its usart0
you ask about esp32 on a avr site?
Anyways, for 50 relays off 1 esp32, use a chain of tpic6b595 chips. You’ll need 7 of them. Then you’ll need a 74hct367 for the logic level translation. There should be heaps of examples for Arduino on the web.
Serial drivers would be the best way, IMO. Allegro used to make some dedicated serial lamp/relay drivers, but I'm not sure if they're still available. You might have to use logic level shift registers with additional driving circuitry, e.g. FETs/transistors or ULN200x  driver chips.
I see MAX4820 comes up when I search for serial relay driver, but I have no personal experience of those, whereas I have used the Allegro parts in the distant past.
