Waveme: Free timing diagram drawing tool
28 posts / 0 new
Introducing Waveme
A new, free, GUI-based, digital and analog (mixed-signal) timing diagram drawing software for Windows (and Linux via Wine).
Waveme is intended primarily for documentation purposes,
where a diagram can be exported (stored) to an image file (BMP, PNG, SVG or TIFF) or a PDF document.
A color diagram can be converted to black-and-white, and saved into a new file.
Waveme can be used to draw waveforms, gaps, arrows, labels and value-lines (see attached images).
Both, digital and analog signals can be drawn.
Highly configurable, with a wealth of keyboard shortcuts.
Website:
waveme.weebly.com
Google group for questions, bug reports, feature requests, and general discussion:
https://groups.google.com/forum/#!forum/waveme
Waveme is distributed as a 32-bit single-file executable, it doesn't require installation,
and there are no changes to the registry nor configuration files.
Please note that because it is an executable file, it might be flagged by antivirus programs.
Avoid false-positive, by always confirming with Google's www.virustotal.com.
Hope you find it useful!
Just found this - it looks really nice.
Thanks for posting this ... and writing the program.
BTW, I downloaded the exe and scanned it with McAfee with no issues.
wnitzan wrote:
Please note that because it is an executable file, it might be flagged by antivirus programs. Avoid false-positive, by always confirming with Google's www.virustotal.com.
This is somewhat funny, as chrome does actually flag the exe file as virus, false positive i assume.
Good work wnitzen. Looks really good.
Do you have any plans for an Apple Mac version?
There are already a million monkeys in front of a million keyboards, and the internet is nothing like Shakespeare!
Thank you for your feedback!
I heard that Waveme runs well under Wine on MacOS.
Currently, I do not own a Mac, so I can't build a native program for MacOS.
If I hear that there is a robust demand for a MacOS port, I will consider.
At the moment, I'm porting Waveme to Linux.
Would a mod please move this to the freeware thread in the off topic forum to keep it from getting lost (and delete this post)?
Sorry Rick. No can do. Don't have the required tools to be able to merge threads. But I will see if I can do a copy paste later... currently killing spammers.
Waveme can be run, as is, on Linux by using Wine.
I tested Waveme with Wine (development version 1.9.21) on Fedora 24 and Ubuntu 16.04 LTS.
Version 1.4 is now available.
New features:
- Bus waveform:
Segment drawing is more flexible. A segment now has 3 (instead of 2) independently specified portions: Transition to level, level, and transition from level.
* This allows for a waveform to start and/or end with the level portion of a segment.
* Multiple segments can be placed back-to-back, with only the outliers having non-zero transitions. This gives the appearance of a single segment with multiple regions.
- Along arrow:
Select whether to show the right and/or left guidelines.
* This makes it possible to draw an arrow pointing in only one direction, and without guidelines around it; or
* A straight line, without arrow heads nor guidelines.
Bug fix:
- Signal and Bus waveform:
Incorrect empty segment after undo of segment deletion.
Oh dear!
I've been looking for something like this for a long time! Very interesting!
Others here know that I've recently migrated to GNU/Linux as primary OS, though. I'll switch over to Windoze for a first test. It that works out I'll consider installing Wine on my Mint.
Thank you very much for posting this!! (Notice double exclamation marks ;-)
I tested Waveme version 1.4 on Ubuntu and Fedora with the latest Wine, that is supported on each platform (2.14 and 2.16, respectively).
Installing Wine was painless for me.
Running Waveme on Wine is nothing more than this command line:
wine waveme.exe [XML_project_file]
Please share your experience with us...
Dare I ask what it is written in? Is there not a possibility of the GUI layer being changed to something more portable so it can be compiled natively for Linux?
It's Python and WxWidgets so there's no tech reason for it not being available native on Linux: http://waveme.weebly.com/about.html
Could it be to keep the source proprietary?
We should always be wary of "free" software that isnt open-sourced. There is the risk of being dropped to the ground or pressed for money for the next version.
I'm still planning to test it, despite this.
Waveme is written in Python with the WxPython GUI toolkit (which is a wrapper around the C++ WxWidget GUI toolkit).
I compiled the code into a single-file executable, so that it is self-contained, easy to download and requires NO installation (completely portable).
Before realizing that Wine exists, I tried porting to multiple Linux distros.
Very quickly I discovered that there are multiple graphics libraries in use,
with multiple "up-to-date" versions on each distro,
each rendering some graphics widgets differently,
and each with its own rendering bugs (who knows where...).
After chasing a few of those... I found Wine.
To my delight, Waveme seems to work flawlessly on Wine without ANY modification!
Apparently, those who wrote Wine already dealt with all those differences, so why would anyone repeat this, if one doesn't have to?
So, my experience is that Python is indeed OS portable, but GUI programming is OS (library) dependent.
As to Waveme not being open source.
You already have the program.
The worst that can happen, if I stop supporting further development, is that you will have benefited from a free program for several years, until it is no longer compatible with Windows...
Yup.
But had the sources been open we could ourselves have built it for any Linux distribution we are running.
Well, I'm on Windows for other matters ATM, so might give it a spin.
Johan, I sent you a PM.
Waveme version 1.5 is now available.
Bug fix: Gaps dialog box did not open.
Waveme version 1.6 is now available.
New features:
- Superscript and subscript: supported in all text entries.
- Waveform name: Can be individually customized per row (font, color and alignment).
- All waveforms support segment labels, with identical and expanded customization options.
- Signal and Bus waveform, segment label vertical position: can be placed above a segment too.
- Multiple segment selection in Bus and Signal waveforms: supports duplicate, delete and move operations.
- Auto Bus and Auto Signal waveforms:
  * Added support for first, multiple gap, and last segments.
  * Segment labels:
     - Text can surround the auto-generated numeric values.
     - Supports wrap around, and initial wrapped around numeric values.
- Row copy and paste operations allow copying a row from one diagram to another.
- Title: Horizontal position can now be relative either to the whole diagram, or to the waveforms area.
- Horizontal grid lines:
  * Can select not to show in Spacer Rows.
- Vertical grid lines:
  * Can end on a given unit.
  * Can draw groups of vertical lines with a gap in between.
  * Can draw single vertical lines.
- Along Arrow:
  * Option not to show horizontal line.
  * Option to extend guidelines to cover arrow's own waveform.
- Aware of multiple connected monitors.
Waveme version 1.7 is now available.
New features:
  • Signal waveform: Added D (Data) segment.
  • Across arrow: Arrow head can be bidirectional: Head can be drawn at the "From row" end, as well as at the "To row" end.
Waveme 2.0 is now available.
This version includes UI changes for faster user interaction:
- Adding a new item immediately adds the item to the diagram, using default values, and then opens an edit dialog for further adjustments to the new item.
- An "Apply" button was added to all edit dialogs, General options and Waveform options dialogs. Now you can apply your changes to a diagram, while the dialog stays open, allowing you to observe and make adjustments faster.
- Row arrows are managed with a tabbed notebook dialog.
- Row labels are managed with a tabbed notebook dialog.
Waveme 2.1 is now available.
New feature:
    In Auto-bus and Auto-signal dialogs, auto-label values are not allowed to be left empty.
Bug fix:
    Redraw dialog window after a change in selected font to prevent dialog box from being drawn incorrectly.
Waveme version 2.2 is here!
New features:
- Expanded support for clipboard copy/paste operations to Bus and Signal segments, row arrows and row labels.
Now rows, segments, arrows and labels can be copied and pasted either within the same diagram or in another diagram.
- Along arrow guideline can now be from any row to any row, instead of from current row to any row.
Bug fixes:
- Row copy/paste was broken.
- Saving to a PDF file with "A4" page size and "Portrait" orientation created a "Letter" page size instead.
What's next?
I'm looking into adding analog signal drawing capabilities to Waveme, turning Waveme from a digital-only into a mixed-signal waveform drawing tool.
Please share your needs, and post some analog drawings, that you'd like to create with Waveme.
Version 2.3 is now available.
New features:
- Export (save) diagram to SVG image file format.
- Directly export (save) color diagram into a black-and-white image file or PDF document.
No longer needs to first save as a black-and-white diagram, reload that diagram, and only then export.
- Open a diagram file with drag-n-drop onto Waveme's window.
- Value-lines: A new row element.
Horizontally drawn lines across a waveform, with tick marks and labels to the left of the waveform.
Most commonly used with analog signals to denote vertical values.
- Labels can be rotated, instead of only be horizontal. Applies to labels, arrows and value-lines.
Rotation is only supported when using True Type fonts.
- Signals can now start with a D value. If first segment is also a D, the left-end will be shown opened.
- Bus and Auto-bus waveforms can have open ends when using D and X segments, instead of only closed ends.
Thanks for the heads up on the new version.  I've had it for a while now and it works great!
Happy Trails,
Mike
JaxCoder.com
If you're on Linux, try gtkwave.
MattRW, Waveme is a waveform drawing tool, not a waveform viewer like gtkwave.
Version 2.4 is a bug fix.
Across arrow: vertical shape had incorrect to/from unit selections.
Version 2.5 is here, just in time for Waveme's 3rd anniversary.
New features:
- Analog waveform drawing:
Signal row now supports 3 new analog segment types: Sine, Linear and Ramp/RC time constant.
A mix of both digital (L, H, Z, X, D) and analog segment types can be drawn in the same row.
- Quickly change Signal and Bus segment width without opening a dialog box, by mouse dragging, keyboard shortcuts, toolbar buttons or menu commands.
- Project and image file dialogs now show an initial suggestion based on the diagram's name, and remember last directory location for each type.
- Default font is now OS and local system dependent.
Bug fix:
- Gaps: Handled occasional incorrect drawing of an edge's middle pixel.
