Printing a float to the USART with at least 5 decimals
17 posts / 0 new
Hi All, I am trying to print a float to the serial monitor and am having so much trouble.
ATMEGA644PA@ 5V,16MHz
Baud rate is 115200
transmit_USART0 works fine but I want to print a float.
void init_USART0() {
  unsigned int number = (F_CPU)/(16*(BAUD0)-1);
  UBRR0H = (unsigned char)(number>>8);
  UBRR0L = (unsigned char)number;
  UCSR0B = (1<<RXEN0)|(1<<TXEN0);// Enable receiver and transmitter
  UCSR0C = (1<<USBS0)|(3<<UCSZ00);// Set frame format: 8data, 2stop bit
void transmit_USART0(char c) {
  while (!(UCSR0A & (1<<UDRE0))); //Wait for empty transmit buffer
  UDR0 = c;
void printNum_USART0(float data, int presc, bool ln){
  char buffer [43];
  dtostrf(data,presc+4,presc,buffer);
  for (int i=0; i<43; i++) {
   transmit_USART0(buffer[i]);
 if (ln) transmit_USART0('\n');
dtostrf(data,presc+4,presc,buffer); does the heavy lifting here and is probably the problem
When I call:
float i =-123456.12345;
    printNum_USART0(i,4,true);
I get -123456.1300 in the serial port.
float i =-1234567.12345;
I get -1234567.1000 in the serial port.
float i =-12345678.12345;
I get -12345678.0000
It's like every time I increase the size of the number it rounds the decimal points no matter the precision or character width.
I've tried using sprintf( and its family AND the floating point version, but can never get past 2 decimals
Additionally my buffer is 43 in size. so it prints garbage like: -12345678.0000 ╟╟
How can I remove that?
32bit IEEE754 float can only convey 7.5 digits of decimal accuracy. You are expecting too much.Maybe consider a compiler with 64 bit double.
I am using avr-gcc/++
Is that not enough?
joshagirgis wrote:
Is that not enough?
Does your example number have more than 7 significant digits?
I understand the 32bit limitation. Wondering if there is anyway to get a 64bit double.
Judging from your post I don't suppose avr-gcc would do that.
To answer your other question
dtostrf creates a null terminated string in buffer.
You could do
for (int i = 0; i < 43 && buffer[i] != 0; i++) {
but it would be more normal to create a 'transmit_string' function and call that  instead eg.
void transmit_string_USART0(const char *buf)
    while (*buf)
        transmit_USART0(*buf++);
That's a good way of doing it. Thank you
Reason I mentioned "other compilers" is that Imagecraft Pro and IAR bother offer 64 bit double. Make sure you are sitting down when you read the price tags!
IAR is too embarrassed to even put the price on their website.
--Mike
double in avr-gcc is 32 bits
$ avr-gcc -dM -E - </dev/null | grep DOUBLE
#define __SIZEOF_LONG_DOUBLE__ 4
#define __SIZEOF_DOUBLE__ 4
There is a 64-bit FP library that can be used with AVR GCC, but it is not fast, and it is not small.
I'm on a phone, don't have the link.
I always start with the question "do you >>really<< need FP? Really?"
Probably not, but I was too stupid to realize that :/
I'd love to look at that link though!
Too many users don't look carefully at the problem, and just jump into using bloating point, when integers would do a much better job.
You pay the price in performance & code space.  Keep bloating calculations as the backup plan, but try integer methods first.
https://www.avrfreaks.net/comment/2299006#comment-2299006
Rowley has always had 64-bit doubles.    However they lost interest in their C compiler several years ago.    So you are stuck with with regular Tiny, Mega, Xmega and associated tools.
Quite honestly,  you can get good enough accuracy if you do your float calculations in the right order.
Or use integer maths and scale afterwards.
The common scenario is GPS calculations.     There is plenty published about how to do the maths with float.
I'll play around with this!
Fair enough.
But your time might be better spent re-examining your approach, this time with integers.  As mentioned, one of the very few applications which genuinely benefit from FP is GPS, and even that can avoid FP.
Still, always fun to play with a new library ;-)
