GCC Preprocessor Capabilitiy?
18 posts / 0 new
Greetings -
Don't have access to AS7 for a while so I can't do the simple "try it and see if it works". I need to implement a DSP filter for 3 axes of accelerometer data. The starting point for the filter coefficients is:
X = 256 * exp( -2 * PI * Fcorner )
The resulting value is a run-time constant so it would be really nice to be able to do something like:
#define FCORNER   0.01      //corner frequency in Hertz
#define PI  3.1415
#define XFIL 256*exp(-2*PI*FCORNER)
BUT, I suspect that exp() is only available via AVR-libc and so is not available to the preprocessor. I can always just do
#define XFIL 35     //coefficient for 0.01Hz corner
So, the question is whether or not the preprocessor is capable doing the computation in the first example, or is it necessary to resort to the second one?
Thanks for your help!
I think the only time the preprocessor itself does any arithmetic is if you have
#if expression
where expression will be an integer constant expression that is actually evaluated by the preprocessor.
Otherwise, when you have somethig like
#define X (10 + 30 - 50)
int x = X;
the preprocessor isn't doing any maths, it's simple text replacement into the code wherever you use X
int x = (10 + 30 - 50);
and the compiler will then evaluate it.
The compiler will  work out that  it's a constant expression with value -10.
But you can't have a constant expression that includes a function call, in that case it will have to be evaluated at runtime by calling exp().
So I think you are stuck with calculating the value yourself, like in your second example.
You can precompute the value with an external tool, auto-generated a .h, all handled by the Makefile. The external tool can simply be a host-based C program, or python, or...
I thought the preprocessor was"dumb"  in that it only treat this as text---it does not "understand" any data types.
bty the way, whyt type of filter are you trying to create?
Joey: basically doing what you suggest.
avrcandies: Creating a high-pass filter to separate out relatively small acceleration changes from background gravity, in order to implement a "record trigger" function. The filtered data only drives the trigger algorithm and is never recorded. My reference is "The Scientist and Engineer's Guide to Digital Signal Processing" by Steven Smith, Chapter 19 (Recursive Filters). It is available on-line for free download, chapter by chapter. Highly recommend.
As others have pointed out the preprocessor only does text replacement. The compiler can then fold constants where possible.
If you were using C++11 or later you could use constexpr variables and functions to force compile time computation. This would require you to roll your own constexpr version of exp().
namespace Foo {
constexpr float exp( float arg ) noexcept
    // some implementation
constexpr auto FCORNER = 0.01;
constexpr auto PI      = 3.1415;
constexpr auto XFIL    = 256 * exp( -2 * PI * FCORNER );
} // Foo
build-avr-gcc: avr-gcc build script
toolchain-avr-gcc: CMake toolchain for cross compiling for the AVR family of microcontrollers
avr-libcpp: C++ standard library partial implementation (C++17 only) for use with avr-gcc/avr-libc
picolibrary: C++ microcontroller driver/utility library targeted for use with resource constrained microcontrollers
picolibrary-microchip-megaavr: picolibrary HIL for megaAVR microcontrollers
picolibrary-microchip-megaavr0: picolibrary HIL for megaAVR 0-series microcontrollers
Really (really) short on code space. Going with #define numeric values.
Thanks, wonderful!  Sad, since now I will spend some hours (that I'm lacking) wanting to read this book.  By the way, I don't think XFIL=35 is correct, I got some other value (256*0.939)...but perhaps I'm sleeping in the weeds.
There is an online compiler where you can try out ideas when you don't have access to your own compiler-
https://godbolt.org/
I use it when I quickly want to try something out. Its usually not that important which compiler is chosen as long as its the same family (gcc). I usually just use the x86-64 compiler as you can see the printf output that way by turning on the a.out option.
I'm not sure why you would need to roll your own. You can use the math.h version of exp(), and also use M_PI from math.h while you're at it. The compiler will certainly let you know when it cannot return a compile time value.
https://godbolt.org/z/9zm91b
I did a quick test of what you posted (with a slight modification) using avr-gcc/avr-libc and it worked but it seems the compiler is able to do some strange/surprising stuff with standard library functions in constexpr contexts. Namely, avr-libc's math.h does not define exp() inline yet somehow it was still able to use it in a constexpr context. If I try to do something similar with a user defined function the compiler insists that it is declared constexpr and defined inline.
Yes, gcc has a large number of builtin functions, so they can all be used in constexpr.
https://gcc.gnu.org/onlinedocs/g...
I found out about this feature some time ago: https://www.avrfreaks.net/forum/...
This is a power far, far beyond what the preprocessor can do.
FYI - That number, XFIL=35, was picked randomly, out of the weeds. Only intended to show concept.
I was not aware that gcc had that. Thanks for the info.
The math library is part of the standard.
The compiler is allowed to know what exp does without
needing to look at the source or even the binary.
It can therefore make exp(10) into a compile-time constant.
One problem with this is that with math functions,
what the compiler knows can be wrong.
Different math libraries might get different values for exp(10).
If you don't have access to AS7, you can still play with the avr compiler at the command line (easy enough to get, unless you are for some reason tied to a work pc that is restricted, I suppose, or maybe you on a beach typing away on an ipad- but then why are you doing any math on a beach).
#include <math.h>
#define XFIL 256*exp(-2 * M_PI * FCORNER)
//or this
//#define XFIL 256*__builtin_exp(-2 * M_PI * FCORNER)
int main(){
    volatile int x = XFIL;
    for(;;){}
 ./avr-gcc -Os test.c
 ./avr-size a.out
 text    data     bss     dec     hex filename
   20       0       0      26      14 a.out
 ./avr-objdump -d a.out
 Disassembly of section .text.startup:
00000000 <main>:
   0:   cf 93           push    r28
   2:   df 93           push    r29
   4:   00 d0           rcall   .+0             ; 0x6 <__zero_reg__+0x5>
   6:   cd b7           in      r28, 0x3d       ; 61
   8:   de b7           in      r29, 0x3e       ; 62
   a:   80 ef           ldi     r24, 0xF0       ; 240
   c:   90 e0           ldi     r25, 0x00       ; 0
   e:   9a 83           std     Y+2, r25        ; 0x02
  10:   89 83           std     Y+1, r24        ; 0x01
  12:   ff cf           rjmp    .-2             ; 0x12 <__zero_reg__+0x11>
You can see the value (240) is loaded into the var x (on the stack), so you can use defines/macro in this case without having to pre-compute.
There is probably a lot more of that going on than we realize. The above example also works when using __builtin_exp() (don't even need math.h), so even when using what we think is the library version we get the built in version.
Oh, so the gcc compiler is smarter than I thought!
After a bit of experimenting, If you compile with -fno-builtin, then it does produce code that includes the run time call to exp(), which is what I thought it would have to do in all cases, but clearly not.
If you are going to rely on the compiler not having to do the run time call, probably worth checking the generated code to make sure it has optimised.
There is also an older, complete version available for download from Analog Devices: https://www.analog.com/en/educat...
