USB Type C PD Sink IC
8 posts / 0 new
I need an easy to use IC that can provide 15V@3A through USB type C. I found the STMicro STUSB4500 IC, which looks perfect but it seems limited to 30W max. Anyone have suggestions?
toalan wrote:
Are you looking for something that can provide 15v 3A through a USB C cable, or are you looking for something you plug into your computer and produce 15V 3A?? If so that's 45W, and I believe a USB 3.0 port will only put out 5W max if I remember correctly.
This is USB type C which is rated for upto 100W at multiple voltages. I need an IC that can talk to the power delivery IC at the other end of the usb cable.
USB-PD though it's also BCR (Barrel Connector Replacement); new arrivals at Mouser with an ETA of 1-July'19.
CYPD3177-24LQXQ Cypress Semiconductor | Mouser
EZ-PD™ Barrel Connector Replacement - Cypress | Mouser
900mA default; swap resistors to reach the 3A requirement.
The EK has the load switch PFET; major parts to acquire are a USB Type-C cable and a USB PD wall wart.
EZ-PD™ Barrel Connector Replacement (BCR)
TY,
Being a heavy user of Cypress PSOC 1 uCs, I really should have looked at Cypress. The internet saves the day again.
Power Your Next Product With Any USB-C Power Adapter
Date: Thursday, July 11, 2019
Time: 11:00 AM Eastern Daylight Time
Sponsors: Mouser Electronics, Cypress and Molex
Event Type: Hands-on Virtual Training Workshop
Duration: 90 Minutes
Participants are highly recommended to purchase a Cypress EZ-PD BCR Dev Kit (CY4533)  and Molex USB Type C connector from Mouser to follow along, step by step in this live workshop.
Well, although that it may be not related but I suppose you are using a Li-ion battery, in that case you can use a Li-ion battery charger IC and it will take care of that. check Richtek they have some options...
