ATmega32 External Clock Not Working
11 posts / 0 new
I have an ATmega32 which I'd like to use with a 16 MHz crystal clock oscillator. I didn't have a problem until I set the low fuse from 0xE1 (internal 1 MHz) to 0xE0 (external). Then I connected a 16 MHz clock oscillator between XTAL1(12) and XTAL2(13) and two 22 pF capacitors between ground and those pins. This setup has worked for me before every time but this time it didn't work. I got the classical bad connection error on the USBASP. Then I set an ATmega8A with the clock and connected its clock signal output (connected to XTAL1) to the XTAL1 of the ATmega32. And it worked! So I'm assuming that the oscillator's amplifier circuit is broken or is it the fuses? Please let me know if you've ever had such a problem with similar AVRs.
There is a difference between an oscillator and a crystal. An oscillator module has only one output and the 22pF are not needed. If you have connected a crystal, be sure to set the fuses for an external crystal not oscillator.
It says External Clock; Start-up Time 6 CK + 64 ms; so I guess it is a crystal?
Clock != Crystal
If it's a little metal can with 2 legs it's almost certainly a "crystal".
You can use the mega8 to repair the damage - while it provides the clock do ISP again to either put things back to the way they started or to go direct to the CKSEL choice for "crystal" nor "external clock".
External xtal:
or external clock:
Which are you really using?
Is there any way to use the crystal oscillator configuration for ATmega32? Or do I use the classical single transistor amp circuit?
Ohh I see. I didn't see that the list on the fuse calculator goes down. smh. Which one should I choose? High or the medium frequency?
Choose 8-16MHz xtal.
But the important lesson is:
crystal has 2 pins
ceramic resonator has 3 pins
clock module has 4 pins (sometimes 6 pins)
david.prentice wrote:
crystal has 2 pins  and needs two 18pf caps
ceramic resonator has 3 pins  the caps are built in, so none are needed
clock module has 4 pins (sometimes 6 pins) no caps, but module needs vcc/gnd
bold notes added.
Thanks. I absolutely know what's going on with those. I only got confused when I saw the External Clock option and I didn't understand that they meant a complete oscillator circuit. I think this will be helpful the others who are in confusion too.
This is such a common problem. Probably averages one a week or more, through the year. Big surge when university projects are due!
