FatFs AtMega328P
16 posts / 0 new
Hello everyone, I'm new here.
I want to create a TXT or CSV file in a SD Card with FatFs library and the ATMEGA328P; i've tried with some examples but i haven't gotten anything sad. I've tried some tutorials and used older versions (http://web.archive.org/web/20150715053300/http://elm-chan.org/fsw/ff/ffsample.zip) because i read in this post that newer versions have some problems ( https://www.avrfreaks.net/forum/implementing-fatfs-library-avr-micro). Also I tried to configurate it by myself but honestly i dont understand how to do it for this microcontroller, whenever i tried i got the following error: id returned 1 exit status collect2.exe.
The closest I was to achieving it was using another library, with this one I could create the file but I coudn´t write into it (https://www.dharmanitech.com/2009/01/sd-card-interfacing-with-atmega8-fat32.html).
Please if anyone could help me to configurate the library or with an example it would be fantastic (i don't want to use Arduino Software).
Thanks guys.
PostScript:
Sorry, I think this is not the correct forum but I don’t know how to move my publication.
FatFs works very well for most of us so you should probably try to diagnose why there's a problem for you.
Thank you por reply
Do you know any tutorial? I repeat, I don't know how how to solve this error: id returned 1 exit status collect2.exe
That is not the whole error. Quote the WHOLE error (not that pointless "error list" thing). I'm guessing it's really just an undef ref?
With only 2K of SRAM, wouldn't it be sort of tight to try to do a full FATFS implementation?  Maybe PetitFS would be more workable?
FatFs is fine in 2K
I've read this interesting tutorial:  https://www.avrfreaks.net/forum/tut-c-getting-sdmmc-card-working-painlessly-fatfs  and used a code based on a ATmega1284p (https://github.com/jambu-aj/FatFS )
I already tried to configurate my SD pins into diskio.c. My SD pins are SLK-PB5, MISO-PB4, MOSI-PB3 and SS-PD4
#define SS        (1<<DDD4)
#define MOSI    (1<<DDB3)
#define MISO    (1<<DDB4)
#define SCK        (1<<DDB5)
#define CS_LOW()    PORTD &= ~SS        /* CS=low */
#define    CS_HIGH()    PORTD |= SS            /* CS=high */
#define SOCKINS        (!(PINB & 0x02))    /* Card detected.   yes:true, no:false, default:true */
#define SOCKWP        (PINB & 0x01)        /* Write protected. yes:true, no:false, default:false */
#define    FCLK_SLOW()    SPCR = 0x52        /* Set slow clock (F_CPU / 64) */
#define    FCLK_FAST()    SPCR = 0x50        /* Set fast clock (F_CPU / 2) */
Also i configurated this part in diskio.c:
/* Power Control  (Platform dependent)                                   */
/* When the target system does not support socket power control, there   */
/* is nothing to do in these functions and chk_power always returns 1.   */
static
int power_status (void)        /* Socket power state: 0=off, 1=on */
    return 1;//(PORTE & _BV(7)) ? 0 : 1;
static
void power_on (void)
    PORTB |= MOSI;    /* Configure SCK/MOSI/CS as output */
    PORTD |= SS;
    DDRB  |= MOSI|SCK;
    DDRD |= SS;
    /* Enable SPI, Master, set clock rate fck/16 */
    SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0);
static
void power_off (void)
    SPCR = 0;                /* Disable SPI function */
    DDRB  &= ~(MOSI|SCK);    /* Set SCK/MOSI/CS as hi-z, INS#/WP as pull-up */
    DDRD  &= ~(SS);    /* Set SCK/MOSI/CS as hi-z, INS#/WP as pull-up */
    PORTB &= ~(MOSI|SCK);
    PORTD  &= ~(SS);    /* Set SCK/MOSI/CS as hi-z, INS#/WP as pull-up */
The main code is this, it already complies but gets stuck in f_open.
// External 16MHz crystal
 #define F_CPU 16000000UL
 // Define baud-rate of the serial port
 #define BAUD 9600
 #define MYUBRR F_CPU/16/BAUD-1
#include <string.h>
#include "ff.h"
#include "diskio.h"
FIL file;                                               /* Opened file object */
FATFS *fatfs;                                            /* File system object */
DIR dir;                                                /* Directory object   */
FRESULT errCode;                                        /* Error code object  */
FRESULT res;                                            /* Result object      */
UINT bytesRead;                                         /* Bytes read object  */
UINT read;                                              /* Read bytes object  */
int result=1;
char buff[] = "helloworld";
int buff_stat;
// function to initialize my USART port on the ATMEGA328P
void USART_Init(unsigned int ubrr)
    // Set baud rate
    UBRR0H = (unsigned char)(ubrr>>8);
    // Set frame format to 8 data bits, no parity, 1 stop bit
    UBRR0L = (unsigned char)ubrr;
    // Enable receiver and transmitter
    UCSR0B = (1<<RXEN0)|(1<<TXEN0);
    // Set frame format: 8data, 1 stop bit
    UCSR0C = (1<<UCSZ00) | (1 << UCSZ01);
// function to transmit/TX stuff out of the ATMEGA328P and into my laptop
void USART_Transmit(unsigned char data)
    // Wait for empty transmit buffer
    while ( !( UCSR0A & (1<<UDRE0)) );
    // Put data into buffer, sends the data
    UDR0 = data;
// function to transmit/write a whole null terminated string to serial port
void serial_write_str(char* str)
    while(*str != 0x00) {
        USART_Transmit(*str);
        str++;
        USART_Init(MYUBRR); // initialize USART
        serial_write_str("PORGRAM INIT\r\n");
        errCode = f_mount(0, &fatfs);                       //mount drive number 0
        if(errCode == FR_OK){
            serial_write_str("F_MOUNT\r\n");
        errCode = f_opendir(&dir, "/");                        //root directory
            serial_write_str("F_OPENDIR\r\n");
        errCode = f_open(&file, "/data.txt", FA_CREATE_ALWAYS | FA_WRITE);
            serial_write_str("F_OPEN OK\r\n");
        else {
            serial_write_str("F_OPEN FAIL\r\n");
        serial_write_str("FINISH!\r\n");
    while(1){
 This is the complete ZIP, any clue? The tutorial also says that i need to configurate this part in mmc.c
/*SPI configuration*/
#define DD_MOSI	DDB5
#define DD_SCK	DDB7
#define DDR_SPI	DDRB
#define DD_SS	4
/* Defines for SD card SPI access */
#define SD_CS_PIN	1
#define SD_CS_PORT	PORTC
#define SD_PWR_PIN	0
#define SD_PWR_PORT	PORTC
 but this example doesn't have it and i couldn't find it in other files (i only have diskio.h, diskio.c, ff.c, ff.h, ffconf.h and integer.h).
Thank you guys.
When I try to build that I see:
		.././GccApplication1_FatFS_SDCard.c: In function 'main':
D:\GccApplication1_FatFS_SDCard\GccApplication1_FatFS_SDCard\GccApplication1_FatFS_SDCard.c(71,24): warning: passing argument 2 of 'f_mount' from incompatible pointer type [-Wincompatible-pointer-types]
This goes back to:
why is this being defined as a pointer to FATFS and not simply an instance of FATFS? Is this because of the example in the user manual?
int main (void)
    FATFS *fs;     /* Ponter to the filesystem object */
    fs = malloc(sizeof (FATFS));           /* Get work area for the volume */
    f_mount(fs, "", 0);                    /* Mount the default drive */
Sure, you have two options here - one is to actually just create one (my preference) the other is to create a pointer to one and then malloc() it (like in the manual). I would not advise that. So just change to:
FATFS fatfs;                                            /* File system object */
(no asterisk).
One thing this shows is that you must NEVER ignore any build warnings unless you 100% know the reason and why it doesn't matter (but in that case you should fix things so it does not occur).
Thank you for your response clawson, now the program partially works, sometimes f_open, f_sync and f_close functions return error and sometimes they return ok (i know that because of the message i send to serial port). Most of times microcontroller creates the file when previusly i create another with Arduino's library and i dont know why. I am testing the Atmel Studio 7's Project in an Arduino Nano with this microSD module ( http://datalogger.pbworks.com/w/file/fetch/89507207/Datalogger%20-%20SD%20Memory%20Reader%20Datasheet.pdf ) and a Class-10 32GB microSD. My SD pins are SLK-PB5, MISO-PB4, MOSI-PB3 and SS-PD4
Let me explain myself better, when i load the AtmelStudio7's Project i only receive (most of times) this messages:
After that, if i load Arduino's SD Library (obviously it always works) with the Arduino IDE to my Arduino Nano these are the messages:
The interesting part comes here, if i load the AS7's Project to the arduino again (without disconnecting) now it works and i can change my program and load it again and it still working
The problem comes when i disconnect and reconnect the Arduino Nano to the computer without changing the AS7 project that previously worked. Surprise when i reconnect the program doesnt work
Any clue?
After solving that silly error (fat object was defined as a pointer) the program was still stuck in f_open so i thought that it could be a problem with the SPI communication, i looked at some libraries and one of them said this:
DDRB |= (1<<PORTB1) | (1<<PORTB2); // CS on pin 9 SS output //SS as output B2 pin 10
In a forum ( https://www.avrfreaks.net/forum/fatfs-atmega328p-16mhz-can-you-use-fatfs-and-avr-example-16mhz-clock-am-i-wasting-my-time) someone wrote this:
IMPORTANT
With AVR8 you must make /SS (PB2) an output or ensure that it is a high input to use master SPI.
When i added (1<<PORTB2) to my SPI-code now it partially works as i told you. Now it looks like this:
static
    {    // Remove this block if no socket power control
        PORTE &= ~_BV(7);    // Socket power on (PE7=low)
        DDRE |= _BV(7);
        for (Timer1 = 2; Timer1; );    // Wait for 20ms
    PORTB |= 0b00001000;    /* Configure SCK/MOSI/CS/SS=(1<<PORTB2) as output */
    PORTD |= 0b00010000;
    DDRB  |= 0b00101000;
    DDRB |= (1<<PORTB2);
    DDRD  |= 0b00010000;
    //SPEED 16MHZ/4, uncomment SPSR = (1<<SPI2X) for 16Mhz/2 speed
    SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0)|(1<<SPR1);    /* Enable SPI function in mode 0 */
    //SPSR = (1<<SPI2X);            /* SPI 2x mode */
 Also I added an interruption with the timer in the main program but honestly i dont know if that is really necessary
ISR(TIMER1_COMPA_vect)
    disk_timerproc();
Here is the complete ZIP in case you want to check it, could the problem be in the SPI communication yet?
Thank you :)
Sounds like you aren't doing SCK speed adjustment during the disk_initialize (but it works if the Arduino stuff has already succeeded in card init)
Excuse me but how can i fix that? frown
I have changed this in my mmc_avr.c, I noted that MMC_WP and MMC_CD were not used in all the mmc_avr.c file
/* Port controls  (Platform dependent) */
#define CS        (1<<DDD4)
#define SS        (1<<DDB2)
#define CS_LOW()    PORTD &= ~CS            /* CS=low */
#define    CS_HIGH()    PORTD |= CS            /* CS=high */
//#define MMC_CD        (!(PINB & 0x10))    /* Card detected.   yes:true, no:false, default:true */
//#define MMC_WP        (PINB & 0x20)        /* Write protected. yes:true, no:false, default:false */
#define    FCLK_SLOW()    SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR0)|(1<<SPR1);        /* Set slow clock (F_CPU / 64) */
#define    FCLK_FAST()    SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR0)|(0<<SPR1);        /* Set fast clock (F_CPU / 4) */
These are my power on and power off functions:
static
        DDRE |= _BV(7);
    PORTD |= CS;
    DDRB  |= MOSI|SCK|SS;
    DDRD |= CS;
    SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR0)|(0<<SPR0);    /* Enable SPI function in mode 0 */
static
    DDRB  &= ~(MOSI|SCK);    /* Set SCK/MOSI/CS as hi-z, INS#/WP */
    DDRD  &= ~(CS);    /* Set SCK/MOSI/CS as pull-up */
    PORTD  &= ~(CS);
    //PORTB |=  0b00110000;
        PORTE |= _BV(7);        // Socket power off (PE7=high)
        for (Timer1 = 20; Timer1; );    // Wait for 20ms
This is my disk_initialize fuction; i don't know if this is correct but disk_initialize function calls first FCLK_SLOW() and after FCLK_FAST() (why this fuction changes the SPI's speed?):
DSTATUS disk_initialize (
    BYTE pdrv        /* Physical drive nmuber (0) */
    BYTE n, cmd, ty, ocr[4];
    if (pdrv) return STA_NOINIT;        /* Supports only single drive */
    power_off();                        /* Turn off the socket power to reset the card */
    if (Stat & STA_NODISK) return Stat;    /* No card in the socket */
    power_on();                            /* Turn on the socket power */
FCLK_SLOW();
    for (n = 10; n; n--) xchg_spi(0xFF);    /* 80 dummy clocks */
    ty = 0;
    if (send_cmd(CMD0, 0) == 1) {            /* Enter Idle state */
Timer1 = 100;                        /* Initialization timeout of 1000 msec */
        if (send_cmd(CMD8, 0x1AA) == 1) {    /* SDv2? */
            for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF);        /* Get trailing return value of R7 resp */
            if (ocr[2] == 0x01 && ocr[3] == 0xAA) {                /* The card can work at vdd range of 2.7-3.6V */
                while (Timer1 && send_cmd(ACMD41, 1UL << 30));    /* Wait for leaving idle state (ACMD41 with HCS bit) */
                if (Timer1 && send_cmd(CMD58, 0) == 0) {        /* Check CCS bit in the OCR */
                    ty = (ocr[0] & 0x40) ? CT_SD2 | CT_BLOCK : CT_SD2;    /* SDv2 */
        } else {                            /* SDv1 or MMCv3 */
            if (send_cmd(ACMD41, 0) <= 1)     {
                ty = CT_SD1; cmd = ACMD41;    /* SDv1 */
            } else {
                ty = CT_MMC; cmd = CMD1;    /* MMCv3 */
            while (Timer1 && send_cmd(cmd, 0));            /* Wait for leaving idle state */
            if (!Timer1 || send_cmd(CMD16, 512) != 0)    /* Set R/W block length to 512 */
                ty = 0;
    CardType = ty;
    deselect();
    if (ty) {            /* Initialization succeded */
        Stat &= ~STA_NOINIT;        /* Clear STA_NOINIT */
FCLK_FAST();
       } else {            /* Initialization failed */
        power_off();
    return Stat;
Also I decided to include a new serial message in my main code to see what was happening with disck_initialize(0) function:
errCode= disk_initialize(0);
    if(errCode == STA_NOINIT){
        serial_write_str("STA_NOINIT\r\n");
and these are the messages that i recieve by serial port:
Again here is the complete ZIP and complete mmc_avr file in case you want to check them out. I'm confused because it works sometimes.
/* MMCv3/SDv1/SDv2 (in SPI mode) control module                          */
/  Copyright (C) 2014, ChaN, all right reserved.
/ * This software is a free software and there is NO WARRANTY.
/ * No restriction on use. You can use, modify and redistribute it for
/   personal, non-profit or commercial products UNDER YOUR RESPONSIBILITY.
/ * Redistributions of source code must retain the above copyright notice.
#include "diskio.h"
   Module Private Functions
/* Definitions for MMC/SDC command */
#define CMD0    (0)            /* GO_IDLE_STATE */
#define CMD1    (1)            /* SEND_OP_COND (MMC) */
#define    ACMD41    (0x80+41)    /* SEND_OP_COND (SDC) */
#define CMD8    (8)            /* SEND_IF_COND */
#define CMD9    (9)            /* SEND_CSD */
#define CMD10    (10)        /* SEND_CID */
#define CMD12    (12)        /* STOP_TRANSMISSION */
#define ACMD13    (0x80+13)    /* SD_STATUS (SDC) */
#define CMD16    (16)        /* SET_BLOCKLEN */
#define CMD17    (17)        /* READ_SINGLE_BLOCK */
#define CMD18    (18)        /* READ_MULTIPLE_BLOCK */
#define CMD23    (23)        /* SET_BLOCK_COUNT (MMC) */
#define    ACMD23    (0x80+23)    /* SET_WR_BLK_ERASE_COUNT (SDC) */
#define CMD24    (24)        /* WRITE_BLOCK */
#define CMD25    (25)        /* WRITE_MULTIPLE_BLOCK */
#define CMD32    (32)        /* ERASE_ER_BLK_START */
#define CMD33    (33)        /* ERASE_ER_BLK_END */
#define CMD38    (38)        /* ERASE */
#define CMD55    (55)        /* APP_CMD */
#define CMD58    (58)        /* READ_OCR */
static volatile
DSTATUS Stat = STA_NOINIT;    /* Disk status */
static volatile
BYTE Timer1, Timer2;    /* 100Hz decrement timer */
static
BYTE CardType;            /* Card type flags */
static
        DDRE |= _BV(7);
    PORTD |= CS;
    DDRD |= CS;
static
    PORTD  &= ~(CS);
/* Transmit/Receive data from/to MMC via SPI  (Platform dependent)       */
/* Exchange a byte */
static
BYTE xchg_spi (        /* Returns received data */
    BYTE dat        /* Data to be sent */
    SPDR = dat;
    loop_until_bit_is_set(SPSR, SPIF);
    return SPDR;
/* Send a data block fast */
static
void xmit_spi_multi (
    const BYTE *p,    /* Data block to be sent */
    UINT cnt        /* Size of data block (must be multiple of 2) */
    do {
        SPDR = *p++; loop_until_bit_is_set(SPSR,SPIF);
    } while (cnt -= 2);
/* Receive a data block fast */
static
void rcvr_spi_multi (
    BYTE *p,    /* Data buffer */
    do {
        SPDR = 0xFF; loop_until_bit_is_set(SPSR,SPIF); *p++ = SPDR;
    } while (cnt -= 2);
/* Wait for card ready                                                   */
static
int wait_ready (    /* 1:Ready, 0:Timeout */
    UINT wt            /* Timeout [ms] */
    BYTE d;
    Timer2 = wt / 10;
    do
        d = xchg_spi(0xFF);
    while (d != 0xFF && Timer2);
    return (d == 0xFF) ? 1 : 0;
/* Deselect the card and release SPI bus                                 */
static
void deselect (void)
    CS_HIGH();        /* Set CS# high */
    xchg_spi(0xFF);    /* Dummy clock (force DO hi-z for multiple slave SPI) */
/* Select the card and wait for ready                                    */
static
int select (void)    /* 1:Successful, 0:Timeout */
    CS_LOW();        /* Set CS# low */
    xchg_spi(0xFF);    /* Dummy clock (force DO enabled) */
    if (wait_ready(500)) return 1;    /* Wait for card ready */
    deselect();
    return 0;    /* Timeout */
/* Receive a data packet from MMC                                        */
static
int rcvr_datablock (
    BYTE *buff,            /* Data buffer to store received data */
    UINT btr            /* Byte count (must be multiple of 4) */
    BYTE token;
    Timer1 = 20;
    do {                            /* Wait for data packet in timeout of 200ms */
        token = xchg_spi(0xFF);
    } while ((token == 0xFF) && Timer1);
    if (token != 0xFE) return 0;    /* If not valid data token, retutn with error */
    rcvr_spi_multi(buff, btr);        /* Receive the data block into buffer */
    xchg_spi(0xFF);                    /* Discard CRC */
    xchg_spi(0xFF);
    return 1;                        /* Return with success */
/* Send a data packet to MMC                                             */
#if    _USE_WRITE
static
int xmit_datablock (
    const BYTE *buff,    /* 512 byte data block to be transmitted */
    BYTE token            /* Data/Stop token */
    BYTE resp;
    if (!wait_ready(500)) return 0;
    xchg_spi(token);                    /* Xmit data token */
    if (token != 0xFD) {    /* Is data token */
        xmit_spi_multi(buff, 512);        /* Xmit the data block to the MMC */
        xchg_spi(0xFF);                    /* CRC (Dummy) */
        xchg_spi(0xFF);
        resp = xchg_spi(0xFF);            /* Reveive data response */
        if ((resp & 0x1F) != 0x05)        /* If not accepted, return with error */
            return 0;
    return 1;
#endif
/* Send a command packet to MMC                                          */
static
BYTE send_cmd (        /* Returns R1 resp (bit7==1:Send failed) */
    BYTE cmd,        /* Command index */
    DWORD arg        /* Argument */
    BYTE n, res;
    if (cmd & 0x80) {    /* ACMD<n> is the command sequense of CMD55-CMD<n> */
        cmd &= 0x7F;
        res = send_cmd(CMD55, 0);
        if (res > 1) return res;
    /* Select the card and wait for ready except to stop multiple block read */
    if (cmd != CMD12) {
        deselect();
        if (!select()) return 0xFF;
    /* Send command packet */
    xchg_spi(0x40 | cmd);                /* Start + Command index */
    xchg_spi((BYTE)(arg >> 24));        /* Argument[31..24] */
    xchg_spi((BYTE)(arg >> 16));        /* Argument[23..16] */
    xchg_spi((BYTE)(arg >> 8));            /* Argument[15..8] */
    xchg_spi((BYTE)arg);                /* Argument[7..0] */
    n = 0x01;                            /* Dummy CRC + Stop */
    if (cmd == CMD0) n = 0x95;            /* Valid CRC for CMD0(0) + Stop */
    if (cmd == CMD8) n = 0x87;            /* Valid CRC for CMD8(0x1AA) Stop */
    xchg_spi(n);
    /* Receive command response */
    if (cmd == CMD12) xchg_spi(0xFF);        /* Skip a stuff byte when stop reading */
    n = 10;                                /* Wait for a valid response in timeout of 10 attempts */
    do
        res = xchg_spi(0xFF);
    while ((res & 0x80) && --n);
    return res;            /* Return with the response value */
   Public Functions
/* Initialize Disk Drive                                                 */
FCLK_SLOW();
    ty = 0;
            } else {
                ty = 0;
    CardType = ty;
    deselect();
FCLK_FAST();
        power_off();
    return Stat;
/* Get Disk Status                                                       */
DSTATUS disk_status (
    return Stat;
/* Read Sector(s)                                                        */
DRESULT disk_read (
    BYTE pdrv,            /* Physical drive nmuber (0) */
    BYTE *buff,            /* Pointer to the data buffer to store read data */
    DWORD sector,        /* Start sector number (LBA) */
    UINT count            /* Sector count (1..128) */
    BYTE cmd;
    if (pdrv || !count) return RES_PARERR;
    if (Stat & STA_NOINIT) return RES_NOTRDY;
    if (!(CardType & CT_BLOCK)) sector *= 512;    /* Convert to byte address if needed */
    cmd = count > 1 ? CMD18 : CMD17;            /*  READ_MULTIPLE_BLOCK : READ_SINGLE_BLOCK */
    if (send_cmd(cmd, sector) == 0) {
        do {
            if (!rcvr_datablock(buff, 512)) break;
            buff += 512;
        } while (--count);
        if (cmd == CMD18) send_cmd(CMD12, 0);    /* STOP_TRANSMISSION */
    deselect();
    return count ? RES_ERROR : RES_OK;
/* Write Sector(s)                                                       */
#if _USE_WRITE
DRESULT disk_write (
    const BYTE *buff,    /* Pointer to the data to be written */
    if (Stat & STA_PROTECT) return RES_WRPRT;
    if (count == 1) {    /* Single block write */
        if ((send_cmd(CMD24, sector) == 0)    /* WRITE_BLOCK */
            && xmit_datablock(buff, 0xFE))
            count = 0;
    else {                /* Multiple block write */
        if (CardType & CT_SDC) send_cmd(ACMD23, count);
        if (send_cmd(CMD25, sector) == 0) {    /* WRITE_MULTIPLE_BLOCK */
            do {
                if (!xmit_datablock(buff, 0xFC)) break;
                buff += 512;
            } while (--count);
            if (!xmit_datablock(0, 0xFD))    /* STOP_TRAN token */
                count = 1;
    deselect();
#endif
/* Miscellaneous Functions                                               */
#if _USE_IOCTL
DRESULT disk_ioctl (
    BYTE cmd,        /* Control code */
    void *buff        /* Buffer to send/receive control data */
    DRESULT res;
    BYTE n, csd[16], *ptr = buff;
    DWORD csize;
    if (pdrv) return RES_PARERR;
    res = RES_ERROR;
    switch (cmd) {
    case CTRL_SYNC :        /* Make sure that no pending write process. Do not remove this or written sector might not left updated. */
        if (select()) res = RES_OK;
        break;
    case GET_SECTOR_COUNT :    /* Get number of sectors on the disk (DWORD) */
        if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) {
            if ((csd[0] >> 6) == 1) {    /* SDC ver 2.00 */
                csize = csd[9] + ((WORD)csd[8] << 8) + ((DWORD)(csd[7] & 63) << 16) + 1;
                *(DWORD*)buff = csize << 10;
            } else {                    /* SDC ver 1.XX or MMC*/
                n = (csd[5] & 15) + ((csd[10] & 128) >> 7) + ((csd[9] & 3) << 1) + 2;
                csize = (csd[8] >> 6) + ((WORD)csd[7] << 2) + ((WORD)(csd[6] & 3) << 10) + 1;
                *(DWORD*)buff = csize << (n - 9);
            res = RES_OK;
        break;
    case GET_BLOCK_SIZE :    /* Get erase block size in unit of sector (DWORD) */
        if (CardType & CT_SD2) {    /* SDv2? */
            if (send_cmd(ACMD13, 0) == 0) {    /* Read SD status */
                xchg_spi(0xFF);
                if (rcvr_datablock(csd, 16)) {                /* Read partial block */
                    for (n = 64 - 16; n; n--) xchg_spi(0xFF);    /* Purge trailing data */
                    *(DWORD*)buff = 16UL << (csd[10] >> 4);
                    res = RES_OK;
            if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) {    /* Read CSD */
                if (CardType & CT_SD1) {    /* SDv1 */
                    *(DWORD*)buff = (((csd[10] & 63) << 1) + ((WORD)(csd[11] & 128) >> 7) + 1) << ((csd[13] >> 6) - 1);
                } else {                    /* MMCv3 */
                    *(DWORD*)buff = ((WORD)((csd[10] & 124) >> 2) + 1) * (((csd[11] & 3) << 3) + ((csd[11] & 224) >> 5) + 1);
                res = RES_OK;
        break;
    /* Following commands are never used by FatFs module */
    case MMC_GET_TYPE :        /* Get card type flags (1 byte) */
        *ptr = CardType;
        res = RES_OK;
        break;
    case MMC_GET_CSD :        /* Receive CSD as a data block (16 bytes) */
        if (send_cmd(CMD9, 0) == 0        /* READ_CSD */
            && rcvr_datablock(ptr, 16))
            res = RES_OK;
        break;
    case MMC_GET_CID :        /* Receive CID as a data block (16 bytes) */
        if (send_cmd(CMD10, 0) == 0        /* READ_CID */
            res = RES_OK;
        break;
    case MMC_GET_OCR :        /* Receive OCR as an R3 resp (4 bytes) */
        if (send_cmd(CMD58, 0) == 0) {    /* READ_OCR */
            for (n = 4; n; n--) *ptr++ = xchg_spi(0xFF);
            res = RES_OK;
        break;
    case MMC_GET_SDSTAT :    /* Receive SD statsu as a data block (64 bytes) */
        if (send_cmd(ACMD13, 0) == 0) {    /* SD_STATUS */
            xchg_spi(0xFF);
            if (rcvr_datablock(ptr, 64))
                res = RES_OK;
        break;
    case CTRL_POWER_OFF :    /* Power off */
        power_off();
        Stat |= STA_NOINIT;
        res = RES_OK;
        break;
    default:
        res = RES_PARERR;
    deselect();
    return res;
#endif
/* Device Timer Interrupt Procedure                                      */
/* This function must be called in period of 10ms                        */
void disk_timerproc (void)
     BYTE n;
     n = Timer1;                /* 100Hz decrement timer */
     if (n) Timer1 = --n;
     n = Timer2;
     if (n) Timer2 = --n;
Thank you :)
Which version of FatFs is this? The most recent ones say you must not cal disk_initialize() directly.
While as a test during initial setup I guess it's OK to call the initialize function just to get an immediate return code - when that is OK then remove everything to do with calling disk_initialize().
It's 2015 version, ff_conf.h version:
/  FatFs - FAT file system module configuration file  R0.11 (C)ChaN, 2015
Sorry for not answering sooner, but i was a little bit busy, anyway... I think i got something interesting, now i can create a TXT file and it always works!!!
How did i "fixed it"? -I say "fixed it" because i'm not pretty sure if that is the correct solution-. After watching all signals in osciloscope i noted that the problem was my CS pin, when it was working it had 5 volts and 0 when it wasn't. So i decided to comment the select and deselect fuctions in mmc_avr.c and as i told you now i can create a file.
I commented everything related to this two functions:
//static
//void deselect (void)
//    CS_HIGH();        /* Set CS# high */
//    xchg_spi(0xFF);    /* Dummy clock (force DO hi-z for multiple slave SPI) */
//static
//int select (void)    /* 1:Successful, 0:Timeout */
//    CS_LOW();        /* Set CS# low */
//    xchg_spi(0xFF);    /* Dummy clock (force DO enabled) */
//    if (wait_ready(500)) return 1;    /* Wait for card ready */
//    deselect();
//    return 0;    /* Timeout */
Now is time to write into the file but i can't. When i'm trying to write into my file f_write and f_sync functions return FR_DISK_ERR; if i don't use f_write, f_sync works perfectly (returns FR_OK). I tried using only f_write without f_sync but i have the same problem (FR_DISK_ERR). Here is my main code and the complete .ZIP:
 * SD_atmega328p.c
 * Created: 13/05/2019 09:23:51 p. m.
 * Author : MoustachedBird
 #define BAUD 9600
#include <avr/interrupt.h>
#include <string.h>
#include "ff.h"
#include "ffconf.h"
#include "integer.h"
#include "diskio.h"
// setup timer 100 hz
void setupTimer(void)
    TCCR1A = 0;     // set entire TCCR1A register to 0
    TCCR1B = 0;
    TCCR1B |=(1<<WGM12);      //CTC mode; clock timer comare
    TIMSK1 |= (1<<OCIE1A);  //ENABLE INTERUPTs
    OCR1A = 0x4E20;
    TCCR1B |=  (1<<CS11); //PRESCALER
    //Start interupt
    sei();
    // Set baud rate
    UDR0 = data;
        str++;
       FRESULT errCode;       /* Result object      */
       UINT bw;             /* Bytes object  */
       setupTimer();
       serial_write_str("PROGRAM INIT\r\n");
       serial_write_str("disk_initialize: ");
       else if (errCode == STA_NODISK){
           serial_write_str("STA_NODISK\r\n");
       else if (errCode == STA_PROTECT){
           serial_write_str("STA_PROTECT\r\n");
       else {
           serial_write_str("DONE\r\n");
       errCode = f_mount(&fatfs,"",0);   //Mount Fat object
       serial_write_str("f_mount: \r");
           serial_write_str("FR_OK\r\n");
       if (errCode == FR_INVALID_DRIVE){
           serial_write_str("FR_INVALID_DRIVE\r\n");
       if (errCode == FR_DISK_ERR){
           serial_write_str("FR_DISK_ERR\r\n");
       if (errCode==  FR_NOT_READY){
           serial_write_str("FR_NOT_READY\r\n");
       if (errCode== FR_NOT_ENABLED){
           serial_write_str("FR_NOT_ENABLED\r\n");
       if (errCode==FR_NO_FILESYSTEM){
           serial_write_str("FR_NO_FILESYSTEM\r\n");
       errCode = f_open(&file, "Sample1.txt",  FA_CREATE_ALWAYS | FA_WRITE );
       serial_write_str("f_open: \r");
       else if (errCode == FR_DISK_ERR) {
       else if (errCode == FR_INT_ERR) {
           serial_write_str("FR_INT_ERR\r\n");
       else if (errCode == FR_NOT_READY) {
       else if (errCode == FR_NO_FILE) {
           serial_write_str("FR_NO_FILE\r\n");
       else if (errCode == FR_NO_PATH) {
           serial_write_str("FR_NO_PATH\r\n");
       else if (errCode == FR_INVALID_NAME) {
           serial_write_str("FR_INVALID NAME\r\n");
       else if (errCode == FR_DENIED) {
           serial_write_str("FR_DENIED\r\n");
       else if (errCode == FR_INVALID_OBJECT) {
           serial_write_str("FR_INVALID_OBJECT\r\n");
       else if (errCode == FR_WRITE_PROTECTED) {
           serial_write_str("FR_WRITE_PROTECTED\r\n");
       else if (errCode == FR_INVALID_DRIVE) {
       else if (errCode == FR_NOT_ENABLED) {
       else if (errCode == FR_NO_FILESYSTEM) {
       else if (errCode == FR_TIMEOUT){
           serial_write_str("FR_TIMEOUT\r\n");
       else if (errCode == FR_LOCKED){
           serial_write_str("FR_LOOKED\r\n");
       else if (errCode == FR_NOT_ENOUGH_CORE){
           serial_write_str("FR_NOT_ENOUGH_CORE\r\n");
       else if (errCode==FR_TOO_MANY_OPEN_FILES){
           serial_write_str("FR_TOO_MANY_OPEN_FILES\r\n");
       errCode = f_write(&file, "hello_world", 11, &bw);    /* Write data to the file */
       serial_write_str("f_write: \r");
        else if(errCode == FR_DISK_ERR){
        else if(errCode == FR_INT_ERR){
        else if(errCode == FR_DENIED){
        else if(errCode == FR_INVALID_OBJECT){
        else if(errCode == FR_TIMEOUT){
       errCode=f_sync(&file);  //Flush cache
       serial_write_str("f_sync: \r");
       errCode=f_close(&file); //Close the file
       serial_write_str("f_close: \r");
       while (1)
    disk_timerproc();
Thank you :)
So to be short....
you have put 5V supply on a Sd card that is only supposed to get 3V3 AND eventhough you have not actually selected the card to be interfaced with ( CS line is logical high ( so 3V3 or in your case perhaps even 5V ) ) you have managed to interface with it....
