Interrupt driven USART only transmitting one character and garbage afterwards
12 posts / 0 new
Hi all,
Using an atmega644pa, 16Mhz, 5V
I followed the interrupt driven USART receive tutorial which seems to be working for one character at a time. @ 115200 baud rate.
The transmit function works perfectly.
But I am having trouble receiving more than 3 transmitted characters from a string. For example:
It works with 1 character at a time:
I am using the arduino serial monitor to send and receive characters, could that be the problem?
but when I want to print "three" I get some of the first characters and some garbage after it:
void init_USART0() {
  unsigned int number = (F_CPU)/(16*(BAUD0)-1);
  UBRR0H = (unsigned char)(number>>8);
  UBRR0L = (unsigned char)number;
  UCSR0B = (1<<RXEN0)|(1<<TXEN0)|(1 << RXCIE0);// Enable receiver and transmitter
  UCSR0C = (1<<USBS0)|(3<<UCSZ00);// Set frame format: 8data, 2stop bit
void transmit_USART0(char c) {
  while (!(UCSR0A & (1<<UDRE0))); //Wait for empty transmit buffer
  UDR0 = c;
unsigned char USART0_Receive(void){
  while (!(UCSR0A & (1<<RXC0)));
  return UDR0;
ISR(USART0_RX_vect){
   transmit_USART0(USART0_Receive());
int main(){
  sei();
  init_USART0();
joshagirgis wrote:
int main(){
  sei();
  init_USART0();
You don't want main() to end, and add a loop forever.
Also, best to enable interrupts after initializing.
int main(){
  init_USART0();
  sei();
  while(1);  // wait forever
Thanks for the edits:
Same issue persists:
Sending "Three" yields: "TK⸮⸮"
Interrupts and polling??
polling??
Not sure what you mean.  I apologize for my ignorance!
I am using an interrupt instead of just synchronously grabbing the characters.
This should be:
unsigned int number = F_CPU/16/BAUD0 - 1;
Even better, set the U2X bit and change 16 to 8 in the calculation.
--Mike
  return UDR0;
Should be:
//  while (!(UCSR0A & (1<<RXC0)));
  return UDR0;
avr-mike wrote:
This should be:
--Mike
F_CPU/16/BAUD0 - 1 is incorrect for some reason.
I can only transmit at 115200 baud for
#define BAUD0 115200
This added no effect on the issue :/
I think with the interrupt that while loop is redundant but does not repair the issue.
This is with a different terminal program:
I set U2X and changed it to 8. And that fixed it.
Oddly enough just using F_CPU/16/BAUD0 - 1; and just asynch normal mode didn't work, it only worked with (F_CPU)/(16*(BAUD0)-1); but not for receiving, hence this post.
I suppose the UART wasn't working fast enough or at a close enough baud??\
anybody know why?
This ISR() will wait for the transmit to finish before it can service the next received char, as you have a blocking transmit routine.
Keep your ISR() short and fast, do not wait or delay.
I posted this already quite recently.
If you want a macro for calculating UBBR then why not just take the one form util/setbaud.h, which has rounding up/down.
(Or even you could actually use setbaud.h)
U2X = 0
#define UBRR_VALUE (((F_CPU) + 8UL * (BAUD)) / (16UL * (BAUD)) -1UL)
or U2X = 1
#define UBRR_VALUE (((F_CPU) + 4UL * (BAUD)) / (8UL * (BAUD)) -1UL)
Your  macro happens to give 8 (but can give non optimal value for other baud rates).
If you use F_CPU/16/BAUD0 - 1 (ie. withour rounding up/down) you get 7.
With rounding you get 8.
8 is the optimal value for UBBR but it's not very optimal for 16MHz without U2X, it has 3.5% systematic error, that's getting borderline.
With U2X and UBBR=16 the error is 2.1%, more likely to work.
This is all in the datasheet (I'm looking at mega328 datasheet, assuming it is the same for your chip).
