Hi all,
I was curious if there was a way to split amps among step-up transformers. What I mean by this is that, for example, let's say I have a input of 20V 40Ah and two transformers that can ramp up the voltage to 40. Only problem is that the transformers have a constant intake limit of 20 amps per transformer. Is there any way to divert the amps going to each transformer so that each transformer is supplied with 20V 20Ah? If that is achievable, could I simply wire the ends of the transformers together to combine the total amps or will that result in system failure?
Thank you.
