wait till a input pin is high
11 posts / 0 new
hallo,
i have (i think) a small problem to do a simple job in the program. i just don't see it.
i want a byte shift out the AVR on a output pin (serieel), in cooperation whit a clock puls on a input pin.
i isolate a bit out of the byte, but before i can shift him to the output pin i have to wait till the clock pulse is high.
and that waiting is the problem, i just don't see how to do this frown
     while (1)
		for (j=0;j<8;j++)
			if ((byte & 0x80)==0x80)
// I HAVE TO WAIT HERE TILL THE CLOKPULSE IS HIGH *********************************8
				PORTB |= (1 << PINB4); // make B4 1
				PORTB &= ~(1 << PINB4); // make B4 0
			byte = (byte <<1);
What port pin is the "clock" signal coming in on?
How clean is the signal, in other words, do you need to debounce the clock input?
i don't need a debounce, the clock is comming from another AVR. on pin B3.
Ok,so you will have code that looks similar to this:
while((PINB & PB3)  ==  0) ; //wait here while clock is low
     //now clock is high
while((PINB & PB3) > 0); //wait here while clock is high
     //now clock is low
The important fact is that you use the PINB register to read the input status of the various pins in PortB. You use PORTB register to set an output pin high or low, or to turn the pull-up on or off for an input. Reading PORTB for an input pin just tells you the status of the pull-up resistor on or off!
yes,..... the while function will do the job, thanks.
jim also thanks for the info yes
Ok, time for the dumb question...or two...
I don't know which AVR you are using, so I am gonna use the Mega328 as its pretty popular, but most AVRs have the same characteristics
Since this is synchronous communications, WHY are you making your life so difficult?  Unless this is a school assignment and your teacher is requiring your life to be difficult.
The AVR has not one, but TWO SYNCHRONUS data transfer engines on it
The SPI engine
The USART engine (running in synchronous mode)
Either one can be the source of the clock(master), or in your case where the clock come from someplace else a slave.
The datasheet tells all.
So why, why, oh why make your life so difficult?
East Coast Jim
Just one small correction in the above: By:
Jim really meant:
while((PINB & (1 << PB3))  ==  0) ; //wait here while clock is low
jgmdesign wrote:
Ok, time for the dumb question...or two...USART engine (running in synchronous mode)
East Coast Jim
this is a small part of a big project, i think i need the USART & SPI later for some other things.
What AVR are you using?
SPI can operate as one of several 'slaves' if you know how to use it properly.
JIm
atmega32
its a little bit complicated, but i gonna use this program for testing a another prog in a atmega 128.
later the bits are comming from a "scanner" (IR transmitter/receiver) that have as output a 300 bits bittrain.
but for testing the program in the 128 it is not easy to use this scanner, so i gonna simulate this bit train whit the atmega32.
there i want to put in a look-up table the bytes that normal coming from the scanner, and these bytes i have to shift out of the atmega32.
