Attaching to Target
11 posts / 0 new
Is there a way to attach the debugger to a target that already has code in Flash? Everytime I open a COF file, it erases and overwrites the flash, thus wiping anything already there.
For example, I'm trying to test the bootloader/firmware interaction. We use the bootloader for field firmware upgrades and we want to return to the bootloader if an upgrade is initiated. If I load the bootloader, then use the bootloader to load the application, I can't do any source level debug of the application. And vice-versa, if I load the application, I can't do source level debug of the bootloader.
I tried disabling the JTAGICE mkII options (i.e. "Don't reprogram device" under the Program Download options), but it always does.
Any suggestions?
Pete
I hate to say this, but "it works for me". I did have problems with this, but I found that I had to change the JTAGICE mkII options while I was IN debug mode.
A couple of other things to look at/try: Are you running the latest version of AVRStudio 4 with Service Pack 4? Also, which device are you trying to debug (although I don't think that matters).
Keep trying. It really does work!
Stu
...which obviously poses a chicken-and-egg problem. If you've got a
device with valuable firmware you wouldn't like to destroy, but didn't
run that option dialog once before, and unchecked that option, but
want to debug a particular device without destroying it *right now*,
you're at a loss.
Jörg Wunsch
But wouldn't it be possible to use the JTAG programming (not debugging) facilities to read the current code to a hex file before trying to make this switch? If the debugger then downloaded the new image it wouldn't matter.
Cliff
Still sounds like a crock to me.
With AVaRICE, I can even attach to a completely running target without
restarting the target code. Useful if you've got an application in the
field that is "free-running", but notice it went astray after 24 hours
of operation, so you'd like to see what happened.
Jörg Wunsch
Ok, I figured it out.
The problem is that I need to configure a project, turn off the program download, then when re-connecting to the target, open the project file (.aps) instead of the COF.
I was always opening a COF, which creates a new project, which by default reprograms the device. So I'm now using the project files instead.
I agree with dl8dtl, one must be prepared for such a scenario with a pre-configured project. At least make it an option at project creation time. Having to whack a chunk of firmware before being able to connect can be problematic.
And dl8dtl is right again by indicating irritation over the resetting of the target. It is a much more complex process to debug targets when I have to reset them, run until I get a strange failure (assuming it is easily repeatable), then see where things are. I would like the ability to just attach, halt the processor, look at things, and then detach and have the program continue.
Those two things would be my #1 and #2 suggestions for the next release of AVR Studio (assuming #2 is a software issue, i.e. not a requirement when connecting via JTAG).
But things are working fine for me now that I understand the setup. Thanks for the replies!
It must be, because as I wrote, AVaRICE (which also uses the JTAG ICE) *can* handle
it.
Jörg Wunsch
dl8dtl wrote:
It must be, because as I wrote, AVaRICE (which also uses the JTAG ICE) *can* handle it.
I have noticed that when I attach the JTAG ICE mkII to my running app, it will occasionally reset the app. My assumption has been that I get a glitch on the reset line.
Have you see this, Joerg?
Stu
No, I haven't so far, but it only happens once in a while that I
need to re-attach an ICE to a running application. Normally, the
ICE is not supposed to pull the reset line unless being instructed
so.
Jörg Wunsch
dl8dtl wrote:
With AVaRICE, I can even attach to a completely running target without restarting the target code. Useful if you've got an application in the field that is "free-running", but notice it went astray after 24 hours of operation, so you'd like to see what happened.
Can I trouble you for the exact sequence/setup you use to do this?
I have a need to attach to a running target in the field.
So far "Attach to Target" has always been grayed out for me.
Interface: JTAG
Studio: 7.0.1188
Processor: ATMega1284P
I have tried turning off "use external reset" and using "skip programming" to no avail ...
Chuck Hackett
12.5 years?  Nearly a record!
